Like Tree42Likes
Old 01-11-2015, 07:12 PM   #7006
Originally Posted by TYTESSMANN View Post
It's great to see that there is another D413 in Canada, unfortunately the setup in the manual is pretty old, at the time that setup was used we had only about a month on the car and we were still learning. By the description of the track I would start with my Gunsmoke setup on my website. As far as the AE shock springs go, I'm not sure why so many people like to use the AE springs, Torrance worked very hard at making the HB springs super consistent with very small weight increments between each spring to so you can basically get your car dialed in in any way you want. I would strongly suggest giving them a try, before we had the HB springs we used Kyosho springs but found the HB springs more consistent with a better feel on the track.
Make that 3, still building mine but impressed so far.
Other than reports of durability and good manners another reason I choose the 413 is it's run by a Canadian Pro driver.
Go Ty Woot!
Should have this thing o the carpet next week some time.
GimpyGolden is offline   Reply With Quote
Old 01-11-2015, 07:14 PM   #7007
Go Ty Woot!
theres two of us in Victoria , BC
Monkey#39 is offline   Reply With Quote
Old 01-11-2015, 07:24 PM   #7008
Originally Posted by kdeleon View Post
For all our talk here about how bad the stock shock caps are and how badly we need to replace them, it is interesting to see Ty post a pic of his cars and he is using the stock caps. Probably just for this race, but even he is using them again.
Is the 2wd in the above pic an HB prototype? If not what is it, looks like a lot of HB hardware on it.
Old 01-11-2015, 07:34 PM   #7009
Trader Rating: 15 (100%+)
Originally Posted by ProfessorX View Post
Any good recent set ups for indoor clay ?
.....hmmm reedy setup, gun smoke setup, NV setup
uncle everett is offline   Reply With Quote
Old 01-11-2015, 08:00 PM   #7010
hollywood3705's Avatar
Anybody know about the Gullwing rear arms? On the c rear tower option it says for use with Gullwing rear arms. Is it a mistake or a future option part? Or am I just not seeing the gull in the stock arms. Or if anybody can tell me how much lower the c tower is in relation to the stock.
hollywood3705 is offline   Reply With Quote
Old 01-11-2015, 08:06 PM   #7011
C tower is used when using the "2nd/bottom" hole on the rear hub. It changes your droop, the c tower lowers your shocks to give back the lost droop....at least that is how I understood Ty's comments here.
(Normal arms)
Old 01-11-2015, 08:10 PM   #7012
So the Gullwing they are referring to the hub height not a lower shock mounting location? Any idea how much lower the c tower is?
Old 01-11-2015, 08:17 PM   #7013
[QUOTE=hollywood3705;13776284]So the Gullwing they are referring to the hub height not a lower shock mounting location? Any idea how much lower the c tower is?[/
I don't. Less then distance between upper and lower holes....due to geometry of where on the arm the now lowered shock end attaches. Thus putting the out hinge pin that much lower.
Old 01-11-2015, 08:19 PM   #7014
Thank you. Just trying to get parts ordered for whenergy the buggy arrives
Old 01-11-2015, 08:25 PM   #7015
-Shock caps AE or HB
-kyosho springs or HB
-rear tower c
-carbon inserts arms
-7-100-3 diff fluids
-37/35 shock fluid
-traxxas xring orings
-aluminum servo horn
-spacers to raise ball studs
-spacers to create toe where arms attach.
-maybe additional inner hinge pin hangers and hinge pins
Old 01-11-2015, 11:10 PM   #7016
mdowney's Avatar
Trader Rating: 21 (100%+)
Looks like a Kyosho RB6 with CF towers, HB ball cups and shocks, and a custom chassis. I know X-Factory makes a CF chassis for the RB6 [edit: I'm wrong. The X-factory CF chassis is for the B5M] but I don't think that's it.
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 01-11-2015, 11:36 PM   #7017
Originally Posted by mdowney View Post
Looks like a Kyosho RB6 with CF towers, HB ball cups and shocks, and a custom chassis. I know X-Factory makes a CF chassis for the RB6 but I don't think that's it.
Are we talking about Ty's 2WD? You're half way there. Last time I saw a picture of it, it was RB6 front end paired with a Centro rear end. Chassis was ofc custom.
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is offline   Reply With Quote
Old 01-11-2015, 11:46 PM   #7018
ISH
ISH's Avatar
I'm in the middle of my build. if i run shorty would 10minute mains be an issue? should i run saddles?
sorry if this has been discussed before...
ISH is offline   Reply With Quote
Old 01-12-2015, 04:52 AM   #7019
No problem
Old 01-12-2015, 06:33 AM   #7020
snwchris's Avatar
Shortys are fine, just make sure you get like a 4000 or better. I have a 7.5T motor, 4200 and run 3mins of warmups and 7min Mains and still plenty left over.
snwchris is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
