Like Tree28Likes
Old 02-28-2015, 08:39 AM   #8041
Look just below the hpi spring rates on the first page. They have links in blue the bottom one is a spring rate chart for all big bore buggy springs.
slasn_48 is offline   Reply With Quote
Old 02-28-2015, 09:05 AM   #8042
Originally Posted by boudin4evr View Post
2 questions
can somebody measure the steering link center to center on the servo
also
who if anybody is using the Schelle racing +4mm carbon chassis?
If so, on what surfaces pros and cons
thanks
I didn't dig out my calipers but from the center of the servo saver ball stud to the center of the steering link ball stud is very close to 25mm.
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 02-28-2015, 01:48 PM   #8043
snwchris's Avatar
Didn't need front shock shafts but since found a place that had some I ordered a set Thursday afternoon and got them this morning.
snwchris is offline   Reply With Quote
Old 02-28-2015, 03:03 PM   #8044
mvrk28's Avatar
I've been stockpiling as many stock parts as possible, too.
Team Durango DESC10 - Tekin Pro 4 HD 4300, Protek, VRP, Proline, Sanwa
TLR 22t 3.0 - Tekin Gen 3 8.5t, Protek, VRP, Proline, Sanwa
VANT LIPOS
mvrk28 is offline   Reply With Quote
Old 02-28-2015, 10:09 PM   #8045
tom76's Avatar
Trader Rating: 30 (100%+)
Is anyone having issues with shorty packs puffing at all? I have a 6.5t motor no name brand and a hobbywing 3.1 esc. Another mate at the track is getting the same issue. Motor got to about 75c deg today in + 30c deg weather temp in sydney. The esc is ok there is no heat there.
Cheers.
St Ives - Sworkz / XB4 17 / XB2
tom76 is offline   Reply With Quote
Old 03-01-2015, 05:18 AM   #8046
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
What motor, batts, and gearing? I have zero issues with an orion 6.5 and nano-tech batts.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 03-01-2015, 06:14 AM   #8047
RENOV8R's Avatar
So your mate is also having this issue with the same battery? What is the C rating?
RENOV8R is offline   Reply With Quote
Old 03-01-2015, 07:44 AM   #8048
Default Sway Bars
I need some heavier sway bars for my carpet setup.
I've read in here some have used Serpent 1/8 car ones in 1.8 and 2.0mm. Anyone know off hand which Serpent 811 Buggy they are from?
GimpyGolden is offline   Reply With Quote
Old 03-01-2015, 09:42 AM   #8049
Suspended
Or, you could get some music wire from just about any hobby shop, and use some vice grips to bend your own. Most hobby shops have a display from K&S Metals with a bunch of different size music wire. Google K&S metals, look on their site to see what size the wire is. Use a conversion site to figure out what the wire size is in mm. Go get some wire of the sizes you want. Bend up some sway bars of your own. Instead of ordering what you hope is the right part and having to wait, you can make your own, and have it today (if you LHS is open on Sunday).
Mantis Toboggan is offline   Reply With Quote
Old 03-01-2015, 09:56 AM   #8050
Nitro and the be use the same sway bars.
turtle189 is offline   Reply With Quote
Old 03-01-2015, 10:24 AM   #8051
Ya, already looked. No dice. If I need them to order it it'd be quicker and easier to order some Serpent ones myself.
Old 03-01-2015, 10:29 AM   #8052
Thanks, there's a few different listed for 811.
By the pic I think these will do with a little tweaking
http://www.amain.com/serpent-2.0mm-r...ll-bar/p206563
http://www.amain.com/serpent-1.8mm-r...ll-bar/p206562
Old 03-01-2015, 01:53 PM   #8053
Those are the correct parts. You will have to bend them to generally match the D413 sway bars then cut them to the right length.
Be sure to bend one for the front and one for the back since they aren't the same.
Here's a 1.8 bent 99 percent correct and marked for the dremel cutoff wheel.
And ready to go.
Hot Bodies D413
AE B5M, T5M
Old 03-01-2015, 02:45 PM   #8054
bhambrent's Avatar
Can someone post pictures of the HB shock caps? Thanks
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 03-01-2015, 02:59 PM   #8055
HPI Racing?
Sofa King Racing
Sofa King is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
