Like Tree31Likes
Old 03-09-2015, 10:13 PM   #8296
Originally Posted by nitro2be View Post
Even if he put 10,000 in center it would still hall ass.i tested 10,000 and it was ok..now the 500 shock oil would be a problem. .lol.
What about if you accidentally put 3000? That would be like running a completely backed off slipper?
CaseyD is offline   Reply With Quote
Old 03-09-2015, 10:14 PM   #8297
Originally Posted by CaseyD View Post
If your teeth were barely catching and slipping that bad it would sound awful. So I guess the question is how does it sound?
It's my first buggy in years since my B44 but it doesn't sound good. VERY loud gear action like it's skipping but yet it still crawls forward.
dblhelx is offline   Reply With Quote
Old 03-09-2015, 10:18 PM   #8298
Did you put the shims in properly on the cone gear that catches the front and rear diff gears?
Old 03-09-2015, 10:19 PM   #8299
nitro2be's Avatar
I'd bet it still go fast, I run 5k in my nitro center and it has a clutch..lol
nitro2be is offline   Reply With Quote
Old 03-09-2015, 10:20 PM   #8300
It will definitely be louder than your B44 but should be a solid sounding noise not crunchy
Old 03-09-2015, 10:22 PM   #8301
Really? This is my first 4wd and first center gear diff. I just figured 10k and lower would feel like a loose slipper. 100k seems the norm and I think Torrance stated if there was a big quad he would throw 300k in there.
Old 03-09-2015, 10:23 PM   #8302
nitro2be's Avatar
Now we're getting some where..1st post , VERY LOUD GEAR NOISES would of helped..lol..how's your plastic spur gear look..stripped? You need to turn your diffs by the out drives and see if smooth.
Old 03-09-2015, 10:26 PM   #8303
Plastic gear is still perfect.
Old 03-09-2015, 10:27 PM   #8304
nitro2be's Avatar
this is my 1st 1/10 electric car and I was shocked that u guys run 100k and up..but have to say 100k kicks ass in this car..my nitro is ran on loose out door track and anything 10k or higher makes car to squirrelly
Old 03-09-2015, 10:30 PM   #8305
Gotcha. Surprising to hear that such heavy cars run such light oil. I believe Ty went up to 10k in is front diff for Reedy!!
Old 03-09-2015, 10:31 PM   #8306
nitro2be's Avatar
Then must be in front or rear diff.you said center already checked. Shims won't be your problem. Those shims so small just prevents long term wear..must disassemble front and rear diffs and when assembly make sure it turns smooth before installing.
Old 03-09-2015, 10:34 PM   #8307
nitro2be's Avatar
There are 4 washers, not shims that go behind each of the 4 spider gear to make proper mesh.those are important .you may be right casey
Old 03-09-2015, 10:38 PM   #8308
nitro2be's Avatar
look at ty's nitro d812 set up.center probably 10k or 15k at most..mugen set up is 7k 7k 3k
Old 03-09-2015, 10:40 PM   #8309
only if both front and rear are messed up though. He said it barely crawls forward, even if one diff was working correctly it would seem like it had some power. The other diff would have to be working as a brake and that would be pretty obvious with the wheels not wanting to move. Seems more center issue to me. I don't know, just trying to throw some ideas out there. I would have already thrown the buggy across the back yard!!!
Old 03-09-2015, 10:43 PM   #8310
Yea you're right, 10k in his D8T at nitro challenge.
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
2004hdfxsti
