Like Tree28Likes
Old 03-24-2015, 04:25 PM   #8536
Originally Posted by STLNLST View Post
Well I just pulled the trigger of the kit from Tower. Once it comes back instock I will have one.
Randy005- How did the chassis feel compared to the kit chassis?
been awhile since I have ran it indoors with the stock chassis but to me it felt less twitchy and jumped much better then I remember, but I did also have the wing in the lower position. I was running stock setup with the Schelle but next time will go with 7k, 60k, 5k to help it smooth it out. The stock setup and the 5.5t motor made it like a On & Off Switch so going to a 6.5t and diff change should help me be more consistent
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 03-24-2015, 04:40 PM   #8537
Jakesterama's Avatar
Trader Rating: 64 (100%+)
Guys running the Schelle, were your already on the longest wheelbase with rear shims? Did you play around with more forward swept front arms?
if (racing_skill<AWESOME){
practice_lap++;
Jakesterama is offline   Reply With Quote
Old 03-24-2015, 05:01 PM   #8538
STLNLST's Avatar
Trader Rating: 19 (100%+)
Thanks for the info.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-24-2015, 05:52 PM   #8539
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
with all of the slop in the steering and the forgiving nature of the center diff, i've never considered this buggy "twitchy". it's not numb by any means. my durango 410v3 was twitchy. with the exotek rack (that takes out at least half the slop) it's a beautiful balance between responsiveness and forgiveness.
RC*PHREAK is offline   Reply With Quote
Old 03-25-2015, 03:13 AM   #8540
HSV427's Avatar
Trader Rating: 21 (96%+)
I really can't believe my luck I've had this buggy 6 months with not one problem until i changed to a smaller pinion and didn't set my mesh right and stripped a spur, clearly my fault, but i can't work it out took the car out for the first time today with the new exotek spur gear and not even 10 laps later i stripped it, the mesh was set perfect, and the motor never came lose, but i still managed to strip it, I'm really at a loss as to whats going on i mean i no spurs strip from a bad mesh but when it happens and the mesh was perfect it really does leave you dumb founded, anyway time to install the new spur and fingers crossed it was just a one off.
XRAY XB4 15, XRAY XB4 16, XRAY XB2, YOKOMO B-MAX4 III FACTORY KIT, YOKOMO YZ4, YOKOMO YZ2,KYOSHO RB6, TAMIYA TRF503, TAMIYA TRF201XMW, TAMIYA TRF 211XM
HSV427 is offline   Reply With Quote
Old 03-25-2015, 04:46 AM   #8541
egobrkr's Avatar
Trader Rating: 26 (100%+)
I agree 100 %. I don't find the buggy twitchy at all. I'm not far off the stock setup but did make a few changes during the build that I knew I would do later. I feel the buggy drives "heavy" for as light as it is. I was not far of pace for lap times with the guy that won our summer seires with his b44.3. This buggy for me is a ton of fun to drive and I can push it very hard and sometimes too hard. I run 7k 100k 4k for diff oil. I was thinking the 100k was going to be too thick but it wasn't.
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 03-25-2015, 07:54 AM   #8542
maybe not Twitchy but it is very aggressive and I am just trying to clam her down so she drives alittle more smoother even tho the buggy wants to be pushed. Basically want it to be like my xb4 but better in the bumps and on big air tracks. So far the Schelle Chassis, exotek rack and the Rc Shox 2x1.6 & 2x1.7 Pistons have helped the car out alot.
Old 03-25-2015, 08:14 AM   #8543
Sounds like the 5 dot ackerman arms might be just what you're looking for.
-Chris
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 03-25-2015, 08:42 AM   #8544
egobrkr's Avatar
-Chris
5 dot ackerman arm? What's that?
Old 03-25-2015, 08:47 AM   #8545
slakr's Avatar
Trader Rating: 28 (100%+)
http://www3.towerhobbies.com/cgi-bin...?&I=LXEGJA&P=7
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is online now   Reply With Quote
Old 03-25-2015, 08:58 AM   #8546
Suspended
-Chris
He could also change (among many things) his front toe setting, camber, arm sweep, diff oils, and caster/kick up. Personally, I feel a change in front toe/camber can greatly alter how reactive a car is, and where in the corner it makes grip.
Another thing is what front tire he is using and how it is being prepped. Could be something as easy as not saucing the fronts, going to a different tread pattern, insert or compound.
If he posts up the setup info from the front half of his car we can get him pointed in the right direction with his setup.
Mantis Toboggan is offline   Reply With Quote
Old 03-25-2015, 09:46 AM   #8547
Turn down your expo on the transmitter.
bladeys is offline   Reply With Quote
Old 03-25-2015, 09:58 AM   #8548
MasiisaM's Avatar
I had a few gears strip as well and didn't understand why..mesh and motor mount were set fine and tight.
Found out the bell cap going to the can of the motor was slightly loose. The three screws on the can of the Tekin motor backed out a bit. Gave it just enough to give me a headache, but not enough it was obvious.
Tightened it down with some loctight...No issues.
TLR 22 2.0 - TLR 8E 3.0 - HB D413
Thanks to:
Tekin - www.teamtekin.com
Thunder Designs - www.thunderdesigns.net
MasiisaM is offline   Reply With Quote
Old 03-25-2015, 10:05 AM   #8549
slakr's Avatar
I was able to catch this early so I didn't end up stripping the spur gear, but the same exact thing happened on my D413.
Old 03-25-2015, 10:18 AM   #8550
egobrkr's Avatar
Originally Posted by slakr View Post
So does it affects the throw of the steering?
