Like Tree28Likes
Old 03-09-2015, 06:42 AM   #8251
boudin4evr's Avatar
Trader Rating: 18 (100%+)
my car ran fine AGAIN this weekend
2 questions: Are you guys using a tiny bit of loctite on screws that go through arm mounts
also
never had this happen 'til this weekend; my front spring perches come off of shock ends (like there is not enough tension holding or pushing down from the springs to keep it in place)
anybody ran into this? might just glue them BUT I think that is unnecessary
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 03-09-2015, 06:50 AM   #8252
Originally Posted by billdogg View Post
I know this isn't D413 specific, but I'll throw it out there. I run a Savox 2274 in my D413. I've noticed there's a lot more resistance when turning the servo by hand (no power to it) than my other Savox servos. 1257, and 1258. I first noticed it when turning the wheels by hand, but then disconnected the servo arm to rule out binding in the steering. I don't remember it being so tight when I bought it new. I send an email out to Savox as well, but thought I might get a quicker response here.
I run the same 2274 and it feels the same way. Does not seem to be an issue, just the way it feels. If you are used to the servos on 1/8 scale, then part of it is the different geometry of the 1/10 scale. Not as much leverage to the servo horn.
ramctd is offline   Reply With Quote
Old 03-09-2015, 07:23 AM   #8253
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
also
You can loctite the front screws as they thread into alum.
I only had a cup come off a cpl times but its good now. I bend about the last 1/4 inch of the spring coil inward to where it fits the cup tight. Sometimes I have to orientate it so the end of the spring falls into the cup on the slot if I over bend it. I also did this on my rb5 long ago.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 03-09-2015, 07:34 AM   #8254
boudin4evr's Avatar
Pic? I dont have my car in front of me
trying to visualize!
Marc Richard
Old 03-09-2015, 07:38 AM   #8255
Default Schelle Chassis
I am lookng for some first hand feedback on the Schelle chassis. was wondering if it would help outdoors in med to med/low dirt tracks. any feedback even on indoor tracks would be helpful. thanks
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 03-09-2015, 07:55 AM   #8256
Yeti AS3's Avatar
A little bend and the spring should snap onto the cup or be a tight push fit. A pair of good needle nose pliers is all it takes.
Hot Bodies D413 1/10 4WD Buggy-d413-spring.jpg
Hot Bodies D413
AE B5m
Old 03-09-2015, 08:03 AM   #8257
Trader Rating: 130 (100%+)
Randy, I have the schelle chassis installed at the moment and buggy drives much better outdoors on a med bit track. I am running the buggy this weekend on a high bit track. will update at some point next week
skyline1015 is offline   Reply With Quote
Old 03-09-2015, 08:40 AM   #8258
is this to keep the spring on the cup or the cup on the shock end? My son and I constantly are popping the spring cups completely off the car, no lie, every race night or practice day, we are out there looking for a spring cup at least once each. Matter of fact Saturday, ran almost the entire main missing a front spring cup. I even have tried a little super glue to keep it in place and still have lost them.
CaseyD is offline   Reply With Quote
Old 03-09-2015, 08:56 AM   #8259
I put on the Exotek spring cups early on and have not had any issues with them coming off. They fit very tight.
Old 03-09-2015, 09:24 AM   #8260
Yeti AS3's Avatar
I think you will find it helps a lot. If your are going to bump something enough to pop the cup of the eyelet, it won't fall of the spring. It has a better chance of finding its way back on the eyelet too.
Hot Bodies D413
AE B5m
Old 03-09-2015, 09:24 AM   #8261
boudin4evr's Avatar
the cup on the shock end!
To keep the spring perch on the rod end! I ran a q and a Main with both front spring perches off! I was gonna super glue but shouldn't have to
I'll post pics tonight
for my ride height, springs aren't that tight or under compression! Yes springs are broken in! I use the HB Gold front and Yellow rear springs
If I remember correctly my ride height is 20mm F and R
Marc Richard
Old 03-09-2015, 09:28 AM   #8262
nitro2be's Avatar
I remember reading the cups that have the guards do that a lot..put standard cups on it not already
nitro2be is offline   Reply With Quote
Old 03-09-2015, 09:50 AM   #8263
nitro2be's Avatar
[QUOTE=snwchris;13894168]I believe that mainly from the shorter chassis. The Schelle chassis was made to help eliminate that and from what I've seen at our track and tried out a couple of the 413s with the Schelle chassis you can definitely be a little harder on it in the corners and sweepers.
I run 2015 reedy..ierc track.im using black rear sway instead of ty's copper and front hubs 1mm spacer top and bottom because I don't understand the effect of raising and lower front hubs yet.spring are stock but do have red fronts and gold rears..
Old 03-09-2015, 11:31 AM   #8264
I run kyosho shock ends and cups in the front now. Still popping them off. I guess next thing Ill do is JB Weld. J/K
Old 03-09-2015, 12:40 PM   #8265
nitro2be's Avatar
Or exotek
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
