Like Tree28Likes
Old 02-03-2015, 07:54 PM   #7456
Originally Posted by ISH View Post
i run the trifecta cut down and mounted high.
thanks guys. does cutting it down make it more stable or leaving it high?
DIRT DIGGER is offline   Reply With Quote
Old 02-03-2015, 08:05 PM   #7457
ISH
ISH's Avatar
to me the car feels better in the air with the wing cut low. i think its preference
ISH is offline   Reply With Quote
Old 02-03-2015, 08:18 PM   #7458
u think it would be better on the straights to leave it high and not cut it?
Old 02-03-2015, 08:39 PM   #7459
ISH
ISH's Avatar
i think leaving it stock would be too much resistance both in the air and on straights.
Old 02-03-2015, 11:02 PM   #7460
I normally run a low wicker on my 2wd and it got me thinking that we don't need the down force in the back of a 4wd as compared to a 2wd so today I ran wing with no wicker. The only hint of a wicker was just the kick up of the wing and I must say it felt really good. I run on a smaller indoor clay track so we aren't fighting any kind of "condition" like outdoor tracks may face.
CaseyD is offline   Reply With Quote
Old 02-04-2015, 12:12 AM   #7461
Chiefy 707's Avatar
Finally got to run my 413. Car felt good. No weird handling quirks. Jumps and lands well. But then I wasn't driving hard which is why I'm disappointed.
-side pod of body ripped away very easily. Partially my fault maybe since I over tightened the screws
-car does not like loamy surfaces. Nothing to do with handling but more as being a collector of dirt.
-threaded portion of hingepin broke. During assembly I was wondering if they would be an issue. I never noticed the breakage until I was home picking away dried dirt. The rest of the hingepin was still there.
Really bummed out since I wasn't even pushing the car hard. The car is still in what I call debug mode.
Anyone else have issues with the hingepins?
"It looks like a [insert car here]. It's just another [insert car here] clone!"
"Why did [insert manufacturer here] go with such a radical design? [insert manufacturer here] needs to stick with what works!" Shhhh, please.
HB/LRP/KO Propo/Protek/Associated/Tekno
Chiefy 707 is offline   Reply With Quote
Old 02-04-2015, 02:29 AM   #7462
RC10B4_Mafco's Avatar
Trader Rating: 15 (100%+)
Send a message via MSN to RC10B4_Mafco
Originally Posted by Wildcat1971 View Post
Some people have issues with the AE ones leaking. The traxxas ones are good and very cheap.
So if I replace the stock o-rings with the traxxas x-rings and keep the stock plastic shock pieces (like the 2mm plastic shock spacer) the shocks will be smoother and won't leak?
RC10B4_Mafco is offline   Reply With Quote
Old 02-04-2015, 05:33 AM   #7463
RENOV8R's Avatar
That is correct. They'll be noticeably smoother and you won't have to bleed them every 2 minutes
RENOV8R is offline   Reply With Quote
Old 02-04-2015, 05:37 AM   #7464
RENOV8R's Avatar
Yes, I snapped an end off when I was building it but I haven't bothered replacing it. Just spin the hinge pin around backwards so the caphead end is at the chassis and it's never going anywhere
Old 02-04-2015, 06:48 AM   #7465
boudin4evr's Avatar
Trader Rating: 18 (100%+)
has anyone found the aluminum shock caps in stock yet? where if so?
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 02-04-2015, 06:49 AM   #7466
boudin4evr's Avatar
I ran mine hard last weekend, crashed hard a few times, car is solid!! I only popped off rear shock cap once! That says alot for this car!
Marc Richard
Old 02-04-2015, 07:04 PM   #7467
TORQUE ROD's Avatar
is there an ideal ride hide for this buggy? and what is the best starting setup
for damp (tacky) indoor clay?
TORQUE ROD is offline   Reply With Quote
Old 02-04-2015, 07:06 PM   #7468
mvrk28's Avatar
Amain pushed their date back another week in case anybody was wondering.
Team Durango DESC10 - Tekin Pro 4 HD 4300, Protek, VRP, Proline, Sanwa
TLR 22t 3.0 - Tekin Gen 3 8.5t, Protek, VRP, Proline, Sanwa
VANT LIPOS
mvrk28 is offline   Reply With Quote
Old 02-04-2015, 07:14 PM   #7469
I just got mine off of rctech and I cannot find any white front wheels for this thing.... I know some are using TLR 22 front wheels what are others using? I would like to not sacrifice width if I can.
bmerkid is offline   Reply With Quote
Old 02-04-2015, 07:23 PM   #7470
mvrk28's Avatar
22-4 front wheels are the same thing
VANT LIPOS
