Like Tree31Likes
Old 03-05-2015, 07:29 PM   #8206
nitro2be's Avatar
Originally Posted by ironzgti35 View Post
Just installed my aluminum shock caps and don't like the tilt of the shock when everything is tightened down. Seems like the mount needs to be spaced out a couple mm. Rears mount up fine but the fronts don't look right. Are you guys having similar issues?
I'll be mounting mine in few minutes, I'll let u know what I think
nitro2be is offline   Reply With Quote
Old 03-05-2015, 07:39 PM   #8207
nitro2be's Avatar
I mounted mine, looks good and better than the b5 caps.i do see what your talking about.i could see adding a shim help a little..but does line up top to bottom well just not perfect at the cap and stand off.
Old 03-05-2015, 07:49 PM   #8208
ironzgti35's Avatar
Trader Rating: 20 (100%+)
It doesn't bind through the travel but the caps don't have any wiggle under tension. I may just find a longer screw and space it out a little further. Also noticed you can't get a wrench on the nut once mounted since the cap so close to the nut
HB Racing Proline Sweep Racing USA - PT RC Racing Oils
ironzgti35 is offline   Reply With Quote
Old 03-05-2015, 08:19 PM   #8209
nitro2be's Avatar
Just back nut off little so it can wiggle, and mount top 1st then bottom so u can get wrench on..I'm using a flanged nut so little easier and looks clean
Old 03-05-2015, 09:03 PM   #8210
tom2tone's Avatar
Trader Rating: 98 (100%+)
Just got my aluminum caps mounted and I see what you guys are talking about as well. They do seem to be angled on the top but doesn't affect anything. Look ok to you guys?
TEKNO EB48.3 / ET48
AE T5M / B6
Tekin / AKA / Hitec / SMC / Futaba
Trains and Lanes Racing http://tandlracing.com/
Dunn Raceway Park http://drprc.com
tom2tone is offline   Reply With Quote
Old 03-05-2015, 09:11 PM   #8211
That's how most shocks look. My rb6 looks just like that at all 4 corners. I'm sure under the stock ball cup they aren't perfectly straight either. Those look super clean though.
CaseyD is offline   Reply With Quote
Old 03-05-2015, 09:23 PM   #8212
nitro2be's Avatar
Talking
oh yea i like. buggy looks $$$ now.
Hot Bodies D413 1/10 4WD Buggy-20150305_210101_resized.jpg   Hot Bodies D413 1/10 4WD Buggy-20150305_210243_resized-2-.jpg
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
Old 03-05-2015, 09:37 PM   #8213
nitro2be's Avatar
Wait, I believe yours screws are backwards. Nut goes to outside. That's how my 1/8 buggy are.
Old 03-05-2015, 09:40 PM   #8214
Originally Posted by nitro2be View Post
Wait, I believe yours screws are back words. Nut goes to outside. That's how my 1/8 buggy are.
You are correct, the mount screw is backwards. Probably makes no difference at all. Just will make it more of a pain to remove and replace shocks.
ramctd is offline   Reply With Quote
Old 03-05-2015, 10:54 PM   #8215
ISH
ISH's Avatar
call me crazy but i think this looks cleaner. i hope amain gets these in stock soon.
MBX7R nitro
Hot Bodies D413
B5M-FL
T5M
Team Orion, Nova Rossi, SMC, MIP, Airtronics, KO-PROPO.
ISH is offline   Reply With Quote
Old 03-06-2015, 04:22 AM   #8216
egobrkr's Avatar
Trader Rating: 26 (100%+)
So to the guys using the B5 shock caps how have they been holding up? The are more accessible then the aluminium caps from hotbodies.
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 03-06-2015, 05:21 AM   #8217
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
B5 caps work great. They are about a mm or so shorter so just unscrew the eyelet to make up for it.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 03-06-2015, 05:21 AM   #8218
RENOV8R's Avatar
Needs orange wheel nuts
RENOV8R is offline   Reply With Quote
Old 03-06-2015, 05:36 AM   #8219
ironzgti35's Avatar
Is that the Sworkz wing? Mine should be shipping out today but I'm thinking about trimming the wicker bill area down like a traditional wing, looks too boxy
Old 03-06-2015, 06:16 AM   #8220
Send a message via AIM to trashedmaxx
I thought about doing that myself with mine. But in my opinion the the wing is pretty flexible. So cutting the wicker down would make that worse. What I did was cut it about halfway then put a few reamed holes in the wicker bill.
Mike Barrett
www.BFastrc.com
www.arcshobbies.com and Raceway
trashedmaxx is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
