Like Tree29Likes
Old 01-14-2015, 06:56 AM   #7051
BLKNOTCH's Avatar
Send a message via MSN to BLKNOTCH
Originally Posted by phillypete View Post
Has anyone found an alternative aluminum servo horn?
It appears the hex on the stock servo saver stripped out while I was setting EPA (yeah I know!!!)
Has anyone tried running a standard servo horn and put the ball stud facing the front of the car?
Here you go, this is what you are after: https://www.hpiracing.com/en/part/67169
Just be careful as running without the servo saver you will run the risk of premature damage to the servo.
BLKNOTCH is offline   Reply With Quote
Old 01-14-2015, 07:06 AM   #7052
slakr's Avatar
Trader Rating: 28 (100%+)
I am using this... http://www.amain.com/xray-x-stiff-co...er-set/p219462
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 01-14-2015, 07:45 AM   #7053
luist99's Avatar
Send a message via MSN to luist99
Has anyone try adding weight to the carbon chassi
luist99 is offline   Reply With Quote
Old 01-14-2015, 09:33 AM   #7054
RENOV8R's Avatar
Wink
Like others have replied, TLR or HPI but with the ball facing the rear of the truck. This eliminates the goofy angle of the linkage when using the servo saver. As for being careful when not using a servo saver I don't think that is nearly as much of an issue in this day and age. Servos are much stronger and high quality that they used to be.
BTW I use the HPI horn because it's all shiny and gold
RENOV8R is offline   Reply With Quote
Old 01-14-2015, 09:53 AM   #7055
MasiisaM's Avatar
+1..
I did try though the TLR horn and the threads are different for the stock ball stud..so the ball stud didn't screw into the horn...I also had a HPI laying around and the stock ball stud went right in.
Plus it does look purdy...
TLR 22 2.0 - TLR 8E 3.0 - HB D413
Thanks to:
Tekin - www.teamtekin.com
Thunder Designs - www.thunderdesigns.net
MasiisaM is offline   Reply With Quote
Old 01-14-2015, 09:57 AM   #7056
ISH
ISH's Avatar
This is true. I recently got back into the hobby and was scared that i had no servo saver on my B5M lol. with titanium gears and what not in servos its not as much of an issue.
ISH is offline   Reply With Quote
Old 01-14-2015, 10:59 AM   #7057
My LHS didn't have the HPI in stock and they said delivery was "Mid January". with the stock servo saver on their it was in drivable. I'm not exactly sure how i did it but the hex was ever so slighly mangled at the corners of the hex impression. On a wheel hub no big deal, but on a servo saver a fraction of a mm is a deal breaker. When I turned left the steering would not re-center.
Needless to say those first couple laps were a durability test until I figured out what was going on!
Until the HPI horn arrives I've put s Racer's Edge aluminum horn on that I had laying around. The angle on the ball cup is a little troubling, but I don't foresee it being an issue.
www.beachrc.com
phillypete is offline   Reply With Quote
Old 01-14-2015, 02:41 PM   #7058
Dog Runner's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to Dog Runner
I put the Nats setup on this car with the only changes being running the wing in the high position and the shock oil of the Reedy Setup. Dialed.
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
Old 01-14-2015, 03:36 PM   #7059
Trader Rating: 15 (100%+)
What oils are you running
uncle everett is offline   Reply With Quote
Old 01-14-2015, 04:45 PM   #7060
jhautz's Avatar
Trader Rating: 85 (100%+)
Was that you running the all yellow D413 at Leisure Hours on Sunday?
jhautz is offline   Reply With Quote
Old 01-14-2015, 05:24 PM   #7061
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Ya, that was him in the fast puke yellow.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 01-14-2015, 08:19 PM   #7062
jhautz's Avatar
I was actually watching that buggy Sunday and was thinking it looked good. I may need to try that setup. Thanks for the tip.
Old 01-14-2015, 08:21 PM   #7063
Dog Runner's Avatar
Yep, that's my puke yellow car. Come on by and say hi any time.
That really is the most awful color on a RC car ever. Gotta change that pretty soon!
The oils I'm using are Associated 37.5 front with 2X1.6 and 32.5 rear with 2X1.7. The shock position of the Nats setup was great and I moved the rear tower in one hole as the track got more slippery and that seems to help it keep turning. The high wing also seemed to make it more stable with our big, fast track.
On a side note, I had an original B44 a long time ago and hated every second of it. Haven't had a wheeler since then. But this car is actually fun and I'm glad I gave 4wd another chance.
JR
Old 01-15-2015, 08:43 AM   #7064
I can guarantee I will be flamed for this but has anyone tried a 550 motor in this car? I read way back in this thread that the idea was thrown around but I don't believe it came to a definitive answer. I currently run a 10.5t 540 motor. However it does run somewhat warm and it lacks the power that my fellow racers have running 5.5t motors. Rather than going out and buying a new motor, I wanted to try running my old 4x4 sct motor. I know this sounds ridiculous but upon further inspection, my hobbywing 3656 sd motor is only a tad longer than the 540 that is currently in my car. I know that it could potentially be hard on the drivetrain but if I turn it down so it is equivalent to the other guy's 5.5t motors wouldn't it be fine? I understand this is not roar legal but I don't race at roar events. I am just trying to increase performance without harming my wallet. Thanks for any opinions
Xray XB9e- HW SCT-Pro, Savox, Turngy 2100kv
Mugen MBX6T- HW EZRUN 150a, Castle 2200kv, savox
xXblitzXx is offline   Reply With Quote
Old 01-15-2015, 08:51 AM   #7065
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
can you get a 48 pitch pinion on that motor?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
