Like Tree42Likes
Old 01-06-2015, 11:20 AM   #6946
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by CarFanatic View Post
man I tried.... I could not get it in!
that is what she said
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-06-2015, 11:21 AM   #6947
RENOV8R's Avatar
yes, it depends on how much you trim it out. If you leave much of the lip on the side, you can't bend it enough to slide it in.
RENOV8R is offline   Reply With Quote
Old 01-06-2015, 11:40 AM   #6948
Trader Rating: 133 (100%+)
Originally Posted by Wildcat1971 View Post
I run the avid chassis. What dont you like?
It doesnt feel that great when running on a med bite dirt track.
skyline1015 is offline   Reply With Quote
Old 01-06-2015, 11:46 AM   #6949
I have run it on medium bite indoor and high bite indoor and liked it, but to each their own. But my medium bite track may have more traction than your medium bite track.
Old 01-06-2015, 12:16 PM   #6950
Vinny Cancilla's Avatar
Ty himself, said he would only use it on high bite tracks.
Serpent Srx8
Serpent America: Triton engines/ Nitro pro.Fuel/ Rc Addiction products : Vp pro Usa/Dialed-Rc
Barnstormers: Chester, NY, N.Y.. IRH Lindenhurst
Vinny Cancilla is offline   Reply With Quote
Old 01-06-2015, 12:25 PM   #6951
Texas Racer's Avatar
Originally Posted by nv529 View Post
Which orientation is the rack designed off of dot forward or rearward?
dot rearward
Texas Racer is offline   Reply With Quote
Old 01-06-2015, 12:30 PM   #6952
Loosen the four screws that hold the shock tower on, a lot, then slide it in from the front.
CaseyD is offline   Reply With Quote
Old 01-06-2015, 03:49 PM   #6953
offroad dude's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Texas Racer View Post
dot rearward
I wish it was built on the forward dot because the rearward dot make the car really twitchy and direct.
offroad dude is offline   Reply With Quote
Old 01-06-2015, 04:43 PM   #6954
kdeleon's Avatar
I believe that the RC Shox rack has even more Ackermann that the rearward dot. But let's assume it is the same as the standard one. All you need to do it is add 1 mm washers under the ball stud and it would be the same as the dot forward. Here is a good image that Nick Vasquez posted.
Hot Bodies D413 1/10 4WD Buggy-ackermann1.jpg
kdeleon is offline   Reply With Quote
Old 01-06-2015, 06:27 PM   #6955
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Thanks for that, thats exactly correct, you just add shims under the ballstud to put it as for forward as you like.
The RCShox ackerman is the same as rear dot with no shims installed, what you cannot see in the pictures is that there is a 1.5mm counterbore under the ballstud location.
MantisWorx is offline   Reply With Quote
Old 01-06-2015, 07:26 PM   #6956
Slotmachine's Avatar
Send a message via MSN to Slotmachine
yes, that is what the manuals say. It just not been what I feel on the track. Whenever, I move the stud back on the inside, my car gets more aggressive. And when I move it forward it pushes more. I have stopped reading those charts, because it is a give and take. And will make your head hurt after a while. I just try things and note how they make my car feel.
Anyway, I use the RCshox rack and did not notice any negative effects to my handling. The ackerman "looked" the same as the Tessman setup, so I did not really worry about it. The RcShox pistons and rack have worked really well. I am very happy with them.
the next time you set the ackerman forward try turning you steering down, with less ackerman you are turning the outside wheel more and causing the front end to scrub.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 01-06-2015, 07:48 PM   #6957
my D/R is at like 85%, lol
Old 01-06-2015, 08:01 PM   #6958
pballer2777's Avatar
Trader Rating: 27 (100%+)
what is the difference in the + and - on the ackerman arm?
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 01-06-2015, 08:40 PM   #6959
kdeleon's Avatar
Also on the first page of this thread:
Originally Posted by T. Deguzman View Post
the +/- raises and lowers the rack 0.5mm for bump steer adjustment. if the + is facing up it is higher, with the - facing up the rack sits lower. you can also put shims under the rack if you need more than 0.5mm..
Old 01-06-2015, 09:04 PM   #6960
thank you
