Like Tree28Likes
Old 02-11-2015, 10:46 PM   #7636
kdeleon's Avatar
Originally Posted by khj94704 View Post
Is this still the standard thing to do with CF parts? I didn't exactly follow this method (chamfer with an emory board, wash with dish soap, dry, CA edges, more or less) but my god it was a pain in the butt. Is this really necessary?
It isn't necessary. Even the cars designer, Torrance, said he only rounded the edges but did not seal them with CA.
For me, I just slightly sanded the chassis to take off the edge but did not put CA. I did CA the front shock mount. After a few crashes, I could see some damage before I put CA on it. But CA stopped that. Otherwise, my chassis has help up.
kdeleon is offline   Reply With Quote
Old 02-12-2015, 04:48 AM   #7637
Chr1s's Avatar
I would seal your edges. Mine started to split at one of the edges. I sanded and glued it, and it been fine since.
Chris Kline
Chr1s is offline   Reply With Quote
Old 02-12-2015, 05:04 AM   #7638
RENOV8R's Avatar
Put on the RC Shox ackerman last night and it does eliminate a lot of slop. But has anybody thought about a tighter linkage between the steering rack and the servo horn. I figure you can eliminate close to another millimeter of slop.
RENOV8R is offline   Reply With Quote
Old 02-12-2015, 06:31 AM   #7639
big greg's Avatar
Trader Rating: 119 (99%+)
We're still talking about slop?
Hot bodies d812e tekin T8 1700 rx8 gen 2
Hotbodies d815 o.s. speed Tessman ed
Hb/hpi racing, vp pro usa, Lutz rc, valvenous paint, tekin racing, rc addiction products/nitro pro fuel
Rip bill bridges
big greg is offline   Reply With Quote
Old 02-12-2015, 06:32 AM   #7640
Yes, I've been looking at the same thing and I think it's a good single place to remove some slop. I browsed around on amain for a link from another car that might work but they don't give much as far as measurements go.
I also removed the bushings from my steering blocks and filed them down a bit. That helped to take a little slop out and it still moved free with the screws tight.
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 02-12-2015, 06:35 AM   #7641
The car is still sloppy so we're still talking about it.
Hot Bodies D413
AE B5M, T5M
Old 02-12-2015, 06:51 AM   #7642
My wiring job, one zip tie is all I needed to keep everything neat and in place.
Wiring has kinda become my thing, been 6 years at flying heli's.
GimpyGolden is offline   Reply With Quote
Old 02-12-2015, 07:08 AM   #7643
Vinny Cancilla's Avatar
To me, most of the slop is in the ball cups and ball studs.
Serpent Srx8
Serpent America: Triton engines/ Nitro pro.Fuel/ Rc Addiction products : Vp pro Usa/Dialed-Rc
Barnstormers: Chester, NY, N.Y.. IRH Lindenhurst
Vinny Cancilla is offline   Reply With Quote
Old 02-12-2015, 07:23 AM   #7644
VegasHB's Avatar
Anyone else try running associated pistons in their car?
Building my shocks last night I wanted to stick with a 2 hole setup for more pack and being an AE guy i have a boat load of AE pistons lying around. The center hole is larger and won't center well but i found once you put the washers on they hold well. To get them to center up, I put the nut on loosely, inserted the assembly into the shock body all the way to the bottom and then tightened up the piston nut. Smooth as butter through the whole stroke.
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 02-12-2015, 07:30 AM   #7645
mvrk28's Avatar
Ya know, I was debating on doing it at all. But I ended up doing my chassis, and I used emory paper, sharpie a rag and some CA. I didn't go crazy on rounding them off I just put the chassis in a clamp sanded it and wiped it clean, then used a Sharpie around the edge. Then left it in the clamp at an angle and with a fine tip on my CA glue I applied CA at the top and let it run down the chassis leaving a nice fine and shiny edge. I will probably end up taking the rest of the carbon off and doing it. IMO it's too easy to do it so why not.
Team Durango DESC10 - Tekin Pro 4 HD 4300, Protek, VRP, Proline, Sanwa
TLR 22t 3.0 - Tekin Gen 3 8.5t, Protek, VRP, Proline, Sanwa
VANT LIPOS
mvrk28 is offline   Reply With Quote
Old 02-12-2015, 07:43 AM   #7646
slakr's Avatar
Trader Rating: 28 (100%+)
To apply the CA, I use a Q-Tip
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 02-12-2015, 08:39 AM   #7647
mvrk28's Avatar
Build progress! I had to mount the electronics ahead of the steps so I could take it in to get soldered today.
Yes I'm aware my rear arms are backwards, I was half past tired when I put them on haha
Hot Bodies D413 1/10 4WD Buggy-image.jpg
VANT LIPOS
Old 02-12-2015, 08:56 AM   #7648
skeasor's Avatar
That's better than putting the diffs in backwards
Support: http://bumpsandjumpsrc.com/, http://thehiddenhangar.com/, https://www.kranzelshobbies.com/, http://aerotechhobbies.net/
skeasor is offline   Reply With Quote
Old 02-12-2015, 09:17 AM   #7649
mvrk28's Avatar
Oh god now you have me wanting to go back and check!
VANT LIPOS
Old 02-12-2015, 09:23 AM   #7650
RENOV8R's Avatar
For the cost involved, why not just install the RC Shox pistons that are made for the shocks and be done with it. 1.6 2-hole front & 1.7 2-hole rear seems to be a good setup
