Like Tree28Likes
Old 02-09-2015, 12:19 PM   #7576
im looking to buy this buggy. I race on a ozite carpet indoor track. I own a tlr 22-4 and wanting to upgrade to this kit. when should it come of back order? parts aswell? im hoping that hot bodies gets over this issue soon.
hbae3052 is offline   Reply With Quote
Old 02-09-2015, 12:19 PM   #7577
Originally Posted by RC*PHREAK View Post
Got those cheap graphite arm inserts off eBay. Came pretty quick and the fit is perfect:
I got some of those too, fit was perfect... unlike the ones from HB which DON'T and require a bunch of file work.
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 02-09-2015, 01:24 PM   #7578
MasiisaM's Avatar
I didn't have to do anything to put the HB carbon inserts in. They were turn key and required no bench work. Maybe i got a lucky batch..
TLR 22 2.0 - TLR 8E 3.0 - HB D413
Thanks to:
Tekin - www.teamtekin.com
Thunder Designs - www.thunderdesigns.net
MasiisaM is offline   Reply With Quote
Old 02-09-2015, 01:56 PM   #7579
what are you guys running in the diffs?
chrisnitro is offline   Reply With Quote
Old 02-09-2015, 02:05 PM   #7580
ISH
ISH's Avatar
F7k,C100k,R5k
ISH is offline   Reply With Quote
Old 02-09-2015, 02:27 PM   #7581
MasiisaM's Avatar
Med/high bite i will go with 7/100/3
Thanks to:
Old 02-09-2015, 03:56 PM   #7582
jhautz's Avatar
Trader Rating: 85 (100%+)
10/100/3 med/high traction, med/large size clay track.
jhautz is offline   Reply With Quote
Old 02-09-2015, 09:21 PM   #7583
Mine fit just fine as well. First I've read about anyone having a problem with the fit. The price from HB is a little silly but not the quality, from my experience.
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 02-09-2015, 09:32 PM   #7584
Originally Posted by Egress View Post
Thanks for your comment, but in case the car flips or bounces After a Jump is it the Springs that should be softer? How does affect hard oil and relatively soft springs the handling?
I'm running 90 percent of the Tessmann carpet setup and thought it was pretty darn good Sunday on our carpet track. Two weeks ago I tried the setup with extra kickup rather than the 5 dot ackerman arms and too much camber along with thicker sway bars I made from Serpent parts. I was traction rolling with very little warning but the car was pretty good on the jumps.
I ordered and installed the 5 dot arms and set my kickup back to the 8 degrees from the Tessmann setup. The sudden traction rolls went away and I should have pushed the car harder through the turns than I actually did. The only difference between my setup and the Tessmann setup sheet is my 1.8mm Serpent sway bars and I have HB red springs on both ends.
Hot Bodies D413
AE B5M, T5M
Old 02-09-2015, 09:53 PM   #7585
I've been wondering if I should adjust my center diff oil weight. I'm running 60K right now but most high traction setups seem to be a little to a lot higher weight. What difference will the thicker oil in the center diff make? I have some knowledge of how to tune diff oils for outdoor medium grip conditions but really don't know much about indoor high grip.
Hot Bodies D413
AE B5M, T5M
Old 02-09-2015, 09:56 PM   #7586
Lowe's48's Avatar
How much does it weigh with a shorty set up ? Saddle set up ?
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Lowe's48 is offline   Reply With Quote
Old 02-09-2015, 10:22 PM   #7587
Hey guys, I'm gonna pull the trigger on purchasing this bad machine here real soon so I've been reading through this thread before I ask many questions, I'm almost to page 200 and I see people talking about sanding and sealing the edges of the carbon fiber? I don't have much experience with cf so far and I know this car is like 80% so I'm looking for tips on taking care of it? Sorry if I just haven't come to that discussion yet or if it's covered in a specific thread, thanks for any info
mikeinsocal is offline   Reply With Quote
Old 02-09-2015, 10:46 PM   #7588
mvrk28's Avatar
From what I've been told sanding is optional, some people like to chamfer the edges to make it look trick, but you can just seal the edges and that would be more than fine.
Team Durango DESC10 - Tekin Pro 4 HD 4300, Protek, VRP, Proline, Sanwa
TLR 22t 3.0 - Tekin Gen 3 8.5t, Protek, VRP, Proline, Sanwa
VANT LIPOS
mvrk28 is offline   Reply With Quote
Old 02-09-2015, 10:59 PM   #7589
Trader Rating: 8 (90%+)
I can't wait to find some front shock tower mount.
Boostgod is offline   Reply With Quote
Old 02-10-2015, 05:25 AM   #7590
jwood7's Avatar
basicly its locking the center. car will accelerate harder but will also have a drag brake type feel when u let off. if u feel the center diff fade and start to slip u defidently need to go up in weight. best thing to do is try it and see how u like it
jwood7 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
