Like Tree28Likes
Old 01-20-2015, 12:09 PM   #7141
Originally Posted by MasiisaM View Post
I havent broken a wing mount yet...and haven't seen anyone else have an issue. I think any wing is going to tear no mater what you do.. I picked up a trifecta wing from proline and its built pretty tough. It's lasted quite a bit longer than the other wings i was using.
Somewhere back in the thread someone mentioned running an SWorks S104 wing so I ordered one. Easy fit and looks about 3 times thicker than the stock wing.
iScream is offline   Reply With Quote
Old 01-20-2015, 12:14 PM   #7142
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I run the sworkz wing. I run one on my B5M for club racing and practice. They last forever. My daughters is 6 months old.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-20-2015, 12:15 PM   #7143
Has anyone tried replacing the ball cups on the suspension links to remove slop? Or does anyone know a trick for tightening up the fit of the cups on the balls?
I think I'm going to remove the servo saver so it should be easy to find something less sloppy there but I'm not so sure about the camber and steering links.
I already have the RCShox ackerman bar installed but I really want to get some more slop out of it. Whether it makes a difference on the track or not it will make me feel better about the buggy.
-Chris
Old 01-20-2015, 12:17 PM   #7144
you could try the AE B5 ball cups. They are over engineered and take a while to get any slop.
Old 01-20-2015, 12:19 PM   #7145
TORQUE ROD's Avatar
Just an off topic question here. what is the best replacement for the
original servo saver?
TORQUE ROD is offline   Reply With Quote
Old 01-20-2015, 12:27 PM   #7146
From what I've read, most people either run the stock servo saver or remove it and go without one, as I intend to do.
Old 01-20-2015, 12:35 PM   #7147
OK, it was probably a post of yours that I saw. It's definitely beefy and I like that it's colored rather than clear.
Old 01-20-2015, 01:22 PM   #7148
Trader Rating: 129 (100%+)
Default schelle chassis
i installed the chassis over the weekend and was curious if anyone else has tried it. If so, what are your thoughts?
skyline1015 is offline   Reply With Quote
Old 01-20-2015, 02:14 PM   #7149
Slotmachine's Avatar
Send a message via MSN to Slotmachine
-Chris
Pop the cup off and place an empty parts bag or simular plastic over the ball stud and pop the cup back on, tear the rest of the bag off and it tightens up the slop without becoming too tight.
Paul
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 01-20-2015, 02:40 PM   #7150
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Interested as well. I have been eyeing it but there isn't much feedback out there.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 01-20-2015, 04:12 PM   #7151
i believe the tlr 22 clamping hexs will work seeing that the 22-4 rims are the exact same size and offset as the d413 rims. both front and rear
vanpaassen55 is offline   Reply With Quote
Old 01-20-2015, 06:39 PM   #7152
billdogg's Avatar
Trader Rating: 15 (100%+)
Originally Posted by jhautz View Post
Ran your setup at Rockford tonight. You are correct. Totally dialed. Steering is so reactive I had to slow my servo down. Once I did that it was on rails. By far the best this car has ever been for me. Thanks for the tip.
Had to try his myself. Went tonight for practice, and it's awesome!
billdogg is offline   Reply With Quote
Old 01-20-2015, 06:49 PM   #7153
what setup is it? can someone post this setup? thanks alot
DIRT DIGGER is offline   Reply With Quote
Old 01-20-2015, 07:23 PM   #7154
Dog Runner's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to Dog Runner
It's the Nationals setup but with 37.5/32.5 shock oil. A slight change I also liked was one hole in on the rear tower from what the setup says.
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
Old 01-20-2015, 07:29 PM   #7155
pm sent to u jr
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
