Like Tree28Likes
Old 03-22-2015, 01:52 AM   #8491
HSV427's Avatar
Trader Rating: 21 (96%+)
Originally Posted by nitro2be View Post
Here's some better advice, go to track in your area and watch the speed of individual cars.see one you like that fits your skill and personality then ask what turn motor they are running. I've always been the kind of guy that wants the 671 blower with NOS and I'll learn to drive it. Call me crazy, it's just my personality. Do you want a mustang or prius?
+1 Great advise.
XRAY XB4 15, XRAY XB4 16, XRAY XB2, YOKOMO B-MAX4 III FACTORY KIT, YOKOMO YZ4, YOKOMO YZ2,KYOSHO RB6, TAMIYA TRF503, TAMIYA TRF201XMW, TAMIYA TRF 211XM
HSV427 is offline   Reply With Quote
Old 03-22-2015, 04:56 AM   #8492
fredmotokx's Avatar
Nice call, I run a 6.5T in all my buggy and sometime I feel like I need more, I'm kinda sad I have not buy a 5.5...
TLR SCTE 2.0
Team associated B5
fredmotokx is offline   Reply With Quote
Old 03-22-2015, 06:44 AM   #8493
RENOV8R's Avatar
I'd say 6.5 is a good all around motor. When on a small track I just turn the radio down to 75% throttle. No use getting a 13.5 then realizing it's not enough for your track. These are 4 wheelers, they like lotsa power
RENOV8R is offline   Reply With Quote
Old 03-22-2015, 06:51 AM   #8494
RENOV8R's Avatar
Originally Posted by HSV427 View Post
Just wondering is there any advantage in running the exotek spur gear, i stripped the stock spur and was wondering should i just replace it with the stock one or upgrade to the exotek.
I'm sure the Exotek is a good upgrade but make sure you have a good look and make sure there isn't a reason the original one stripped in the first place. I've had mine a few months and the stock spur is still fine. I think with all the talk about the stock ones being a little out of round, some are leaving the mesh a little looser than it should be.
Old 03-22-2015, 07:20 AM   #8495
Anyone have issue with the center diff leaking? Those super small screws are not very good I don't think strip the diff case easy if over tightened.
turtle189 is offline   Reply With Quote
Old 03-22-2015, 07:42 AM   #8496
Make sure and take your time using the right tool. Did you use a .050 or the 1.3mm driver? .050 fits a lot tighter. And when you tighten them down do it like a car tire, don't cinch them down in a circle, go in a star pattern. Make sure you don't over tighten them.
CaseyD is offline   Reply With Quote
Old 03-22-2015, 08:26 AM   #8497
nitro2be's Avatar
I did.over tightened too so I replaced with new stock one and ordered spare, then next day exotek comes out with there's that solves the problem. The stock replacement seem to be little harder plastic and no leaking since.
nitro2be is offline   Reply With Quote
Old 03-22-2015, 08:55 AM   #8498
I did use the right hex and a star pattern. I just think the screws should be a bit bigger thread size. I bought this used was leaking a bit I changed gasket and oring but when put back together leaks worse. Two of the screws didn't tighten up all that great.
Old 03-22-2015, 09:42 AM   #8499
Mine has also been leaking. I assembled with much care abd the second time I put gasket sealer, haven't ran it yet.
bladeys is offline   Reply With Quote
Old 03-22-2015, 09:56 AM   #8500
Overfilling maybe?
Fill to top of cross pins then install final sun gear and spur/cover.
GimpyGolden is offline   Reply With Quote
Old 03-22-2015, 11:48 AM   #8501
SeanKewley's Avatar
Iím looking to get back into buggies and was wondering if a 3800kv Neu-Castle motor would be a good entry point for me with this kit. I havenít raced since the late 80s (RC10 for 2wd and Kyosho Optima Mid for 4wd).
I have pretty much decided on the D413. Has the parts supply improved much? I see Amain and Tower carry parts. Are there any other US online stores that are trust worthy as well?
SeanKewley is offline   Reply With Quote
Old 03-22-2015, 03:18 PM   #8502
Trader Rating: 89 (100%+)
while that is a good motor, I think you'd be much happier with a sensored system
dan-o is offline   Reply With Quote
Old 03-22-2015, 04:03 PM   #8503
SeanKewley's Avatar
Glad I asked. I'm familiar with sensorless ESCs and motors from racing fast electric boats, but didn't realize the cars benefited from sensored power systems. What would be a compatible sensoed setup in the 3800 kv range?
Old 03-22-2015, 04:18 PM   #8504
HSV427's Avatar
I found the problem with why i stripped the original, it was due to my motor coming loose, i think I've over tightened the motor mount and may have stripped it cause it just won't tighten up, just as it starts to get tight it gets to that point and then just spins and becomes loose.
Old 03-22-2015, 04:32 PM   #8505
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
It kind of in between a 13.5 and a 10.5.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
