Like Tree42Likes
Old 03-05-2015, 01:20 PM   #8191
Looking into getting a 4wd buggy between this and a xray xb4. Reading through this thread and looking to purchase it seems that there is a major supply issue with part as well as kits for hotbodies is this common?
Motts97 is offline   Reply With Quote
Old 03-05-2015, 02:02 PM   #8192
tom2tone's Avatar
Trader Rating: 98 (100%+)
Originally Posted by boudin4evr View Post
what i'm hunting for is the aluminum shock caps set
They are in stock on stormer....
http://www.stormerhobbies.com/cgi-bi...=&pn=HOT114112
TEKNO EB48.3 / ET48 / EB410
AE T5M / B6
Tekin / AKA / Hitec / SMC / Futaba
Trains and Lanes Racing http://tandlracing.com/
Dunn Raceway Park http://drprc.com
tom2tone is offline   Reply With Quote
Old 03-05-2015, 02:27 PM   #8193
ironzgti35's Avatar
Trader Rating: 20 (100%+)
With the Sworkz wing, can you get the predrilled version or do the holes no line up?
HB Racing Proline Sweep Racing USA - PT RC Racing Oils
ironzgti35 is offline   Reply With Quote
Old 03-05-2015, 02:32 PM   #8194
I got the no holes and drilled where I want. Don't know if the pre-drilled will line up. I kind of doubt it.
ramctd is offline   Reply With Quote
Old 03-05-2015, 02:34 PM   #8195
boudin4evr's Avatar
Trader Rating: 18 (100%+)
Originally Posted by tom2tone View Post
thanks
I've never ordered from Stormer! They are on the way!
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 03-05-2015, 02:54 PM   #8196
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Yes
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 03-05-2015, 03:26 PM   #8197
thanks
I have ordered numerous things from Stormer with no issues.
Old 03-05-2015, 03:47 PM   #8198
ISH
ISH's Avatar
it is an issue currently for a few reasons. i don't think parts will continue to be on back order too much longer. back in dec i went down to the hobby shop and without hesitation got front shock supports and shock shafts. should be getting better soon.
MBX7R nitro
Hot Bodies D413
B5M-FL
T5M
Team Orion, Nova Rossi, SMC, MIP, Airtronics, KO-PROPO.
ISH is offline   Reply With Quote
Old 03-05-2015, 05:46 PM   #8199
can someone take a picture of there aluminum shock caps installed. I think i know how they are installed but was just making sure i had the plastic bushings in the right spot up against the shock cap and the nut hold them against it. aswell as the placement of the washer. just wanted to make sure i install it right being no manual. thanks
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 03-05-2015, 06:08 PM   #8200
nitro2be's Avatar
I have mine on at home.but u do want the flat part facing out where then washer and nut contact. Just like my 1/8 scale buggy
nitro2be is offline   Reply With Quote
Old 03-05-2015, 06:21 PM   #8201
Thanks guys this could be an issue that would have me looking else where, I'll keep my eye on it for a little before I jump the gun because I know there was an issue with the dock workers in California thanks again
Old 03-05-2015, 06:56 PM   #8202
ironzgti35's Avatar
Just installed my aluminum shock caps and don't like the tilt of the shock when everything is tightened down. Seems like the mount needs to be spaced out a couple mm. Rears mount up fine but the fronts don't look right. Are you guys having similar issues?
Old 03-05-2015, 07:15 PM   #8203
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
thanks. i know bob will deliver what i order. unlike philscraphobbyshop.
RC*PHREAK is offline   Reply With Quote
Old 03-05-2015, 07:23 PM   #8204
they do not
Sofa King Racing
Sofa King is online now   Reply With Quote
Old 03-05-2015, 08:09 PM   #8205
Send a message via AIM to trashedmaxx
Originally Posted by Sofa King View Post
they do not
Thanks for the info. I have been running the nondrilled with very good luck. But they are always out of stock, the black nondrilled.
Mike Barrett
www.BFastrc.com
www.arcshobbies.com and Raceway
trashedmaxx is offline   Reply With Quote
