Like Tree31Likes
Old 02-18-2015, 05:20 AM   #7801
Tobiasmart's Avatar
Originally Posted by ColourGhost View Post
I removed all slop from mine. Absolutely zero slop left. This is what you need to do.
Buy some Xray 8mm ball ends (XRA362651) 12 pieces , - 8 : Front - 2 : rear - 2 : servo. Bushings - 4 pieces. XRA362290. 2 for the steering blocks and 2 for the Ackerman. These parts are 0.1mm larger then HB.
The bushings fit very tight in the ackerman, but dont worry it works great.
You also need some 1-2mm shims, because the XB4 ball ends are a little shorter, so if you put a 2mm shim on the steering ball you have 6mm like HB
To begin with it all is a little tight, but it will loosen up after a few hours.
When i drop mine, the sound it makes when it lands is niiiice. Dosnīt sound like dropping a bag of empty cans anymore, more like a BMW door closing.
I felt the car became a little more responsive, but also a little more predictable. I also think the slop is positive when it comes to durability. I prefer zero slop. F....... hate slop.
Enjoy
Forgot. Also put a 5x7x0,2mm (or 0,1mm) shim behind the Hex hubs. No more slop, and no more pins falling out
I can recommend the X-ray bushings as well! A lot easier to set camber without that slop. But instead of using bushings in the ackerman bar, you can buy 4 flanged bearings 3x6x2,5mm and drill the hole with a 6mm bit. butter smooth and slop free steering forever! And cheaper than X-ray bushings.
Cars: HB D413 - HB D815e - HB D815 - Mugen MBX7
Electronics: REDS - Hobbywing - Savöx - Viper - Sanwa
Tobiasmart is offline   Reply With Quote
Old 02-18-2015, 07:02 AM   #7802
Looks like some nice new bits are coming your way soon, almost makes me want one now
http://www.redrc.net/2015/02/exotek-...rs/#more-93133
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 02-18-2015, 08:06 AM   #7803
mvrk28's Avatar
those hexes are going to sell out fast, I just ordered the RC Shox ackerman, wonder what the difference is with the exotek.
Team Durango DESC10 - Tekin Pro 4 HD 4300, Protek, VRP, Proline, Sanwa
TLR 22t 3.0 - Tekin Gen 3 8.5t, Protek, VRP, Proline, Sanwa
VANT LIPOS
mvrk28 is offline   Reply With Quote
Old 02-18-2015, 09:10 AM   #7804
kdeleon's Avatar
The new spur is interesting especially as 13.5t stock class is picking up in certain areas.
kdeleon is offline   Reply With Quote
Old 02-18-2015, 09:22 AM   #7805
snwchris's Avatar
Alum vs Plastic and then price would be the difference.
I do like the option of the clamping hexes.
For the time being I just used a dab of shoe goo across the pin in the hex to keep in place.
snwchris is offline   Reply With Quote
Old 02-18-2015, 10:05 AM   #7806
boudin4evr's Avatar
Trader Rating: 18 (100%+)
I likey!! I just placed my order!
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 02-18-2015, 10:32 AM   #7807
Enjoy
Cool, thanks for the info. I've got some B5 balls and cups that I'll install at some point. And I have some other balls and cups coming in this week to replace my servo saver and link. Could have saved a few bucks doing it your way though.
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 02-18-2015, 10:34 AM   #7808
yes all of the above please!
Its not that the stock parts are bad... haven't had an issue with any of these, but these parts just make it betterer ehhehehehehe
www.beachrc.com
phillypete is offline   Reply With Quote
Old 02-18-2015, 11:21 AM   #7809
VegasHB's Avatar
The ports not being open seems like just an excuse. After reading through this thread it seems there's been parts shortage from day one before all this port silliness has happened.
After putting my kit together this week and looking over the front brace, it really is a weak spot. The plastic is brittle, it's only mounted at 4 unsupported small points and has thin plastic walls on the sides. You take a tumble or a shot from another car in the side of that thing and it'll snap no problem.
When you look at most front ends of 2wd's or some 4wd's the front tower is thick and mounted flush against the front bulkhead. This puppy is a thin walled bridge anchoring at each end, great for supporting the front end like it's designed but not for a wallop in the side or top. Its the Tacoma Narrows Bridge of RC parts :P
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 02-18-2015, 11:39 AM   #7810
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
I've seen these things take a beating that no other brand would stand up to. In this case, the theory is sound: break the $7 plastic piece and save the carbon fiber shock tower. The one of these I saw that did break was broken in such a way that an inventive fella could have fixed it and gotten back to racing. Some I have seen on here are a different story. Truly though, if we really want to get our cars off the shelf we will find a way. That's one of the reasons we are in this hobby.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 02-18-2015, 12:11 PM   #7811
Some of us have spare parts and didn't really have any trouble finding them. I haven't tried buying a spare front brace until we suddenly got a few people in here saying they broke theirs. But I saw them in stock not too long ago. I bet I have at least one spare by early March.
Not sure what to say about your opinion of the brace being a weak spot on the car. Plenty of people are crashing them in all kinds of ways without hurting the brace. The few people breaking them seem to be slamming into poles or walls at high speed. While the brace may not be as tough as some other parts of the buggy I don't see it as fragile.
Hot Bodies D413
AE B5M, T5M
Old 02-18-2015, 12:16 PM   #7812
snwchris's Avatar
Its actually not a bad design... I think a few people had some bad crashes or bad luck, and then starting saying how it will snap and then people run out to buy or carry as a spare.
Same thing happened with the Spur gear.... a few people mangled the spur or didn't set the mesh right and then all of a sudden there were bad spurs and people were buying them up and now you don't hear any issues of the spur anymore.
Yes its a shame that the supply chain is taking way too long, but none of us have control over that.
Last week I removed mine and actually modeled it in Solidworks, now if I only had a 3D Printer.... lol
Old 02-18-2015, 12:47 PM   #7813
Trader Rating: 93 (100%+)
This particular reason is why I presented the idea to RPM. They're known to improve upon other plastic pieces (i.e. B44 arms) so why not improve on a known weak point on this buggy? Even if the Hot Bodies factory part came off back-order, I would choose the RPM one over it if it were to become available.
Please makes some noise on RPM's FB page to get their attention if you would like to see this happen. I see that a few guys have already done so.
Life moves pretty fast. If you don't stop and look around once in a while, you could miss it. -- F. Bueller
eddiemoney13 is offline   Reply With Quote
Old 02-18-2015, 01:01 PM   #7814
VegasHB's Avatar
Well our local track had 2 in stock so snatched one up. I was going to grab the other and ebay it but figured another local racer would need it since there's a lot of D413's showing up.
Old 02-18-2015, 01:03 PM   #7815
RENOV8R's Avatar
The RC Shox only has one recessed bearing and it looks kinda homemade. These look niiiiiiiiiiice!
RENOV8R is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Cameron Kellogg
