Like Tree28Likes
Old 02-25-2015, 03:31 AM   #7951
Trader Rating: 89 (100%+)
Originally Posted by ColourGhost View Post
Sorry. Emulsion. Bladder is 100% impossible to build without rebound on these. I have build other shocks without any issues, but these shocks don't last more than a few hours before they have build up to 100% rebound. If i go with Kyosho X- rings they are really smooth, but build up 100% rebound within one hour of training. This is a big problem for me, and i'm having a real hard time believing no one else is producing rebound at least after a whole day of training. I cant make these shocks "all dead" - either they suck in or rebound like hell.
I guess I will have to check mine after a few runs.? This shock design has been around for a long time.... What if after you run and the rebound returns you release that extra pressure? By cracking open the bleed screw.
dan-o is offline   Reply With Quote
Old 02-25-2015, 03:45 AM   #7952
Vinny Cancilla's Avatar
Originally Posted by CaseyD View Post
I'm using these as well but I'm building up quite a bit of rebound. (Emulsion). I originally added a .5mm spacer inside the cartridge and it felt tight but I may end up putting it back to see how it feels again.
I'm using emulsion with 1mm limiters front and rear.
Serpent Srx8
Serpent America: Triton engines/ Nitro pro.Fuel/ Rc Addiction products : Vp pro Usa/Dialed-Rc
Barnstormers: Chester, NY, N.Y.. IRH Lindenhurst
Vinny Cancilla is offline   Reply With Quote
Old 02-25-2015, 04:04 AM   #7953
I let the air out every 1-2 hour. I run 3 limiter inside front, and 2mm inside rear. I can build Xray xb4 or kyosho rb6 with no problems, but the HB D413 is a no go for me. Other shocks you can build "dead" - no shaft movement up and down. My experience with these are that you can start with no rebound, and the shaft get sucked in almost all the way, and after 2 hours of racing it's the other way around , -they come out pretty fast when removing the spring.
ColourGhost is offline   Reply With Quote
Old 02-25-2015, 05:07 AM   #7954
snwchris's Avatar
I just rebuilt my emulsions last week and that was after running them for 3wks. They had zero rebound and did not suck in either. I'm knidof curious when I get home tonight to check and see how they are.
snwchris is offline   Reply With Quote
Old 02-25-2015, 05:21 AM   #7955
Trader Rating: 54 (100%+)
I have the Exotek rack my slop is completely gone in the steering rack. It replaced the rcshox version.... I also have the exotek center diff cap, being made of aluminum is WAY better than stock. You don't have to worry about the screws literally pulling completely through the holes like on the thin stock plastic cap when you tighten it down.
AE RC8B3.1E |Xray XB2 CE|Sanwa M12|MKS Servos
Yodah is offline   Reply With Quote
Old 02-25-2015, 05:55 AM   #7956
ironzgti35's Avatar
Trader Rating: 20 (100%+)
Most of the slop in mine seems to be in the rod ends and spindles, not the rack.
HB Racing Proline Sweep Racing USA - PT RC Racing Oils
ironzgti35 is offline   Reply With Quote
Old 02-25-2015, 06:32 AM   #7957
Originally Posted by ISH View Post
wow
dare i say that the rc shocks rack might take up more of the slop than this.
Not in my experience. The RCShox ackerman bar removed as much as can be removed from replacing the bar but still left a significant amount of slop.
The rest of the slop up front seems to come from the loose fitting ball cups, loose caster/steering block bushings and loose fitting front axles.
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 02-25-2015, 07:02 AM   #7958
Well you must be the worst most dumb driver out there, according to half of this post that part never breaks and if it does just use google dumba$$.
This was said with the utmost sarcastic intent.
But you're not bitter, right?
I made it through another day of racing Sunday, complete with some traction rolls that made the buggy tumble, a couple head on bumps into pipes and boards, and being hit from just about every possible angle by aggressive drivers. Managed to pop a shock off the tower once and pop ball cups off twice.
I must be the best smartest crasher out there to not break such a fragile part as the tower brace.
This was said with a little sarcasm but mostly good humor and I was smiling while I typed it. See, here's a nodding smiley face to prove it.
Hot Bodies D413
AE B5M, T5M
Old 02-25-2015, 07:03 AM   #7959
I'm curious about what made you want to replace the RCShox ackerman bar. I'm really happy with mine.
Hot Bodies D413
AE B5M, T5M
Old 02-25-2015, 07:08 AM   #7960
just ordered the exotek rack. i will compare maybe even do a video.
I'm still trying to figure out how to quiet down this car. any ideas?
Maybe try the Extock spur gear/diff cap, I've not got a D413, but found most of the noise of my old Durango 410 came from the spur gear, not all of the std ones were round, swapped to a machined RW or RDRP one & it was a lot quieter, might be the same for the D413.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 02-25-2015, 07:24 AM   #7961
VegasHB's Avatar
Finally finished my 413. Spent too much time trying to wire it up nicely. The receiver always looks a mess so I made a plastic cover out of a product package and some velcro, added some carbon decal lipstick. Paint job was terrible but I dressed it up with some graphics i got off the kit box and printed to vinyl. Finished it up with a matte finish using Valspar glass frost spray to hide my terrible paint job overall. The ebay special heat sink on the motor actually works great and fits perfect using the proline body.
Used B5 ball cups everywhere, just one less part I need to worry about carrying in stock and they fit great with less slop overall.
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 02-25-2015, 07:26 AM   #7962
RENOV8R's Avatar
I ordered the Exotec strictly for the bling. No comparison. the RCShox is very functional, just looks like somebody sat on a stump and carved it out with a pocket knife. Also don't like the way the holes for the balls are recessed and only has one bearing per side.
RENOV8R is offline   Reply With Quote
Old 02-25-2015, 09:08 AM   #7963
muggy427's Avatar
Dude I even re read that post how did you think I was being serious? I've been the one defending all of us that have broken the front shock mount and can't find it.
i found 2 in my pit bag
muggy427 is offline   Reply With Quote
Old 02-25-2015, 09:36 AM   #7964
Moderator
bds81175's Avatar
I'll give you......$1,000,000 for one of them.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 02-25-2015, 09:59 AM   #7965
boudin4evr's Avatar
Trader Rating: 18 (100%+)
my exotek took 98% of steering rack slop out but its in the caster blocks!
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
