Like Tree28Likes
Old 01-08-2015, 03:35 PM   #6976
Originally Posted by Tobiasmart View Post
Ronnefalks setup is for slicks. Tessman and Lowe have setups for pins. I Think the setups is a good starting point with stock chassis as well but The car is nervous and harder to drive with it on carpet.
Yep, I saw the tire types. I thought it was interesting that the Ronnefalk setup looks more like what I would expect for high traction. Low ride height and big sway bars. I think I'm going to go that direction myself. Maybe lean the castor angle back more by adding kickup as that's suppose to make a car easier to drive when traction is high.
-Chris
iScream is offline   Reply With Quote
Old 01-08-2015, 03:48 PM   #6977
Just got mine in the mail today. Didn't think it came because the box I saw was so small lol. Now just waiting on everything else to get here. Can't wait to get this thing on the track.
redneckhatch is offline   Reply With Quote
Old 01-09-2015, 10:26 AM   #6978
MasiisaM's Avatar
Been running Ty's Gunsmoke set up and enjoy it...I need just a touch more push so i moved the rear camber link to pos 1#. Felt the shock and seed to bind on the last part of the stoke..Like a bump stop.
I found that the ball cup kisses the camber plate pretty darn good. As you can see I still have a bit of travel left...When i fully compress the shock the ball cup pops.
Just FYI if you plan to use Pos #1.
TLR 22 2.0 - TLR 8E 3.0 - HB D413
Thanks to:
Tekin - www.teamtekin.com
Thunder Designs - www.thunderdesigns.net
MasiisaM is offline   Reply With Quote
Old 01-09-2015, 11:29 AM   #6979
im running my d413 on carpet I mix of ozite and low pile commercial grade carpet. Im using pin pionts 2 rows cut on the front on on the back with a slightly modified tessman setup and its great . also running goosebumps with good results
Monkey#39 is offline   Reply With Quote
Old 01-09-2015, 11:34 AM   #6980
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
mine hits too
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-09-2015, 11:54 AM   #6981
RENOV8R's Avatar
How much drag brake should i program into my ESC? 70% OK? I think I read that 100% is hard on the spur gear
RENOV8R is offline   Reply With Quote
Old 01-09-2015, 11:54 AM   #6982
Texas Racer's Avatar
I grounded the lower corner edges of my plate so it doesnt hit anymore. Dremel or #400 sand paper will both work.
Texas Racer is offline   Reply With Quote
Old 01-09-2015, 12:19 PM   #6983
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
[QUOTE=RENOV8R;13771816]How much drag brake should i program into my ESC? 70% OK? I think I read that 100% is hard on the spur gear[/QUOTE
On clay I run 5%. Some do run a bit more. Not saying its wrong, but 70% sounds crazy for tracks I'm on.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 01-09-2015, 12:32 PM   #6984
you can always lower the outside as opposed to raising the inside. should help with the binding
Old 01-09-2015, 03:36 PM   #6985
DWheels's Avatar
In most buggies 5 drag brake is pretty normal. Myself and others I race with use no drag brake or 5 push control on our d413s. The drive train already seems to have a high amount of drag on its own. The push control is to reduce some of the drag.
Tekin, Inc. - Team Yokomo - Protek RC - Factory-RC Products - Pro-Line Racing - Vision Racing Products - Avid RC - Max.FX - SOR Graphics
DWheels is offline   Reply With Quote
Old 01-09-2015, 03:42 PM   #6986
0 drag here
Old 01-09-2015, 07:21 PM   #6987
Trader Rating: 520 (100%+)
+1
flame56mx is offline   Reply With Quote
Old 01-09-2015, 07:29 PM   #6988
itsjusme's Avatar
Just take a dremel or a file and take the edge off the plate.
Ed Hawkins
itsjusme is offline   Reply With Quote
Old 01-10-2015, 12:46 AM   #6989
Are you using the C rear shock tower?
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 01-10-2015, 07:54 PM   #6990
Have any of you tried the 13.5 T motor on the buggy ? and if so, what pinion would any of you recommend for a medium to large clay tracks?
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
2004hdfxsti
