Like Tree28Likes
Old 01-04-2015, 07:17 PM   #6901
Trader Rating: 130 (100%+)
Originally Posted by snwchris View Post
Get the #3 aggressive knuckle plate and still had tight steering
Can you take some pics with the chassis installed?
skyline1015 is offline   Reply With Quote
Old 01-04-2015, 08:37 PM   #6902
Trader Rating: 24 (100%+)
Default Slop
Originally Posted by Texas Racer View Post
Any suggestions on how to remove the slop ? many thanks..
I use xb4 short bushings on the spindles and ackeman, the hole on all the bushing goes are 4.6mm, xray bushings are 4.5mm, stock hb bushings are 4.3, my only slop now are the turn buckles and arms, ill be using xray turn buckles and balls soon
blacktop20valve is offline   Reply With Quote
Old 01-04-2015, 08:49 PM   #6903
YoG
YoG's Avatar
What's the part number for those bushings
XRAY XB2ce/AE T5M/HB D413/TEKNO SCT410
http://www.corvictoria.com/
YoG is offline   Reply With Quote
Old 01-04-2015, 09:43 PM   #6904
Yog your sure showing alot of intrest in the d413 :-)
anyone having issues with the 'o' rings in the diff leaking ? is there a fix ?
Monkey#39 is offline   Reply With Quote
Old 01-04-2015, 10:43 PM   #6905
YoG
YoG's Avatar
LOL I sure am. I think I'm getting that buggy feeling inside you know.Did you grease or green slime your o-rings prior to install?
Old 01-04-2015, 10:49 PM   #6906
yeah I seem to remember there being an upgrade for it posted like a year ago
Old 01-04-2015, 10:55 PM   #6907
Default Bushing
xra 362290
Old 01-04-2015, 11:32 PM   #6908
Trader Rating: 8 (90%+)
Sweet looking ride there buddy.You did rock out tonight.
Thanks Glenn.
Join the HB - Tekno Alliance.
Boostgod is offline   Reply With Quote
Old 01-05-2015, 05:06 AM   #6909
Texas Racer's Avatar
Thanks Blacktop20valve for the reply...will get the xray bushings asap..
Texas Racer is offline   Reply With Quote
Old 01-05-2015, 06:10 AM   #6910
snwchris's Avatar
I'm still running stock Orings and have rebuilt the shocks a couple times with no issues of leaks and no diff issues as well.
snwchris is offline   Reply With Quote
Old 01-05-2015, 06:21 AM   #6911
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Can anyone running on tacky high bite clay let me know what they are running for droop?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-05-2015, 01:39 PM   #6912
gotspeed24's Avatar
Trader Rating: 38 (100%+)
i noticed on ty's reedy setup that hes running no bladder. does that mean no bladder at all? or is the bladder just cut out? if its entirely without bladder, would there need to be a seal between cap and shock body? thanks in advance
gotspeed24 is offline   Reply With Quote
Old 01-05-2015, 01:54 PM   #6913
Had my buggy out for the first time yesterday runmimg some practice. After adding a stiffer spring up front and a tire change i was able to put down some decent laps.
Unfortunately I also had my first breakage..... coming through a rythym section a marshall dropped a 4wd SCT directly infront of me. With no time to turn or stopped I slammed into him. Snapped the rt front shock shaft right at the lower mount. Yard sale'd the spring and spring cup. Appears it snapped right at the lower droop notch. Has anyome else had this happen? Could this be a potential weak spot with the shocks being right out front? Why did HB's not etch the shafts instead of notchimg them?
Otherwise can't wait for my rcshox pistons amd ackerman plate to come in and run it at our winter series opener this weekend
robbie_gtc is offline   Reply With Quote
Old 01-05-2015, 01:59 PM   #6914
he cuts the center out of the bladder.
I wouldnt call it a weak spot...but the shocks are clearly vulnerable being out in front....other platforms have been notorious for breaking front shock shafts in violent collisions.......
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 01-05-2015, 02:13 PM   #6915
gotspeed24's Avatar
thanks jason
