Like Tree35Likes
Old 01-25-2015, 04:27 PM   #7246
Originally Posted by skeasor View Post
Hi guys,
I have one of these on order and was hoping someone could clarify this for me...I currently run a Losi 22 2.0 and have front wheels and tires already glued up for when I race 2wd buggy. Can I also use these on the D413? I found this on the first page of the thread but wasn't sure if they mean that the 22 2.0 or the 22-4 wheels. I'd also like to use the rears from my 22 2.0 as well. The less to take the the track the better
TLR rears are same between 2wd and 4wd.
The 22.2 fronts are narrower than the 22-4 but both come out at same track width, at least this is my understanding.
I have 22-4 fronts and rears and it's pretty clear Torrance modeled the 413 wheels after these.
GimpyGolden is offline   Reply With Quote
Old 01-25-2015, 04:33 PM   #7247
im trying to set my droop on my shocks. im trying to get 24mm f and 32mm r. could u tell me what lines to thread up to on shock shafts i have no way to measure. thanks
DIRT DIGGER is offline   Reply With Quote
Old 01-25-2015, 04:36 PM   #7248
skeasor's Avatar
Originally Posted by Stealth_RT View Post
The rears will work fine. But 2wd front tires would be too narrow for a 4wd buggy. Sure, they'd fit, but you'd be giving up front traction under power, which is afterall, why we run 4wd. You should really get some actual 4wd front tires and wheels. Any wheel sold as 22-4 front wheels will work, using the included 12mm hexes.
Thanks guys! I appreciate the help. i'm really looking forward to receive this kit. It's my first 4wd buggy.
Support: http://bumpsandjumpsrc.com/, http://thehiddenhangar.com/, https://www.kranzelshobbies.com/, http://aerotechhobbies.net/
skeasor is offline   Reply With Quote
Old 01-25-2015, 04:37 PM   #7249
Parts!
Where is the best source for parts in Canada/US or Asia/UK for the 413?
Started carpet racing yesterday and I'm a lil green with the offroad stuff.
Thinking front tower brace, arms, hinge pins and shock shafts/ends would be good to have on hand. Trouble is no one shop I know of has em all in stock.
Tried Tower, A-main, Omni and a couple overseas shops but no dice. Is there a good one stop shop for 1/10 buggy stuff with good stock for 413?
Old 01-25-2015, 05:16 PM   #7250
Trader Rating: 52 (100%+)
Anyone have a part number for the traxxas o rings your using in the shocks?
CarFanatic is offline   Reply With Quote
Old 01-25-2015, 05:22 PM   #7251
Parts!
If the places you tried were outta stock they should have more parts the end of the month.
turtle189mt is offline   Reply With Quote
Old 01-25-2015, 05:46 PM   #7252
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
TRA2362
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 01-25-2015, 06:07 PM   #7253
Chr1s's Avatar
So I've been running the car for a few months and I thought would post my thoughts on avid vs stock chassis.
I ran the stock chassis for about about 2-3 months, then ran the avid for about 1.5 months. Got the car setup about as good as i could with both chassis and here's what I found.
I've found that the stock chassis allows me to carry more corner speed, accelerates faster, lands better, and has more traction(which I attribute to flex).
The avid chassis seems to mellow out the steering, and overall makes the car easier to drive but it's slower on primary track I run on. Where the avid chassis seemed to show promise was on a high grip bumpy surface where you need something that's very consistent.
I would not say this chassis is a must buy, and it might make you slower if you don't run on super high grip. I'm back to the stock chassis simply because my lap times are faster.
Chris Kline
Chr1s is offline   Reply With Quote
Old 01-25-2015, 06:22 PM   #7254
savageboy69's Avatar
Trader Rating: 88 (100%+)
Anyone have the alum caps yet?
Xray|Rc America|Hudy|FX engines|Tekin|SOR graphics|LFR|Ogio|SRT servos|
XB8 2016
XB8-E 2016
XB4 2017
savageboy69 is offline   Reply With Quote
Old 01-25-2015, 06:48 PM   #7255
Ran my d413 for the first time today. Car is way to soft on the shocks. What springs are guys running to stiffen These up? I just picked up a setof rcshox pistons. Just need to know what springs
Old 01-25-2015, 07:35 PM   #7256
What piston and oils did you start with?
XB8 2016
XB8-E 2016
XB4 2017
Old 01-25-2015, 07:55 PM   #7257
ISH
ISH's Avatar
I haven't had any issues finding parts on Amain.
ISH is offline   Reply With Quote
Old 01-25-2015, 08:00 PM   #7258
ISH
ISH's Avatar
AE yellow front springs and grey rear.
Old 01-25-2015, 08:03 PM   #7259
ISH
ISH's Avatar
Any pics of this yet?
yes sir let me snap a few and post them up.
Old 01-25-2015, 08:49 PM   #7260
ISH
ISH's Avatar
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
