Like Tree35Likes
Old 01-27-2015, 09:44 AM   #7321
skeasor's Avatar
Originally Posted by Yeti AS3 View Post
You're slacking man! The temp in the track area is prob 55 deg too which may play a part. I will say I was a little rough after coming back after 2 yrs or so.
55 degrees is nice! Our track is so cold you can see your breath. We usually stand around the heater right before the heat to try and warm the plastics
Support: http://bumpsandjumpsrc.com/, http://thehiddenhangar.com/, https://www.kranzelshobbies.com/, http://aerotechhobbies.net/
skeasor is offline   Reply With Quote
Old 01-27-2015, 09:45 AM   #7322
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I wear shorts all year long
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 01-27-2015, 09:59 AM   #7323
Captcha's Avatar
Incase anyone is looking a have a 7 race day old d413 for sale in the FS/t section. Comes rtr minus RX. Please check out the add.
Brandon Ryan
Public Relations, and Hype-Man
301 Raceway & Hobby
3404 NE 37 PL.
Wildwood, FL 34785
Captcha is offline   Reply With Quote
Old 01-27-2015, 10:13 AM   #7324
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
I've tweaked my normal set up to calm the car down a bit. Try it out and let me know how it works for you guys.
Hot Bodies D413 1/10 4WD Buggy-nick-1-27-2014.jpg
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 01-27-2015, 10:18 AM   #7325
MasiisaM's Avatar
Hey Nick..Im just curious on what you're running for your ESC settings..
I do wish the the set-up sheets included such info...kinda like the TLR sheets
TLR 22 2.0 - TLR 8E 3.0 - HB D413
Thanks to:
Tekin - www.teamtekin.com
Thunder Designs - www.thunderdesigns.net
MasiisaM is offline   Reply With Quote
Old 01-27-2015, 10:37 AM   #7326
off the top of my head*
Tekin RSX with gen2 6.5 motor
250 firmware
minimum throttle: 2
minimum brake: 1
current limiter: 72%
brake power: 70 (brake is fine tuned on-the-fly using M12's dual rate function, I'm usually around 75-100% dual rate depending on grip level. less grip = lower D/R percentage)
deadband: 25
linear throttle curve
no boost
no timing
no expo
12 degrees fixed motor end bell timing (factory setting)
*I'll have to double check when I get home.
Nick Vasquez
Old 01-27-2015, 11:02 AM   #7327
Dog Runner's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to Dog Runner
You suck!!!
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
Old 01-27-2015, 03:01 PM   #7328
TORQUE ROD's Avatar
Default Front Bearing Slop
My front hub bearing slops need some suggestions on a better bearing (brand) for the front. many thanks...
TORQUE ROD is offline   Reply With Quote
Old 01-27-2015, 03:07 PM   #7329
Schelle bearings are very good.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 01-27-2015, 08:44 PM   #7330
Have you guys found that better bearings will remove some slop compared to the stock ones?
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 01-27-2015, 08:55 PM   #7331
doubtful. even crappy bearings dont have much play. Unless of course you blew up the bearing...then that is different
Old 01-27-2015, 09:04 PM   #7332
So I posted Sunday night that I was disappointed with the sway bars I made when I got to the races. The buggy seemed to be traction rolling much easier than the previous weeked when I practiced with it.
Somehow I had it in my head that I only changed the sway bars during the week but that isn't true. I actually increased my camber to about 2.5 (eyeballed) all the way around and I switched to the sworks s104 wing. Plus I shoe gooed the three body pieces together. Do you guys think the increased camber would have caused the buggy to traction roll more easily? What about adding weight up high by using the thicker wing and the shoe goo? Could that have been enough to make a noticeable in tendency to traction roll?
Hot Bodies D413
AE B5M, T5M
Old 01-28-2015, 05:25 AM   #7333
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Increasing camber isn't going to result in more traction rolling. On carpet, I have seen a lot of people tire glue an even coat around the outside side wall of the front tires. This allows the tire to slide at extremes (through long sweepers especially) instead of completely folding over and jacking the car over. Thicker sway bars are going to plant the outside tire quicker in a corner. You could be folding the front tire over right away. You also want to run FIRM foams on carpet.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 01-28-2015, 11:10 AM   #7334
TORQUE ROD's Avatar
[QUOTE=Wildcat1971;13811222]doubtful. even crappy bearings dont have much play. Unless of course you blew up the bearing...then that is different[/QUOTE
the bearings that came with the buggy is really bad..you can move the middle part of it side to side .
Old 01-28-2015, 11:25 AM   #7335
How is running 100,000k in the center calming anything down? I'm at 15/60k/2 and mine seem pretty good....3k may be better, my next tweak. Just curious because when I tried 100k it was a twitchy rear end happy car....on a medium bite track.
AE B6
AE B64
kerby is offline   Reply With Quote
