Like Tree31Likes
Old 02-15-2015, 11:51 AM   #7726
Tobiasmart's Avatar
Originally Posted by hbae3052 View Post
For people using the avid aluminum chassis on carpet, how does it perform over the stock carbon chassis?
I have been using been using for a couple of months now on carpet and it makes the car handle so much better. Much better concistency. Lower cg makes it possible to drive it harder without getting unsettle. You will have little less grip. But with the cf chassis grip is like an on off button. Very twitchy.
Been using it in both my 4wd and my 2wd conversion witch by the way handles extremely well. Try it!
Tobiasmart is offline   Reply With Quote
Old 02-15-2015, 12:37 PM   #7727
So what is actually lower with this chassis? Does the motor and/or battery sit lower in the chassis than stock? From the pictures it doesn't look that way but it's hard to tell for sure.
Were you adding weight to the car before switching to this chassis? If not, I'm not understanding what advantage there would be to adding almost 2 ounces of weight to the chassis.
What kind of tires are you running on the carpet? What else have you changed from the stock setup?
If you don't have them already, I suggest trying the 5 dot ackerman arms. Between those and some expo in my radio I don't find the steering to be twitchy at all. I'm running pin tires all around and the grip is pretty much 100 percent.
Thanks,
Chris
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 02-15-2015, 04:36 PM   #7728
nitro2be's Avatar
Did anyone get a front tower from a main..I had two back order for today and nothing. .
nitro2be is offline   Reply With Quote
Old 02-15-2015, 05:20 PM   #7729
jwood7's Avatar
Originally Posted by ColourGhost View Post
Great
ae part # 7368. they r $2.89 at amain. work perfect on the ackerman and top of spindle
Hot Bodies D413 1/10 4WD Buggy-image.jpg
jwood7 is offline   Reply With Quote
Old 02-15-2015, 05:23 PM   #7730
jwood7's Avatar
Old 02-16-2015, 04:25 AM   #7731
snwchris's Avatar
Originally Posted by bmcallister View Post
Have you used the serpent caps?
I have not done the Serpent caps yet, I'm still running the stock caps since September. One of our local racers has made the change and a few people on here as well have done them.
Originally Posted by lovell
I have serpent caps on my d413.
Here are the part numbers needed
500146-14.50
500137-4.69
500199-11.49
2-500176-23.99
500179-2.50
Also Post #5686 is picture proof of the Serpent Caps on and working
Hot Bodies D413 1/10 4WD Buggy-serpent-cap-1.jpg   Hot Bodies D413 1/10 4WD Buggy-serpent-cap-2.jpg
snwchris is offline   Reply With Quote
Old 02-16-2015, 06:23 AM   #7732
Attachment 1271714
Cool thanks
ColourGhost is offline   Reply With Quote
Old 02-16-2015, 06:29 AM   #7733
Is there anyone here who isn't running 12mm hexes front and rear?
Hot Bodies D413
AE B5M, T5M
Old 02-16-2015, 06:33 AM   #7734
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
My son still has the smaller hex in the front.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 02-16-2015, 07:29 AM   #7735
Hmm, I would have bet a dollar that nobody in here is running the smaller hexes. Did you guys already have 9.8mm wheels and tires from a previous buggy?
Anyone else running the small hexes?
Hot Bodies D413
AE B5M, T5M
Old 02-16-2015, 08:48 AM   #7736
Moderator
bds81175's Avatar
Bought the car with them and it had a set of rims. Its our first real 4x4 buggy (I had a durango but that doesn't count, heheheh). The smaller hex seems to work fine. What was the issue with it?
Tekno RC
Old 02-16-2015, 09:04 AM   #7737
snwchris's Avatar
I don't think there is an issue with them.
The original kit comes with I believe 12mm Hexes all around and a optional set of smaller hex. The smaller front hexes are for running the AE wheels, cause some have the 10mm hex. One of our racers at our track had to borrow mine so he could run his AE 4w one day and worked for him.
Old 02-16-2015, 09:21 AM   #7738
mvrk28's Avatar
I've had the car for nearly one week, raced it and ran an all day practice the following day. Driving again today. Here are my thoughts on the car.
The build: easy, 5 stars. All kits should be this easy to build, I did not have one single issue, the only thing I had trouble with was the snap rings on the drivelines to lock the bearings in. Those little suckers were hard to get on!
The car itself: Amazing to look at. Countless people wanted to talk to me about it or just look at it on Friday. This car is insanely durable it's not even funny. I had a large number or crashes that should have broke this car, and it kept trucking. I was drilled full speed by an XB4 and not one single thing broke. I did notice the front sway bar will come out of the mounts once you've crashed enough, but I blame myself for that. You can only ask so much of this car.
I really can't find anything bad to say about this car, I turned my fastest lap ever on my first night out. It was the most fun I've ever had at the track, and renewed my love for this hobby. I can't wait for the D215!
Team Durango DESC10 - Tekin Pro 4 HD 4300, Protek, VRP, Proline, Sanwa
TLR 22t 3.0 - Tekin Gen 3 8.5t, Protek, VRP, Proline, Sanwa
VANT LIPOS
mvrk28 is offline   Reply With Quote
Old 02-16-2015, 09:37 AM   #7739
No issue with the small hexes.
I bought the DE Racing setup wheel kit for the D413. When I got the package, it came with two 12mm adapters and two 10mm adapters. I contacted DE through their web site and Dave Enstrom replied to me last night, saying most people are running the 9.8mm hexes in front, as he understands it. He's also getting me fixed up with the 12mm setup I need.
I told him my impression, from rctech, is that most everyone here is running 12mm front and back. So I'm asking you guys to see what reality is as far as the rctech world goes.
-Chris
Hot Bodies D413
AE B5M, T5M
Old 02-16-2015, 09:45 AM   #7740
Buzzy09's Avatar
-Chris
Im running 12mm all the way around
Losi 22 sct 2.0
Losi scte 2.0 (4 sale rtr 525 )
Losi 22 2.0
Hot bodies d413
Buzzy09 is offline   Reply With Quote
