Hot Bodies D413 1/10 4WD Buggy >
Like Tree66Likes
Old 01-06-2015, 08:12 AM
  #6931
Trader Rating: 53 (100%+)
A small dab of shoo goo on the hex cross pins works well on this car. No need for clamping hexes.
nv529 is offline
Old 01-06-2015, 08:22 AM
  #6932
Trader Rating: 148 (100%+)
i used some blue locktite. worked for me as well
skyline1015 is offline
Old 01-06-2015, 08:28 AM
  #6933
Originally Posted by CaseyD
you have to loosen it significantly.
ugh!!!
CarFanatic is offline
Old 01-06-2015, 08:38 AM
  #6934
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by big greg
Careful the rc shox Ackerman pushes the. Ball stud forward creating more Ackerman then stock position, Making it more twitchy
No it does not unless you add more shims under the ball studs, if you install with no washers it is further back than stock. This is why there is a counterbore under the ball stud.
MantisWorx is offline
Old 01-06-2015, 08:39 AM
  #6935
MantisWorx's Avatar
Originally Posted by kdeleon
I don't think this is right. Moving forward means less ackermann and more aggressive steering. Moving it backwards means more ackermann and less aggressive steering.
http://www.rctech.net/forum/electric...l#post13614802
http://www.competitionx.com/rc-tuning-ackermann/
I agree with this
Old 01-06-2015, 08:43 AM
  #6936
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
yes, that is what the manuals say. It just not been what I feel on the track. Whenever, I move the stud back on the inside, my car gets more aggressive. And when I move it forward it pushes more. I have stopped reading those charts, because it is a give and take. And will make your head hurt after a while. I just try things and note how they make my car feel.
Anyway, I use the RCshox rack and did not notice any negative effects to my handling. The ackerman "looked" the same as the Tessman setup, so I did not really worry about it. The RcShox pistons and rack have worked really well. I am very happy with them.
Wildcat1971 is offline
Old 01-06-2015, 08:46 AM
  #6937
Default schelle chassis
so i know 1 guy on here has driven the buggy with the chassis. has anyone else tried with the chassis?
I have the Avid chassis and didnt like it all. Just wondering what everyone's take is
  #6938
MantisWorx's Avatar
I think its give and take with the settings one give aggressive initial steering and the other aggressive exit steering. It could depend on bumps steer and many other factors. but i do know that on an onroad car forward is aggressive.
Old 01-06-2015, 09:06 AM
  #6939
I run the avid chassis. What dont you like?
Old 01-06-2015, 09:17 AM
  #6940
RENOV8R's Avatar
Originally Posted by Anupam Das
Anyone know whats up with HPI Hotbodies and all the backordered parts. I checked Amain and like 30% of the parts are all back-ordered. Wanted an m3x20 screw, backordered. Front shock shaft: backordered. Steering rack: also backordered
Parts are all shown as "in stock" at Tower Hobbies. BTW I buy all my screws etc. at the local fasteners store.
RENOV8R is offline
Old 01-06-2015, 09:22 AM
  #6941
RENOV8R's Avatar
Originally Posted by CarFanatic
So I just finished up my kit. Cut out the rediculous body. Am I right in assuming you have to take apart the shock tower to get the front nose piece on?!!!!!
I can't believe people are comlaining about this! 4 screws and about 2 minutes. And it's not like you have to take it back out every time you remove the body
RENOV8R is offline
Old 01-06-2015, 09:24 AM
  #6942
Which orientation is the rack designed off of dot forward or rearward?
nv529 is offline
Old 01-06-2015, 09:25 AM
  #6943
+1 ordered a bunch of spares from tower on the weekend. Everything I wanted was in stock
robbie_gtc is offline
Old 01-06-2015, 09:30 AM
  #6944
snwchris's Avatar
On mine I'm able to twist and slide the nose cone in place. Its not that difficult.
snwchris is offline
Old 01-06-2015, 09:59 AM
  #6945
man I tried.... I could not get it in!
