Like Tree42Likes
Old 03-04-2015, 09:20 PM   #8161
Originally Posted by bladeys View Post
What tooth is the spur/pinion. Waiting for my buggy to come from Tower.
I just want to be sure, 48 tooth?
bladeys is offline   Reply With Quote
Old 03-04-2015, 09:28 PM   #8162
Ok the spur is a 72 tooth spur. The pinion is a 48 Pitch and I use a Robinson 23 Tooth 48 Pitch steel pinion from Avid with Tekin 6.5 Turn motor. I think there is a pinion chart on the first page of the thread.
http://avidrc.com/product/5/accessor...cessories.html
ramctd is offline   Reply With Quote
Old 03-04-2015, 09:34 PM   #8163
Thanks.
Old 03-04-2015, 11:01 PM   #8164
Originally Posted by billdogg View Post
What did you drill and tap into for the wing? I wanted to do this, but there's not much meat where the post is.
As stated above I am using the Exotek wing mount and wing buttons. Quality, function and pretty bling.
Old 03-04-2015, 11:18 PM   #8165
Sorry for the dumb question here but i'm new to the 1/10th electric buggy world I run 1/8 nitro and just got a D413 to race at a new indoor track that's going in here locally.
I've been looking at motors and ESC's and don't really know what to go with I was looking at going with one of the castle combo kits but i don't really know which one to choose. Any have any ideas of what else i should run? I'm not a pro level driver heck i'm not even a good novice driver to be honest i suck! I have fun though I just want to make sure that if i do want some power i can have it.
OKCIS is offline   Reply With Quote
Old 03-04-2015, 11:43 PM   #8166
ISH
ISH's Avatar
my recommendations for ESC would be hobby wing. or LRP. depending on budget.
smc has a good inexpensive hight spec ESC too. personally i run the orion10.1 in my D413. motors you can really go wrong with most brands.
MBX7R nitro
Hot Bodies D413
B5M-FL
T5M
Team Orion, Nova Rossi, SMC, MIP, Airtronics, KO-PROPO.
ISH is offline   Reply With Quote
Old 03-05-2015, 01:28 AM   #8167
mvrk28's Avatar
With the addition of the Exotek spring perches and the HB shock caps I decided it was time to add a few more goodies. I keep a few sets of a arms on hand so I ordered the carbon inserts, gold and yellow HB springs and VRP "X Pistons." I also fit her up with the RC Shox Ackerman, looking forward to seein the differences from these changes.
I'm going to glue my inserts, it looks like TY runs glued inserts almost exclusively.
Also thinking about a Tenshock x211 6.5 4 pole, they're on sale for $45 and I'm tempted, anybody run one yet?
In other news my charger and power supply showed up today! Hitec 30a w/ Hitec X2 ultima. I don't dharge above 10 amps so this combo should be just right.
Team Durango DESC10 - Tekin Pro 4 HD 4300, Protek, VRP, Proline, Sanwa
TLR 22t 3.0 - Tekin Gen 3 8.5t, Protek, VRP, Proline, Sanwa
VANT LIPOS
mvrk28 is offline   Reply With Quote
Old 03-05-2015, 01:43 AM   #8168
Im looking for a stiffer spring.. currently running the HB reds all around is there stiffer ones out there ?
Monkey#39 is offline   Reply With Quote
Old 03-05-2015, 01:44 AM   #8169
mvrk28's Avatar
Check the first post it lists springs
VANT LIPOS
Old 03-05-2015, 01:51 AM   #8170
mvrk28's Avatar
Cancelled my spring order just saw that those were the standard rate.
VANT LIPOS
Old 03-05-2015, 03:25 AM   #8171
Xray 3 dot front and kyosho orange rear. Good combo if you want stiff
ColourGhost is offline   Reply With Quote
Old 03-05-2015, 04:23 AM   #8172
Maybe a little bit offtopic..but does it make more sense to buy a 1:10th scale HB D413 or to convert a 1:8th HB D812 to electric? Hometrack is med. size & designed for 1:8th
G-M. is offline   Reply With Quote
Old 03-05-2015, 05:25 AM   #8173
snwchris's Avatar
They are entirely two different cars, so it depends on what you want to race and the type of turn out at your track for the class. In the end both will cost some coin for finish product, it mainly depends on what you want to race.
I race both 1/10 4w Buggy and 1/8 E-buggy on both 1/8 sized tracks and also 1/10 sized medium tracks.
snwchris is offline   Reply With Quote
Old 03-05-2015, 05:29 AM   #8174
snwchris's Avatar
As for ESC I would get the HW 120A V2.1 (its about $80) and then would go with a HW Motor or a SMC Motor ($65 to $80).
As for motor turn or size, I would recommend getting a 7.5T, since new to 4w Buggy. It has plenty of grunt for most sized tracks. I run one in mine and works good when I go to bigger tracks as well.
Old 03-05-2015, 06:25 AM   #8175
RENOV8R's Avatar
Originally Posted by ramctd View Post
Well I only used the stock wing mounts for one day, so don't have a good comparison. I do know that the other D413 drivers here kill wings at a pretty good rate with the stock setup.
I switched to the sworks wing early on for their durability. I have been running the same one I started with and after 3 race days and 3 practice days it is as good as new. I am upside down more than I like to admit also. This is that wing.
Question. The butons are on top, so obviously the mounts are in the normal position. But it looks like the wing is in the low position with the mounts flipped. Is this just the design of the wing?
RENOV8R is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
