Like Tree28Likes
Old 03-11-2015, 01:07 PM   #8341
Originally Posted by tom2tone View Post
What are you guys using to mount your esc's? I've tried my usual Kyosho gel mounting tape and servo tape. The Kyosho tape wouldn't stick to the chassis and the servo tape eventually slides my esc forward. Thanks for any advice!
Home Depot, 3M mounting tape with the 20lb holding weight. Double it up though for shock obsorbtion, it's pretty thin compared to the gel type.
CaseyD is offline   Reply With Quote
Old 03-11-2015, 01:54 PM   #8342
ironzgti35's Avatar
Trader Rating: 20 (100%+)
3M Outdoor double sided tape, mine has always been gray with a red peel.
http://www.homedepot.com/p/Scotch-1-...1-DC/100575385
HB Racing Proline Sweep Racing USA - PT RC Racing Oils
ironzgti35 is offline   Reply With Quote
Old 03-11-2015, 05:45 PM   #8343
The only thing you'll have a problem with is making sure you can get something under it to get it off! I actually broke a couple tabs on my airtronics receiver with this stuff pulling from the top to remove it. Very strong and + 1 for the doubling it up to help save your electronics.
Hacksback is offline   Reply With Quote
Old 03-11-2015, 06:42 PM   #8344
Best stuff is from depot or Walmart the 3m. But that and the gel type Parma works good but you have to first clean the spot with some alcohol and make sure it's dry then after application let it sit and cure for a little before trying to wire it up and all of it doesn't cure right like any adhesive it'll come off easy but 3 m is more forgiving. Parma stuff I usua let sit over night before wiring up
Motts97 is offline   Reply With Quote
Old 03-11-2015, 07:08 PM   #8345
No argument here. Whenever I get the wild hair to rewire or reconfigure my layout I always cringe when I hear that cracking sound as you're gently trying to slowly lift one corner at a time.
As a demonstration one time I held my entire car by just holding the on/off switch that was attached with this tape. Crazy strong.
Old 03-11-2015, 07:55 PM   #8346
Run a heat gun on low a little around it but mainly underneath of it on the chassis once it gets warm peals off pretty easy just don't over do it
Old 03-11-2015, 08:15 PM   #8347
snwchris's Avatar
Parma Pro Servo tape. It's been on since September with no issues. The Kyosho gel is too thick for the low body clearance
snwchris is online now   Reply With Quote
Old 03-11-2015, 08:29 PM   #8348
Moderator
bds81175's Avatar
Red peel that statically clings tenaciously to your fingers when trying to throw it in the trash one handed. Stuff is awesome though.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 03-11-2015, 08:46 PM   #8349
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Originally Posted by Texas Racer View Post
I use HB ball caps with HB ball stud. I try to use the kyosho ball caps on the HB
ball stud and its tight..
I run the yoshi ball cups. You have to pinch the ball cup with pliers in a few directions to loosen them up. I did it with a ball off the car so i could make sure it was loose
+1 I use this stuff on every car.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 03-11-2015, 09:06 PM   #8350
tom2tone's Avatar
Trader Rating: 98 (100%+)
Thanks for the advice! I'll pick some up and give it a try. So once you put it on the chassis, its pretty difficult to remove?
TEKNO EB48.3 / ET48
AE T5M & B6
Tekin / AKA / Hitec / SMC / Futaba
Trains and Lanes Racing http://tandlracing.com/
Dunn Raceway Park http://drprc.com
tom2tone is offline   Reply With Quote
Old 03-11-2015, 09:13 PM   #8351
It's definately on there. The easiest way to get it off is to try and roll it off, peeling usually results in the tape tareing.
Old 03-12-2015, 08:18 AM   #8352
Ok so I bought a used d413 I put all my electronics in it. Put it on the track and the either the center diff is slipping which has 100k in it or my sensor wire is bad. It cogs/slips when I try to take off from a stop. Once it's going it's good. I checked the sensor wire and it seems to be plugged in tight. Could it be a problem with the center diff?
mrcjones is offline   Reply With Quote
Old 03-12-2015, 08:42 AM   #8353
Cogging is very different from a slipping diff. If you built the center diff wrong enough that it slips, I would expect it to make quite a nasty sound any time you accelerate or brake.
Diff oil weight shouldn't make any difference for what you're describing.
-Chris
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 03-12-2015, 08:49 AM   #8354
Yeah its smooth and quiet once it's going
Old 03-12-2015, 09:07 AM   #8355
Yeti AS3's Avatar
Plugged in tight doesn't mean the wire can't be bad. They can go south for no reason. Could also be a sensor board. The wire is cheap enough to try.
Hot Bodies D413
AE B5m
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
