Like Tree42Likes
Old 03-10-2015, 09:54 AM   #8326
Tower are releasing the back order D413 but still no alum shock caps.
bladeys is offline   Reply With Quote
Old 03-10-2015, 11:31 AM   #8327
mvrk28's Avatar
Better off going through your LHS if they can get HB. I have had my caps for a week or two now.
Team Durango DESC10 - Tekin Pro 4 HD 4300, Protek, VRP, Proline, Sanwa
TLR 22t 3.0 - Tekin Gen 3 8.5t, Protek, VRP, Proline, Sanwa
VANT LIPOS
mvrk28 is offline   Reply With Quote
Old 03-10-2015, 12:42 PM   #8328
Originally Posted by Yeti AS3 View Post
Sometimes I wonder if ppl actually read the posts.
Since your post follows mine should I assume it's me you mean? If so, what do you think I missed?
Obviously I read most of them since I agreed with the suggestions about leaving out pins or washers.
-Chris
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 03-10-2015, 01:14 PM   #8329
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
Originally Posted by RC*PHREAK View Post
Got those cheap graphite arm inserts off eBay. Came pretty quick and the fit is perfect:
so hold off on these fellas. second time out with them, the front right insert cracked (was only running them in front). my suggestion would be that if you really want the stiffer inserts, pony up the dough for the HB's.
RC*PHREAK is offline   Reply With Quote
Old 03-10-2015, 01:15 PM   #8330
Originally Posted by boudin4evr View Post
Torrance please any input?
my spring perches keep coming off!
the cup on the shock end!
To keep the spring perch on the rod end! I ran a q and a Main with both front spring perches off! I was gonna super glue but shouldn't have to
I'll post pics tonight
for my ride height, springs aren't that tight or under compression! Yes springs are broken in! I use the HB Gold front and Yellow rear springs
If I remember correctly my ride height is 20mm F and R
this usually happens on the front when the car takes a hit. up front i use the non-shielded spring perches and on the shock end i trim off the locking tabs so that the perches can rotate. this way when the perches lift even momentarily it can easily find its way back onto the eyelet. with locking tabs it's easier to get the perches dislocated.
for the rear i haven't encountered this problem so i use the shielded perches and leave the locking tabs on the eyelet.
Torrance Deguzman
HPI/HB Mechanical Engineer
powered by LRP
T. Deguzman is offline   Reply With Quote
Old 03-10-2015, 02:34 PM   #8331
boudin4evr's Avatar
Trader Rating: 18 (100%+)
thanks! yes it's only on front! Never happened until last weekend!
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 03-10-2015, 02:59 PM   #8332
VegasHB's Avatar
Originally Posted by iScream View Post
I understand how diffs work. I was telling CaseyD that they can't slip on both sides like a ball diff that is too loose.
I was just adding on to your statement, i should have quoted the prior post. Man there's a lot of touchy people in this thread.
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 03-10-2015, 08:28 PM   #8333
No problem. Didn't mean to create the impression that I was mad at you or anything like that.
Hot Bodies D413
AE B5M, T5M
Old 03-11-2015, 05:57 AM   #8334
egobrkr's Avatar
Trader Rating: 26 (100%+)
If you don't use the servo saver do you just use and aluminum horn? I have a losi 22 horn I can use. Do I need to use the losi ball stud or the hot bodies ball stud for the servo link?
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 03-11-2015, 06:08 AM   #8335
Send a message via AIM to trashedmaxx
I had the same issues with my stock cups. I used the guard style and the low style, both fell off. Next step I tried was drilling a small hole in the cup and zip tying the spring to the cup. Worked but annoying to change springs.
I finally just switched to B5 ends and cups and have not had a problem since. And all the slop is removed.
Love the car, has been working great.
Mike Barrett
www.BFastrc.com
www.arcshobbies.com and Raceway
trashedmaxx is offline   Reply With Quote
Old 03-11-2015, 06:50 AM   #8336
Same here except I went with Kyosho ends and cups since I run an RB6 for my 2wd. Still pop them off but not nearly as frequently.
CaseyD is offline   Reply With Quote
Old 03-11-2015, 08:05 AM   #8337
RENOV8R's Avatar
Yes, the Losi horn and the HB ball stud reversed
RENOV8R is offline   Reply With Quote
Old 03-11-2015, 12:28 PM   #8338
Texas Racer's Avatar
I use HB ball caps with HB ball stud. I try to use the kyosho ball caps on the HB
ball stud and its tight..
Texas Racer is offline   Reply With Quote
Old 03-11-2015, 01:14 PM   #8339
Why doesn't Exotek make shock caps they make pretty good products and the demand is there?
Motts97 is offline   Reply With Quote
Old 03-11-2015, 01:56 PM   #8340
tom2tone's Avatar
Trader Rating: 98 (100%+)
What are you guys using to mount your esc's? I've tried my usual Kyosho gel mounting tape and servo tape. The Kyosho tape wouldn't stick to the chassis and the servo tape eventually slides my esc forward. Thanks for any advice!
TEKNO EB48.3 / ET48 / EB410
AE T5M / B6
Tekin / AKA / Hitec / SMC / Futaba
Trains and Lanes Racing http://tandlracing.com/
Dunn Raceway Park http://drprc.com
tom2tone is offline   Reply With Quote
