Like Tree35Likes
Old 01-05-2015, 04:25 PM   #6916
Originally Posted by gotspeed24 View Post
thanks jason
anytime
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 01-05-2015, 04:38 PM   #6917
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Originally Posted by robbie_gtc View Post
Snapped the rt front shock shaft right at the lower mount. Yard sale'd the spring and spring cup. Appears it snapped right at the lower droop notch. Has anyome else had this happen? Could this be a potential weak spot with the shocks being right out front? Why did HB's not etch the shafts instead of notchimg them?
A guy at my track snapped his shaft in the exact same location over the weekend.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 01-05-2015, 05:07 PM   #6918
Trader Rating: 520 (100%+)
Hmm, out of the ten D413's running up here, I haven't seen that happen..But like Jason said, being the first thing to contact any object that is motionless I would say that stuff's going to happen. I am very impressed with this cars durability having run quite a few different brands in the past, so far it stands alone in that dept...
flame56mx is offline   Reply With Quote
Old 01-05-2015, 05:19 PM   #6919
big greg's Avatar
Trader Rating: 119 (99%+)
Careful the rc shox Ackerman pushes the. Ball stud forward creating more Ackerman then stock position, Making it more twitchy
Hot bodies d812e tekin T8 1700 rx8 gen 2
Hotbodies d815 o.s. speed Tessman ed
Hb/hpi racing, vp pro usa, Lutz rc, valvenous paint, tekin racing, rc addiction products/nitro pro fuel
Rip bill bridges
big greg is offline   Reply With Quote
Old 01-05-2015, 06:54 PM   #6920
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Isnt forward less ackerman?
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 01-05-2015, 07:35 PM   #6921
trx450racer174's Avatar
My car has been bullet proof so far. Loving it every time I put it on the track.
E.K.D. RC Paint Work
Team Serpent USA, Desoto Racing , Team DE Racing, Team Hitec, Team Trakpower, Futaba, Team AKA, TrackstarRC.
trx450racer174 is offline   Reply With Quote
Old 01-05-2015, 07:36 PM   #6922
Unfortunately I also had my first breakage..... coming through a rythym section a marshall dropped a 4wd SCT directly infront of me. With no time to turn or stopped I slammed into him. Snapped the rt front shock shaft right at the lower mount. Yard sale'd the spring and spring cup. Appears it snapped right at the lower droop notch. Has anyome else had this happen? Could this be a potential weak spot with the shocks being right out front?
Between my son and I we broke 4 front shock shafts in 2 days. However I agree with Jason I don't think they are a weak spot, I feel it was more our fault for the droop we were running, I had them set at the first line above the threads. After measuring the stroke length then comparing to Tessmans set up we were running a full 2mm more stroke. I have some new shafts on the way, and will be setting the proper stroke, should eliminate the issue.
CaseyD is offline   Reply With Quote
Old 01-05-2015, 07:39 PM   #6923
Trader Rating: 52 (100%+)
So I just finished up my kit. Cut out the rediculous body. Am I right in assuming you have to take apart the shock tower to get the front nose piece on?!!!!!
Mugen MBX7R
Mugen MBX7R Eco
Losi 5ive
CarFanatic is offline   Reply With Quote
Old 01-05-2015, 08:04 PM   #6924
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
moving it forward calms it down. more rearward is twitchy.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 01-05-2015, 08:08 PM   #6925
you have to loosen it significantly.
Old 01-05-2015, 08:39 PM   #6926
Originally Posted by Jason Snyder View Post
he cuts the center out of the bladder.
I wouldnt call it a weak spot...but the shocks are clearly vulnerable being out in front....other platforms have been notorious for breaking front shock shafts in violent collisions.......
I built mine with no bladders. I used b5 shock caps and put some spare cap o-rings from my AE rides on and tightened down the cap. No leaks and easier to bleed. Imo anyways.
Coming from a B44 used to the towers and arms being out front of the shocks. Kinda preferred it actually. Arms are cheaper and quicker to replace then pulling a shock body apart. guess I was just curious if others were having similar breakage.
Thanks Jason, always watching and rewatching your you tube vids.
robbie_gtc is offline   Reply With Quote
Old 01-05-2015, 08:56 PM   #6927
kdeleon's Avatar
I don't think this is right. Moving forward means less ackermann and more aggressive steering. Moving it backwards means more ackermann and less aggressive steering.
Hot Bodies D413 1/10 4WD Buggy
http://www.competitionx.com/rc-tuning-ackermann/
kdeleon is offline   Reply With Quote
Old 01-06-2015, 12:07 AM   #6928
Default D413 parts backorders
Anyone know whats up with HPI Hotbodies and all the backordered parts. I checked Amain and like 30% of the parts are all back-ordered. Wanted an m3x20 screw, backordered. Front shock shaft: backordered. Steering rack: also backordered
Anupam Das is offline   Reply With Quote
Old 01-06-2015, 02:19 AM   #6929
This car is great, but i wish i'd bought an XB4. Parts are really hard to get
ColourGhost is offline   Reply With Quote
Old 01-06-2015, 07:16 AM   #6930
ironzgti35's Avatar
Trader Rating: 20 (100%+)
Anyone know of clamping hexes that fit? I'm doing an Avid order this week and they make a bunch for different platforms if I could just add them to the order it would be ideal.
HB Racing Proline Sweep Racing USA - PT RC Racing Oils
ironzgti35 is offline   Reply With Quote
