Like Tree31Likes
Old 03-22-2015, 11:42 PM   #8521
nitro2be's Avatar
Originally Posted by HSV427 View Post
Just out off curiosity has any one else stripped an engine mount, i find that if only just tighten it, it comes loose and if i over tighten it it stripps, I'm really struggling to find that sweet spot.
I always blue loctite 24 hours before I go to track.never has failed. You already know you need to replace yours and it's not cheap.
nitro2be is offline   Reply With Quote
Old 03-22-2015, 11:49 PM   #8522
HSV427's Avatar
Trader Rating: 21 (96%+)
Exactly at $80 Australian delivered its an expensive learning curve, ill try the loctite thanks its just not some were i would normally put lactate but your right blue is only medium strength so ill give it a try.
Serpent 977 35th anniversary. Serpent 977 evo2, Shepherd Velox, Motonica p81rs2, OS speed shimo edition.
HSV427 is offline   Reply With Quote
Old 03-23-2015, 12:10 AM   #8523
nitro2be's Avatar
U might be cheaper having it re threaded .look into it,3.5 or 4 mm
Old 03-23-2015, 07:17 AM   #8524
Jakesterama's Avatar
Trader Rating: 64 (100%+)
+1 if it is a top screw, drill and tap it for a bigger screw, problem solved. If it is a bottom hole, chamfering the chassis might be tough with average tools. The biggest problem I have found with RC aluminum is debris on the screw or in the hole. Always hit your screws that are going into aluminum with a quick shot of motor spray or at least wipe it off. That is also the reason I stopped using LocTite. The build-up on the threads would end up stripping the fine threads after a couple rebuilds.
Jakesterama is offline   Reply With Quote
Old 03-23-2015, 12:00 PM   #8525
tom76's Avatar
Trader Rating: 30 (100%+)
Pm sent
Cheers.
St Ives - Sworkz / XB4 17 / XB2
tom76 is offline   Reply With Quote
Old 03-23-2015, 12:29 PM   #8526
Thanks for your response but i was talking about the sweet spot on the new engine mount as i really don't want to strip another one.
I guess the sweet spot for the mount is wherever the mesh is perfect. Sweetspot for the screws is tight with blue locktight. Many people are changing out the button head screws for socket heads to get more torque on them.
Tight equals: 1.5 to 2.5 Nm depending on head/grade
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 03-23-2015, 05:06 PM   #8527
BmainStar's Avatar
Exactly at $80 Australian delivered its an expensive learning curve, ill try the loctite thanks its just not some were i would normally put(((( lactate)))))) but your right blue is only medium strength so ill give it a try.
Think I see the Problem..Lactate LOL Any thing screwing in to alum on a r/c car should have Lactate
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 03-23-2015, 05:08 PM   #8528
Socket heads work good with blue lock tight. Now how about some parts and apparel? Not good marketing and distributionand I am here by the HPI headquarters, virtially not present.
bladeys is offline   Reply With Quote
Old 03-23-2015, 09:44 PM   #8529
STLNLST's Avatar
Trader Rating: 21 (100%+)
Anyone in Norcal running one of these beasts?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-23-2015, 09:46 PM   #8530
HSV427's Avatar
How are people finding the new avid and schelle chassis, have they improved the buggy and are they worth the $$$. the buggy is already pretty awesome so its hard to imagine it better.
Old 03-24-2015, 09:28 AM   #8531
boudin4evr's Avatar
Trader Rating: 18 (100%+)
im thinking about trying the schelle chassis
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 03-24-2015, 09:49 AM   #8532
Vinny Cancilla's Avatar
Not sure about schelle chassis, but from what I read, the avid chassis is really meant for very high bite.
Serpent Srx8
Serpent America: Triton engines/ Nitro pro.Fuel/ Rc Addiction products : Vp pro Usa/Dialed-Rc
Barnstormers: Chester, NY, N.Y.. IRH Lindenhurst
Vinny Cancilla is offline   Reply With Quote
Old 03-24-2015, 09:58 AM   #8533
Ran My Schelle Chassis for the 1st time at MSCS Round 1 and it was pretty sweet. My only issue is I was running a 5.5t and was just to much motor for that size track and surface. I also ran the wing in the lower position and it seemed to help it jump and fly better. think ill go back to my 6.5t for the next round at Dirt Burners.
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 03-24-2015, 02:33 PM   #8534
HSV427's Avatar
Thanks for the advise i just pulled the trigger on the schelle chassis, can't wait to get it and test.
Old 03-24-2015, 03:35 PM   #8535
STLNLST's Avatar
Well I just pulled the trigger of the kit from Tower. Once it comes back instock I will have one.
Randy005- How did the chassis feel compared to the kit chassis?
