Like Tree42Likes
Old 03-21-2015, 05:00 PM   #8476
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Qrio View Post
Just bought this buggy and new into RC.
Any advice as to what is a good ESC/Motor combo for starters?
You are going to get a ton of replies with everyone's favorite manufacturer on this. I would get a decent sensored ESC with an 8.5 turn motor and don't hesitate to turn the power down.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 03-21-2015, 05:11 PM   #8477
egobrkr's Avatar
Trader Rating: 26 (100%+)
So just installed the exotek aluminum steering Ackerman. If you have not got the hopup, don't wait any longer. It took out a significant amount of play in the steering. Just be sure to not tighten the screws down tight as it will bind the bearings that come with the ackerman.
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 03-21-2015, 08:20 PM   #8478
nitro2be's Avatar
Orion 5.5 just like setup sheets for ty tessman, and turn it up.hes right your gonna get lots of input on that question. You can never have to much power just be smooth with throttle.
nitro2be is offline   Reply With Quote
Old 03-21-2015, 08:24 PM   #8479
Jakesterama's Avatar
Trader Rating: 67 (100%+)
Well, finally broke a part on my buggy. Rear outside camber link ball cup. Put a new one on, broke it again in 2 laps! Must have got some bad plastic. Gave the 3rd one a pretty good test hit on the same part of the track, and no break! Should be good again for a while (I hope).
if (racing_skill<AWESOME){
practice_lap++;
Jakesterama is offline   Reply With Quote
Old 03-21-2015, 08:25 PM   #8480
HSV427's Avatar
Trader Rating: 22 (96%+)
+1 definitely a must have, the steering feels so much more precise.
Serpent 988, OS speed shimo edition, Serpent 977 35th anniversary. OS speed shimo edition Serpent 977 evo2, Novarossi Mito WC35 2017, Shepherd Velox, O.S Speed r2102, Motonica p81rs2, REDS Racing M7 WCS V3.0, , CM 1/8 INFINITY O.S Speed 2103.
HSV427 is offline   Reply With Quote
Old 03-21-2015, 08:29 PM   #8481
HSV427's Avatar
Does anyone no a good size pinion I should run with a 6.5t motor and a 72t spur gear, running on a medium size out door track.
Old 03-21-2015, 08:40 PM   #8482
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Add shims between the 2 bearings. Pick up some Kyosho 3x5 by .3mm thick shims, remove the top bearings on the Ackerman bar, drop 3 shims on to of each bearing, put top bearings back in, tighten er up. Too long to write the explanation but this is the fix.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 03-21-2015, 08:45 PM   #8483
Yeti AS3's Avatar
If its a true 6.5 your prob looking at around a 23. An orion or speed passion (have run both) are both soft. A 6.5 is more like a 7.5. I run a SP 5.5 now w/23p
Hot Bodies D413
AE B5m
Old 03-21-2015, 08:54 PM   #8484
Moderator
bds81175's Avatar
You still managed to get third!!
Tekno RC
Old 03-21-2015, 09:24 PM   #8485
HSV427's Avatar
Im running a Gforce 6.5t so i don't no if its a real 6.5t, but thanks for the starting point.
Old 03-21-2015, 09:33 PM   #8486
HSV427's Avatar
Just wondering is there any advantage in running the exotek spur gear, i stripped the stock spur and was wondering should i just replace it with the stock one or upgrade to the exotek.
Old 03-21-2015, 09:56 PM   #8487
nitro2be's Avatar
Yes exotek. If mine ever wears out and my spare, I'm getting exotek !
Old 03-21-2015, 10:51 PM   #8488
Suspended
You're suggesting a person new to rc put a 5.5 in his car? That has to be some of the worst advice I have seen on this forum. You can absolutely have too much power. A 5.5 is a lot of motor, and someone brand new would just destroy their car with that much power.
Qrio, it really depends on what you plan on doing. Are you going to race, or just drive the car around in your neighborhood and fields (bashing)? The D413 is a race car designed for use on a track. Things like tall grass and rough terrain will make driving a buggy not very fun. If you do plan on bashing, something like an 8.5 will be plenty of power. If you do plan on running on track, a 13.5 and a speed control that can add timing would be the best place to start. Start with no timing, then when you are ready for more power, you can add timing.
Driving on a track is much more difficult than just driving around in a field. Add to that a car that has way too much power and you have a recipe for frustration.
Mantis Toboggan is offline   Reply With Quote
Old 03-21-2015, 10:52 PM   #8489
HSV427's Avatar
Thanks for the quick response.
Old 03-21-2015, 11:26 PM   #8490
nitro2be's Avatar
Here's some better advice, go to track in your area and watch the speed of individual cars.see one you like that fits your skill and personality then ask what turn motor they are running. I've always been the kind of guy that wants the 671 blower with NOS and I'll learn to drive it. Call me crazy, it's just my personality. Do you want a mustang or prius?
