Like Tree35Likes
Old 01-30-2015, 01:52 PM   #7366
Team Tekin
yzracer758's Avatar
Trader Rating: 18 (100%+)
Tessmann's Reedy Setup: http://www.tytessman.com/setups/pdf/...yrace-d413.pdf
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics | Carolina Custom Anodizing
Jeremy Potter
Tekin C.S. Manager
yzracer758 is offline   Reply With Quote
Old 01-30-2015, 06:09 PM   #7367
Going to be getting this kit this summer and I'd like some tips when putting it together. Also is there a big difference betwen running saddle packs or a shorty pack.
Longhornfan is offline   Reply With Quote
Old 01-30-2015, 06:46 PM   #7368
anyone using #3 ankerarm? curious how much it changes from #4 ?
DIRT DIGGER is offline   Reply With Quote
Old 01-30-2015, 07:01 PM   #7369
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I like aggressive steering but it was too much. Makes the car very twitchy.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 01-30-2015, 08:38 PM   #7370
Is this kit sold out everywhere?! I can't seem to find any in stock anywhere.
mk3design is offline   Reply With Quote
Old 01-31-2015, 01:23 AM   #7371
YoG
YoG's Avatar
Default My HB D413 Build
Just finished my build enjoy.Just wanted to say that the customer service at HPI Racing is top notch. Hey TY now there are three HB D413 on Vancouver Island BC Canada.
Hot Bodies D413 1/10 4WD Buggy-20150131_003607.jpg   Hot Bodies D413 1/10 4WD Buggy-20150131_003627.jpg   Hot Bodies D413 1/10 4WD Buggy-20150131_012615.jpg
XRAY XB2ce/AE T5M/AE SC5M/HB D413/TEKNO SCT410
http://www.corvictoria.com/
YoG is offline   Reply With Quote
Old 01-31-2015, 08:54 AM   #7372
Trader Rating: 36 (100%+)
Send a message via AIM to robby26wi Send a message via Yahoo to robby26wi
front shock shafts...out of stock everywhere...any alternatives??
robby26wi is offline   Reply With Quote
Old 01-31-2015, 05:28 PM   #7373
Looking for some help... saw a couple posts a while back about the frt axles barely fitting in the drive cups.. I have the same issue. The left axle has popped out. I pulled front diff out to verify that tje diff was installed correctly for shorty set up(ring gear on right side) I can't find those posts to see if a fix was offered.
Anyone have a fix?
robbie_gtc is offline   Reply With Quote
Old 01-31-2015, 06:17 PM   #7374
Anyone have a fix?
Got the answer. Frt and rear diff cups swapped. Late night rebuild issues.
Old 01-31-2015, 07:55 PM   #7375
I ran into this issue, I bought some Kyosho shafts put some long shock eyelets on there with either Kyosho or slash spring cups. Just be careful, if you don't space and limit the shaft right it will bottom out into the shock cap. I did it to get myself through the night but have since just left it that way.
CaseyD is offline   Reply With Quote
Old 01-31-2015, 08:04 PM   #7376
kdeleon's Avatar
There is one on ebay. Search by the part number. I think the length is listed wrong but it seems to be the right part. The seller is reputable and even comes to this forum, so ask them if you just want to be sure.
kdeleon is offline   Reply With Quote
Old 01-31-2015, 08:08 PM   #7377
hello just curious what will happen if i change my diff fluilds from 10k 60k 4k to 15k 100k 4k? what would that effect? thanks alot for help.
Old 01-31-2015, 08:33 PM   #7378
jhautz's Avatar
Trader Rating: 85 (100%+)
Generally thicker front diff oil will make the car turn less aggressively off power and have more steering on power. Thicker center diff will give more forward drive allowing less power to be unloaded to the front tires.
Overall it shoukd make the car fell a bit more stable in the more open sections, and less aggressive in the tight sections.
Read "JQ The Guide" section on differentials if you haven't. I think it does a nice job of explaining how the diff oils effect handling. The guide is written for 1/8 buggies but the D413 is 3 diff system set up like a smaller 1/8 scale. The same principles apply, but the oil weights ranges will be different for the smaller 1/10 diffs.
http://jq-products.com/the-news/43-t.../160-the-guide
jhautz is offline   Reply With Quote
Old 02-01-2015, 06:14 AM   #7379
anyone know how to ajust the angle of the wing?
Old 02-01-2015, 06:16 AM   #7380
Trader Rating: 132 (100%+)
Add shims when mounting the wing mount.
skyline1015 is offline   Reply With Quote
