Like Tree42Likes
Old 03-09-2015, 10:36 PM   #8281
ProfessorX's Avatar
Trader Rating: 17 (100%+)
I'm so freaking frustrated I can't believe I got a bad shock cap that wasn't threated all the way in
ProfessorX is offline   Reply With Quote
Old 03-09-2015, 10:40 PM   #8282
Originally Posted by nitro2be View Post
Photos would help, u even have me stumped..bet it's something simple. New motor, esc ,and controller?
Photos of what? Whatever I can do to help you all help me.
dblhelx is offline   Reply With Quote
Old 03-09-2015, 10:41 PM   #8283
nitro2be's Avatar
Originally Posted by Sofa King View Post
Do all 4 wheels turn the same direction if you give it throttle off the ground?
Good question, possibly one diff backwards. Easy mistake for newbies
nitro2be is offline   Reply With Quote
Old 03-09-2015, 10:41 PM   #8284
Yes, sir. The vehicle moves forward. Just slowly. Very.
Old 03-09-2015, 10:44 PM   #8285
You said that the tires balloon when holding it in the air... are the tires all turning the same direction when they are ballooning?
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 03-09-2015, 10:53 PM   #8286
What weight diff fluid did you put in the center diff?
CaseyD is offline   Reply With Quote
Old 03-09-2015, 10:54 PM   #8287
Just checked. Pull the trigger while holding car in the air and all four tires turn in the same direction.
Old 03-09-2015, 11:00 PM   #8288
nitro2be's Avatar
The car, we need to see if something backwards or would bind causing car to move slow. Photo front rear and top center if u can.is your pinion gear tight? Also if your electronics are all new u need to do set up processes.
Old 03-09-2015, 11:03 PM   #8289
So with no resistance the tires balloon and then on the ground with resistance it barely moves. And you're sure you put 100,000 and maybe didn't put lighter fluid in the center allowing it to slip way more than its supposed to?
Old 03-09-2015, 11:06 PM   #8290
Are all the pins in the hexes?
Old 03-09-2015, 11:07 PM   #8291
nitro2be's Avatar
Even if he put 10,000 in center it would still hall ass.i tested 10,000 and it was ok..now the 500 shock oil would be a problem. .lol.
Old 03-09-2015, 11:07 PM   #8292
mattchis's Avatar
My guess you forgot the drive pins
mattchis is offline   Reply With Quote
Old 03-09-2015, 11:07 PM   #8293
Yep! Exactly.
Any chance I just need to shim inside the diff to bring gear mesh closer/tighter?
Old 03-09-2015, 11:11 PM   #8294
If your teeth were barely catching and slipping that bad it would sound awful. So I guess the question is how does it sound?
Old 03-09-2015, 11:12 PM   #8295
nitro2be's Avatar
Yep! Exactly.
no, some are running without shims to quite gear noise down..I've done both and decided to leave the stock shims in..are u hearing any odd sounds?
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
gforcebandit, Robbob
