Like Tree28Likes
Old 02-10-2015, 07:09 PM   #7606
mvrk28's Avatar
Go time!
Hot Bodies D413 1/10 4WD Buggy-image.jpg
Team Durango DESC10 - Tekin Pro 4 HD 4300, Protek, VRP, Proline, Sanwa
TLR 22t 3.0 - Tekin Gen 3 8.5t, Protek, VRP, Proline, Sanwa
VANT LIPOS
mvrk28 is offline   Reply With Quote
Old 02-10-2015, 08:31 PM   #7607
Grigz's Avatar
Trader Rating: 16 (100%+)
Someone school me on wire tucking and hiding. Can't come up with anything other than this to hide wires and keep everything nice and tidy. Obviously I need to go with black wire ties but its all I had for the time being.
TLR / 22-4 2.0 / LRP / Savox
Grigz is offline   Reply With Quote
Old 02-10-2015, 08:57 PM   #7608
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Some ideas. Its prob he most time consuming part of the build for me lol.
Hot Bodies D413 1/10 4WD Buggy-413top.jpg   Hot Bodies D413 1/10 4WD Buggy-413top2.jpg
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 02-10-2015, 09:05 PM   #7609
mattied2000's Avatar
Trader Rating: 15 (100%+)
Originally Posted by mvrk28 View Post
I just came across this link and will be doing this method on my D413, take a look.
http://www.teamcrc.com/crc/modules.p...rder=0&thold=0
Wish I had seen this sooner!!!
mattied2000 is offline   Reply With Quote
Old 02-10-2015, 09:07 PM   #7610
looks nice man!
Old 02-10-2015, 09:09 PM   #7611
Looks nice man!
Old 02-10-2015, 09:12 PM   #7612
kdeleon's Avatar
One more version. Very similar. But Grigz, you might want to try turning your motor to the side and move your transponder. Mine is in the front under the steering rack.
Hot Bodies D413 1/10 4WD Buggy-dsc_7201.jpg
kdeleon is offline   Reply With Quote
Old 02-10-2015, 10:01 PM   #7613
Here is mine. Not a lot of options with the shorty config. I do turn the motor tabs off center just like my 1/8 scale.
ramctd is offline   Reply With Quote
Old 02-10-2015, 10:34 PM   #7614
JeepnMike's Avatar
[/URL]
By chance did you use Tamiya PS Florescent red paint on your body?
TRF801x - DB01RR - B5m Lite - TB03 - Variety Of Vintage Tamiya
JeepnMike is offline   Reply With Quote
Old 02-11-2015, 12:48 AM   #7615
Originally Posted by Stealth_RT View Post
Best to soak the xrings in shock oil for half a day to a day before building the shocks. The xrings are a bit too small to start with, and need to swell some first. Green slime actually retards this process and makes the shocks leak/suck air longer.
Thanks Stealth. That was really useful info. I thought the green slime would do that. Will try it out
ColourGhost is offline   Reply With Quote
Old 02-11-2015, 02:53 AM   #7616
Go time!
You lucky sob lol
turtle189mt is offline   Reply With Quote
Old 02-11-2015, 05:44 AM   #7617
mvrk28's Avatar
Originally Posted by turtle189mt View Post
You lucky sob lol
hahaha you will get yours soon enough! My advise is to back order it with one of the big shops, that way if your local shops don't get one then you will have a good chance of getting one still.
Also, when you do get it you should check out that carbon fiber prep link I posted. I used that method on my chassis and it was crazy easy and the result was awesome! I didn't do the wet sanding part of it but it didn't really look like it needed it.
VANT LIPOS
Old 02-11-2015, 07:43 AM   #7618
RENOV8R's Avatar
Just touch up those white tie wraps with black permanent marker. I've got a similar setup, but with the small RS Pro ESC I was able to fit it further inside, with a 2 bank cap on the outside and the transponder on top of it.
RENOV8R is offline   Reply With Quote
Old 02-11-2015, 07:46 AM   #7619
Vinny Cancilla's Avatar
Originally Posted by uncle everett View Post
Traxxas x rings....$
Bingo!!!!
Serpent Srx8
Serpent America: Triton engines/ Nitro pro.Fuel/ Rc Addiction products : Vp pro Usa/Dialed-Rc
Barnstormers: Chester, NY, N.Y.. IRH Lindenhurst
Vinny Cancilla is offline   Reply With Quote
Old 02-11-2015, 07:52 AM   #7620
What's wrong with the stock o rings? Are they really that bad?
DIRT DIGGER is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
