Like Tree28Likes
Old 01-25-2015, 11:07 AM   #7231
mvrk28's Avatar
I read a post on here from Torrance I believe saying that Kyosho X Rings work well instead of cutting the bladders, can somebody confirm if these are the correct ones?
http://www.amain.com/kyosho-p3-groov...ring-8/p151059
Team Durango DESC10 - Tekin Pro 4 HD 4300, Protek, VRP, Proline, Sanwa
TLR 22t 3.0 - Tekin Gen 3 8.5t, Protek, VRP, Proline, Sanwa
VANT LIPOS
mvrk28 is offline   Reply With Quote
Old 01-25-2015, 12:19 PM   #7232
So how big off a deal is it to change the diff in this buggy. Is there really a lot of screws to take out to get to the diff?
TLR 8ight 4.0 - Samurai 321b - Protek 150T servo's - MT-44
Rico54 is offline   Reply With Quote
Old 01-25-2015, 12:41 PM   #7233
Chiefy 707's Avatar
+ YouTube Video
Originally Posted by Rico54 View Post
So how big off a deal is it to change the diff in this buggy. Is there really a lot of screws to take out to get to the diff? Thanks
"It looks like a [insert car here]. It's just another [insert car here] clone!"
"Why did [insert manufacturer here] go with such a radical design? [insert manufacturer here] needs to stick with what works!" Shhhh, please.
HB/LRP/KO Propo/Protek/Associated/Tekno
Chiefy 707 is offline   Reply With Quote
Old 01-25-2015, 12:48 PM   #7234
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Its like 11 for the rear (plus 4 are around the center diff). About 11 for the front and top shock nuts (plus 4 are around the center diff). With only nine 5 min heats last night I pulled, changed fluid, and reassembled both diffs between runs with a cpl races to spare. Hands down the easiest buggy ever for diff changes is the DEX410 (which I own) and the D413s are not a pain to me.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 01-25-2015, 01:09 PM   #7235
Trader Rating: 21 (100%+)
Those are for the bottom of the shocks and are not, in anyway related to the bladder.... Cutting the bladder= emulsion style shocks
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is online now   Reply With Quote
Old 01-25-2015, 01:42 PM   #7236
Trader Rating: 120 (100%+)
I bought the Avid chassis and have not installed it yet as I have seen mixed reviews. I am thinking about getting the Schelle +4mm chassis but wanted some feedback on it first. So if anyone is running the chassis can you please give me some feedback. Thanks.
22-4
MBX7R Eco, RC8B3E
MBX7R. RC8B3
JoeC is offline   Reply With Quote
Old 01-25-2015, 02:12 PM   #7237
General consensus seems to be:
High to very high grip track=Avid chassis-stiffens car and takes away grip.
Low to medium grip track=Schelle chassis-lengthens car and calms down aggressive steering and improves jumping and stability.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 01-25-2015, 02:21 PM   #7238
skeasor's Avatar
Originally Posted by Chiefy 707 View Post
+ YouTube Video
Haven't seen that video yet but I've heard they're putting a 4wd buggy out in the market. What a unique design.
Support: http://bumpsandjumpsrc.com/, http://thehiddenhangar.com/, https://www.kranzelshobbies.com/, http://aerotechhobbies.net/
skeasor is offline   Reply With Quote
Old 01-25-2015, 02:36 PM   #7239
Chiefy 707's Avatar
Lol oh crap did I link the wrong video? I can't tell from my phone
Old 01-25-2015, 02:40 PM   #7240
Super Moderator
DRTMI's Avatar
Trader Rating: 27 (100%+)
Looks like it. The video you linked is for a Serpent.
A gun in the hand is better than a cop on the phone.
A 9mm might expand but a .45 will never shrink.
The gene pool needs a little chlorine.
DRTMI is offline   Reply With Quote
Old 01-25-2015, 03:09 PM   #7241
skeasor's Avatar
Hi guys,
I have one of these on order and was hoping someone could clarify this for me...I currently run a Losi 22 2.0 and have front wheels and tires already glued up for when I race 2wd buggy. Can I also use these on the D413? I found this on the first page of the thread but wasn't sure if they mean that the 22 2.0 or the 22-4 wheels. I'd also like to use the rears from my 22 2.0 as well. The less to take the the track the better
Kyosho, Associated, Losi, etc all have very similar offset for rears these days, and with the included 12mm hex, they should all work.
In the front, obviously D413 rims work, Losi 22 and 22-4 have the proper offset (22 rims are only 2mm narrower), and Associated 4WD fronts will work but end up in a slightly narrower width. Ty won the nationals with Associated offset rims, and has run 22 fronts since then. Kyosho 4WD fronts are very close and Yokomo 4WD fronts seem to work well too.
Old 01-25-2015, 03:44 PM   #7242
Originally Posted by DIRT DIGGER View Post
anyone know what size drill bit to use for 1.6 and 1.7 pistons?
I bought a set of these, cheap too.
http://www.amazon.ca/gp/product/B002...ilpage_o00_s00
GimpyGolden is offline   Reply With Quote
Old 01-25-2015, 03:52 PM   #7243
Originally Posted by skeasor View Post
Hi guys,
The rears will work fine. But 2wd front tires would be too narrow for a 4wd buggy. Sure, they'd fit, but you'd be giving up front traction under power, which is afterall, why we run 4wd. You should really get some actual 4wd front tires and wheels. Any wheel sold as 22-4 front wheels will work, using the included 12mm hexes.
Old 01-25-2015, 03:52 PM   #7244
Thank you very much sir. Gona order now. thanks
DIRT DIGGER is offline   Reply With Quote
Old 01-25-2015, 04:17 PM   #7245
Lol I was wondering what the deal was when I saw the video.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
