Like Tree31Likes
Old 03-02-2015, 05:03 AM   #8071
snwchris's Avatar
Yea o-ring, fuel tubing or small washer is best bet
snwchris is offline   Reply With Quote
Old 03-02-2015, 05:31 AM   #8072
What is the measurement of the stock o rings?
mrcjones is offline   Reply With Quote
Old 03-02-2015, 06:39 AM   #8073
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Originally Posted by mrcjones View Post
Does anyone have the part # for the 1mm shock limiter? Also are they aluminum or plastic?
Use .030 or .040" plastic shims from about any car that has a 3mm shock shaft. Guys at the track that have em lying around in their box too.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 03-02-2015, 06:40 AM   #8074
Vinny Cancilla's Avatar
Originally Posted by savageboy69 View Post
Had a race this weekend on a very large,bumpy, loose blown out track and was trying a few different things and one of the things i wanted to try was a longer wheelbase so i cut 3mm off the back of the arm and slid it back on the hingepin and put 3mm of spacers in front of it. It really locked the rear end in and gave me a slight push but was very stable.
Longer wheelbase frees up the rear, but makes it more stable through the bumps.
Serpent Srx8
Serpent America: Triton engines/ Nitro pro.Fuel/ Rc Addiction products : Vp pro Usa/Dialed-Rc
Barnstormers: Chester, NY, N.Y.. IRH Lindenhurst
Vinny Cancilla is offline   Reply With Quote
Old 03-02-2015, 06:56 AM   #8075
ISH
ISH's Avatar
Originally Posted by nitro2be View Post
Ierc
Do they stock Hot Bodies parts now that they signed Tessmann?
MBX7R nitro
Hot Bodies D413
B5M-FL
T5M
Team Orion, Nova Rossi, SMC, MIP, Airtronics, KO-PROPO.
ISH is offline   Reply With Quote
Old 03-02-2015, 07:08 AM   #8076
I was running a 6.5 but traded for an 8.5. Much more control on our tight carpet track.
Running some boost on the 8.5 it has tons of rip. For outdoor big track I might go down to a 5.5/6.5 again, just cause I have no doubt the car will handle it.
GimpyGolden is offline   Reply With Quote
Old 03-02-2015, 07:09 AM   #8077
I use either Associated O-rings I had tons of or the plastic spacers that come in the Traxxas shock rebuild kit with their Blue X-rings.
Old 03-02-2015, 07:22 AM   #8078
Thanks, I was going to use associated plastic shims but they seem like they are just a touch to big on the shaft and can get angled on the shaft and bind.
Old 03-02-2015, 09:30 AM   #8079
MasiisaM's Avatar
ran the car over the weekend with the Exotek machined spur and mounting plate and this is by far the best update i have found for the car.
Fitment is perfect on the dif housing and the spur is completely round. I no longer have high and low spots to set the mesh.
On the stocker I had to set the mesh using the low spots which made it a bit tight on the high spots. My temps were in the low 170's on my 6.5.
Now they are mid 150's..the car is not as loud..and my packs last a bit longer
Best 20 bucks i have spent.
TLR 22 2.0 - TLR 8E 3.0 - HB D413
Thanks to:
Tekin - www.teamtekin.com
Thunder Designs - www.thunderdesigns.net
MasiisaM is offline   Reply With Quote
Old 03-02-2015, 11:15 AM   #8080
I set my mesh on the high spots from day 1 and never had a issue with it stripping the gear. 6.5t motor and still on the original spur gear. Why would you set your mesh on the low spot?
Serpent Srx8
Old 03-02-2015, 11:26 AM   #8081
MasiisaM's Avatar
for the spur i had the high spot was really small and was too loose for my liking to set for the high.
Thanks to:
Old 03-02-2015, 01:57 PM   #8082
VegasHB's Avatar
Ran my car for the first time this past week and it's my first 4wd buggy ever and I was loving the power, control and overall feel of the car but for one thing....it jumps like a wet pig. I'm so use to my B5M and how it easily clears a triple using an 8.5. My D413 has a 6.5 and the thing is a rocket but I just can't clear this triple even with an all out run at it. Is this typical with 4 wheelers or is my car over dampened?
So, I run 7k, 100k, 5k in the diffs, stock springs, 37.5 front oil and 35 rear with associated 2 hole pistons @ 1.6 and 1.7. I'm assuming there's just not enough "spring" in this car? I don't want to hamper the overall handling just to clear a triple but I wonder if my piston/oil/spring combo is too restricting? I followed Tessmans shotgun shootout setup.
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 03-02-2015, 02:34 PM   #8083
boudin4evr's Avatar
Trader Rating: 18 (100%+)
I have a 6.5 also and can jump what my 1/8 scales do just about! Are you rolling onto throttle? Gearing?
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 03-02-2015, 02:39 PM   #8084
Shock setup looks too soft to me, FWIW. I'm running 2x1.6 HB front pistons, red HB springs, and 550cst PT oil, which is about 42.5 AE oil. Running 2x1.6 HB pistons in the rear also, with 375 PT oil, which is about AE 32.5 with HB gold springs. With 2x1.7 pistons, you're going to have to go even heavier oil, like 37.5 AE. I bet you're car is just bottoming out very hard into the jump face and scrubbing all your speed. Hitting at full throttle will make it worse.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 03-02-2015, 02:46 PM   #8085
nitro2be's Avatar
Not yet, I was told soon.
nitro2be is offline   Reply With Quote
