Like Tree31Likes
Old 01-06-2015, 09:14 PM   #6961
what effect will happen from moving the rear hubs from top hole to bottom hole
DIRT DIGGER is offline   Reply With Quote
Old 01-07-2015, 06:25 AM   #6962
symmetricon's Avatar
Trader Rating: 27 (100%+)
Going from the upper hole to the lower hole raises your roll center....
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 01-07-2015, 06:59 AM   #6963
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
I would guess that it also affects droop as well after after you re-adjust the ride height.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 01-07-2015, 07:39 AM   #6964
Originally Posted by Yeti AS3 View Post
I would think it affects droop as well after after you re-adjust the ride height.
The down travel measured at the shocks wouldn't change but the ride height would.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 01-07-2015, 09:17 AM   #6965
big greg's Avatar
Trader Rating: 119 (99%+)
Idk a guy here said he had to Dremel down your Ackerman to get it to the stock position. To get the car to settle down. I have not tried the Ackerman myself
Hot bodies d812e tekin T8 1700 rx8 gen 2
Hotbodies d815 o.s. speed Tessman ed
Hb/hpi racing, vp pro usa, Lutz rc, valvenous paint, tekin racing, rc addiction products/nitro pro fuel
Rip bill bridges
big greg is offline   Reply With Quote
Old 01-07-2015, 10:05 AM   #6966
Suspended
After changing to the lower hole the ride height would be lower. So when you raise the ride height back up the shock will be further extended, thus having less droop. There are a lot of adjustments that effect other things, and if you don't reset the other things it can throw your car way out of whack, or even negate the change that you just made.
Mantis Toboggan is offline   Reply With Quote
Old 01-07-2015, 01:34 PM   #6967
luist99's Avatar
Send a message via MSN to luist99
In what position is every one putting their wings at, and how many cuts.
luist99 is offline   Reply With Quote
Old 01-07-2015, 02:54 PM   #6968
for the center diff which would work better 60k or 100k for a loose track
Old 01-07-2015, 02:56 PM   #6969
Team Tekin
yzracer758's Avatar
Trader Rating: 18 (100%+)
60k for sure. Rule of thumb: Higher traction=Thicker center diff
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics | Carolina Custom Anodizing
Jeremy Potter
Tekin C.S. Manager
yzracer758 is offline   Reply With Quote
Old 01-07-2015, 04:03 PM   #6970
Texas Racer's Avatar
Thumbs up
SlotMachine...thanks for the tip..the buggy's drivetrain feels better now.
Texas Racer is offline   Reply With Quote
Old 01-08-2015, 06:03 AM   #6971
We're supposed to have indoor carpet racing starting up soon locally. I haven't seen the track layout but I know we'll be running carpet pin tires so I'm guessing it will be high traction.
I know about the Tessman and Ronnefalk carpet setup sheets and both are running the Avid chassis. Is there any point to using one of those setups as my baseline with the stock chassis?
Also, would anyone happen to know what Kyosho sway bars David Ronnefalk used and what he did to modify them?
Thanks,
Chris
iScream is offline   Reply With Quote
Old 01-08-2015, 06:10 AM   #6972
onekiwi's Avatar
Im going to test the saddle config soon.
We use the serpent 1/8 roll bars, both 1.8 and 2.0, they are easy enough to bendwith pliers
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 01-08-2015, 10:18 AM   #6973
Vinny Cancilla's Avatar
I've been running my low with 2 lines cut. I didn't notice a major difference from running it high. I think it jumped a little lower though. Does anyone know what the middle setting is for the wing? I know the low is the mount upside down and I assume the high is the stock setting.
Serpent Srx8
Serpent America: Triton engines/ Nitro pro.Fuel/ Rc Addiction products : Vp pro Usa/Dialed-Rc
Barnstormers: Chester, NY, N.Y.. IRH Lindenhurst
Vinny Cancilla is offline   Reply With Quote
Old 01-08-2015, 10:56 AM   #6974
I was wondering the same thing after looking at setup sheets. Didn't know there was a medium wing mounting height.
Old 01-08-2015, 12:43 PM   #6975
Tobiasmart's Avatar
Thanks,
Chris
Ronnefalks setup is for slicks. Tessman and Lowe have setups for pins. I Think the setups is a good starting point with stock chassis as well but The car is nervous and harder to drive with it on carpet.
Tobiasmart is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
