Like Tree28Likes
Old 03-02-2015, 03:02 PM   #8086
nitro2be's Avatar
Originally Posted by VegasHB View Post
Ran my car for the first time this past week and it's my first 4wd buggy ever and I was loving the power, control and overall feel of the car but for one thing....it jumps like a wet pig. I'm so use to my B5M and how it easily clears a triple using an 8.5. My D413 has a 6.5 and the thing is a rocket but I just can't clear this triple even with an all out run at it. Is this typical with 4 wheelers or is my car over dampened?
So, I run 7k, 100k, 5k in the diffs, stock springs, 37.5 front oil and 35 rear with associated 2 hole pistons @ 1.6 and 1.7. I'm assuming there's just not enough "spring" in this car? I don't want to hamper the overall handling just to clear a triple but I wonder if my piston/oil/spring combo is too restricting? I followed Tessmans shotgun shootout setup.
2 degree anti squat the ticket
nitro2be is offline   Reply With Quote
Old 03-02-2015, 03:31 PM   #8087
VegasHB's Avatar
Originally Posted by Stealth_RT View Post
Shock setup looks too soft to me, FWIW. I'm running 2x1.6 HB front pistons, red HB springs, and 550cst PT oil, which is about 42.5 AE oil. Running 2x1.6 HB pistons in the rear also, with 375 PT oil, which is about AE 32.5 with HB gold springs. With 2x1.7 pistons, you're going to have to go even heavier oil, like 37.5 AE. I bet you're car is just bottoming out very hard into the jump face and scrubbing all your speed. Hitting at full throttle will make it worse.
This is probably the case, seems like I carry good speed up to the jump and it just falls on it's face coming off. Rolling onto the throttle nets the same distance as hitting it with a run, tells me i'm scrubbing the speed. Thanks for the feedback, i was looking at going lighter oil for more "bounce" but this makes better sense.
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 03-02-2015, 03:32 PM   #8088
nitro2be's Avatar
A main hobbies front shock towers are in..go go go only 8 left
Old 03-02-2015, 04:51 PM   #8089
Managed to scoop one but I had back orders and got no notifications.
What's the point of a back order if it's first come first served?
GimpyGolden is offline   Reply With Quote
Old 03-02-2015, 05:14 PM   #8090
nitro2be's Avatar
I was notified for my back orders..I think people, not you are getting confused with wish list and back ordering. Back ordering require cc # and process the order.a main has always been good to me on back order's. Glad u got one
Old 03-02-2015, 06:59 PM   #8091
kdeleon's Avatar
For amain, back ordering does not require a credit card, but you do need to complete the order.
I have had two backorders with them, one I got an email and the other I did not. But both times, amain did hold the item even though the site said sold out. For those that did not get notified, just check your back orders and they should be ready for you to check them out and this time you will need to pay for it.
kdeleon is offline   Reply With Quote
Old 03-02-2015, 07:56 PM   #8092
Knate14's Avatar
ok so i'm really thinking about this buggy, xray or kyosho. What options should go on the d413 when building the kit?
my rides; Traxxas Mini E-Revo(what got me started 2 years ago) MUGEN SEIKI; MBX7R, MBX7TR, MTX6, MRX6.
Sponsors MUGEN SEIKI, PROLINE RACING, DIALED IN RC RACEWAY.
Win lose or tie I'll be racing till I die.
Knate14 is offline   Reply With Quote
Old 03-02-2015, 07:57 PM   #8093
Knate14's Avatar
or does it even need any?
Old 03-02-2015, 08:02 PM   #8094
Knate14's Avatar
oh and also are any of you having the diffs leak fluid at all if so what have you done to fix the leak. ant fluid coming out is a leak. Please don't tell me yours only seap a little fluid sometimes and just admit it has a leak.
Old 03-02-2015, 08:10 PM   #8095
nitro2be's Avatar
My diffs have never leaked.
Old 03-02-2015, 08:12 PM   #8096
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
So, I finally got my Exotek Ackerman bar and installed it. Its a quality piece.
-There is zero slop.
-Use a dab of grease to hold the bearing in if they want to fall out during assy.
Somebody said that the rack was binding when screws were tight. I had an idea why even before I got the rack. I was correct and have the fix if you have an issue. The problem is the bearing are supported outer race (installed in the arm) with a .03 gap in between them. When u tighten the screw it pushes down on the top inner race and up on the lower bearing inner race. SO...get yourself six 3x5x.3mm shims (I use Kyosho shims) and use 3 between the bearings in each bore...and tighten away.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 03-02-2015, 08:22 PM   #8097
jhautz's Avatar
Trader Rating: 85 (100%+)
Somebody said that the rack was binding when screws were tight. I had an idea why even before I got the rack. I was correct and have the fix if you have an issue. The problem is the bearing are supported outer race (installed in the arm) with a .03 gap in between them. When u tighten the screw it pushes down on the top inner race and up on the lower bearing inner race. SO...get yourself six 3x5x.03mm shims (I use Kyosho shims) and use 3 between the bearings in each bore...and tighten away.
Yea. That spacer should have been included. I did the same thing as you.added some small shims to prevent the screw pulling the inner bearing race.
jhautz is offline   Reply With Quote
Old 03-02-2015, 08:25 PM   #8098
I too was not notified about the front shock tower mount, checked my back orders and BOOM shippable!
Race Cars:
On Road: 2 Xray T3 2012, Serpent S100, 3Racing F113
Off Road: Tekno ET48, Tekno SCT410, Losi 8 Buggy E 3.0, Losi 22 sct, Losi 22 2.0 buggy, HB D413
seanhawk is offline   Reply With Quote
Old 03-02-2015, 08:30 PM   #8099
Knate14's Avatar
awesome good to know they don't leak if built correctly. Is the car easy to maintain? Looks like it might be a bit tougher to work on than other 4 wheelers.
Old 03-02-2015, 09:34 PM   #8100
nitro2be's Avatar
I've only had 1/8 scale nitro cars that all had gear diffs.to me this buggy eeezzz to work on.
