Like Tree28Likes
Old 01-27-2015, 08:05 AM   #7306
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Originally Posted by RENOV8R View Post
Just ordered all new bearings from Avid. Tore down the buggy after the first run and both large back bearings and one front bearing were super notchy. Anybody else experienced this?
I am still on the kit bearings. they are not notchy, but they are also not very good. Your better off with the Avid Bearing Kit.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-27-2015, 08:18 AM   #7307
snwchris's Avatar
Originally Posted by skeasor View Post
Is this still the part number for the aluminum shock caps? #114112. I'll be building one of these kits soon and would like to start off with the aluminum caps. I haven't been able to find them: http://www.hpiracing.com/en/part/114112
edit: I think I found it: http://www3.towerhobbies.com/cgi-bin...&I=LXEYVD&P=ML
I don't think the HB Aluminums are in stock yet.
I'm still running the stock set and even have the B5 Composite ones in my tool bag as back ups.
The stocks ones have been fine, the biggest thing to remember is when your rebuilding shocks is to remove the shock mount from tower instead of popping the shock ball cap on and off, to help eliminate wear on bull cup
snwchris is offline   Reply With Quote
Old 01-27-2015, 08:22 AM   #7308
My shock caps popped off a couple time. then I cleaned out the cups per someones suggestion and I have not had one pop off in a long time. I think the shock cap thing is a bit over blown. There is not a "real" issue, people just want to bolt them on for peace of mind.
Old 01-27-2015, 08:27 AM   #7309
skeasor's Avatar
I think I fall into that category, "for peace of mind"
Support: http://bumpsandjumpsrc.com/, http://thehiddenhangar.com/, https://www.kranzelshobbies.com/, http://aerotechhobbies.net/
skeasor is offline   Reply With Quote
Old 01-27-2015, 08:29 AM   #7310
kdeleon's Avatar
I was servicing my car last week and noticed the same thing. My car didn't sound the same. I thought it was the rear diff at first but turned out to be the bearings. They were also really notchy. Mainly the smaller bearings. I replaced all four and it is back to normal. I think I might replace the front ones too just to keep everything in sync.
kdeleon is offline   Reply With Quote
Old 01-27-2015, 08:32 AM   #7311
skeasor's Avatar
Which bearings are you referring to?
Thanks!
Old 01-27-2015, 08:32 AM   #7312
kdeleon's Avatar
I also ordered the aluminum shock caps but I might wait until others try them (when they finally come in). For all the complaining of the standard ones, I like the design. I would much rather have them pop off in a crash then have the CF front shock tower be torn apart. It is much easier and cheaper to just pop them back in. Or replace them if they start popping out more often.
Old 01-27-2015, 08:35 AM   #7313
kdeleon's Avatar
Thanks!
The rear hub bearings (2 on each side). The bearings around the diff/outdrive were dirty but they were smooth.
Old 01-27-2015, 08:35 AM   #7314
the stock caps dont dig into the track as much. I tried the AE ones and I could tell that they were digging in much more. Which is my mind means more force being transferred to the tower. Plus, the stock caps are really easy to wipe down. I will probably run the stock caps until they become a problem.
Old 01-27-2015, 08:45 AM   #7315
MasiisaM's Avatar
I havent really had an issue with the stock caps..They have popped off twice and with good reason...i had a few pretty good get off's when they popped. In fact i was surprised i didn't break anything.
speaking of breaking..on the last few days of running i've had my left rear tie rod ball cup snap on me right where it tapers to fit the hub..(where it goes from round to flat). Didn't have any get off's i can think of that would cause it to break..the odd thing it's just the left rear that keeps breaking. (three times now).
Checked to see if anything else might be bent causing it to break...but its all square and good to go.
anyone else breaking right there?
TLR 22 2.0 - TLR 8E 3.0 - HB D413
Thanks to:
Tekin - www.teamtekin.com
Thunder Designs - www.thunderdesigns.net
MasiisaM is offline   Reply With Quote
Old 01-27-2015, 08:50 AM   #7316
skeasor's Avatar
Thanks!
Old 01-27-2015, 09:18 AM   #7317
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
[QUOTE=MasiisaM;13809599
anyone else breaking right there?[/QUOTE]
I have broke a few. I modified mine and have not had any issues since..and I should have lol. I took sandpaper to rough up the small cavity where it breaks then clean with alcohol. Take carbon fiber plate and use razor blade to shave it off and make powder. Mix a bunch in with CA (slower setting would be better than AKA I used) and fill the void in the rod end. Do both sides of the rod end.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 01-27-2015, 09:22 AM   #7318
Holy crap, lol.
I never broke a cup. Still never broken a part. maybe I need to try harder, lol
Old 01-27-2015, 09:33 AM   #7319
Yeti AS3's Avatar
Holy crap, lol.
You're slacking man! The temp in the track area is prob 55 deg too which may play a part. I will say I was a little rough after coming back after 2 yrs or so.
Hot Bodies D413
AE B5m
Old 01-27-2015, 09:38 AM   #7320
MasiisaM's Avatar
Damn...thats some breaking bad stuff right there.
Thanks to:
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
nimda5
