Like Tree35Likes
Old 12-30-2014, 07:32 PM   #6811
Originally Posted by kerby View Post
Keep the same.. I've been using them for weeks, awesome feel! 1.6 front and rear...red front yellow rear.... 37.7/30 losi
sent u message
DIRT DIGGER is offline   Reply With Quote
Old 12-30-2014, 07:55 PM   #6812
billdogg's Avatar
Trader Rating: 15 (100%+)
I'm running Ty's national setup, and it's working great. The only thing that could be improved in mid corner steering. Buggy turns in good, and exits nice, but it's a bit lazy mid turn. What can I start adjusting to try?
billdogg is offline   Reply With Quote
Old 12-30-2014, 08:06 PM   #6813
what type of track u running on bill?
Old 12-30-2014, 08:07 PM   #6814
billdogg's Avatar
Hard packed dirt/clay indoor. Medium bite.
Old 12-30-2014, 08:15 PM   #6815
im running on the same type of track i just put that national setup on my car havent ran it yet tho had the reedy setup on before
Old 12-30-2014, 10:18 PM   #6816
anyone have any issues with the front shock shafts? We have had the cars out twice and have been through four shafts already? We built them with the shock end unscrewed down to the top of the threads, I'm thinking we need to be screwing them all the way to the second line?
CaseyD is offline   Reply With Quote
Old 12-31-2014, 06:46 AM   #6817
RENOV8R's Avatar
Good morning, first post on this forum. Race 1/5 scale in the summer and 1/8 buggy in the winter. In the last year, most of our indoor tracks have banned 1/8 buggies as they are too hard on the tracks, so I just picked up a 413. Browsed the interweb and found this thread and must say, glad I did. I'd already built the buggy according to what I've learned over the years and after going through this thread (skipped the first 100 pages of BS LOL) I've now got a "to do" list of about 35 items that need to be changed or tweaked. Worked on it 'till about midnight and here's what I've got so far:
Had some saddle packs so set it up that way, but after reading this it's now changed to shorty setup
Shocks: emulsion with Traxxas x-Rings, AE blue front springs & white rear. Have AE composite caps and standoffs but waiting to see if I have any problems with the stock ones popping off first.
Diffs: 10K, 80K, 7K front to rear
Plastic a-arm covers glued and front inside screw removed
2 degrees toe-out in front, rear - 2.5 degrees in
Battery - TrackPower 4600 mah 80 C shorty
Motor - Tekin Gen 2 6.5
ESC - Tekin RS Pro
Spektrum Sr3100 RX & DX3R Pro TX
Tessmans set up as per manual for now.
Figure this should be a good starting point until I get to the track and feel things out but if you have any suggestions, let me know.
Track is fairly small medium bite clay, tight and technical. All the guys there are running Losi, AE and the odd Durango but nobody has a D413. I think they're in for a BIG surprise!! Cheers, Tim
RENOV8R is offline   Reply With Quote
Old 12-31-2014, 08:31 AM   #6818
TYTESSMANN's Avatar
It's great to see that there is another D413 in Canada, unfortunately the setup in the manual is pretty old, at the time that setup was used we had only about a month on the car and we were still learning. By the description of the track I would start with my Gunsmoke setup on my website. As far as the AE shock springs go, I'm not sure why so many people like to use the AE springs, Torrance worked very hard at making the HB springs super consistent with very small weight increments between each spring to so you can basically get your car dialed in in any way you want. I would strongly suggest giving them a try, before we had the HB springs we used Kyosho springs but found the HB springs more consistent with a better feel on the track.
Xray, RC America, Proline Racing, O.S. Engines, Orion, Hudy, MKS, A Main Hobbies, Muchmore, Avid, Lunsford, 110% Racing, MR33, Live RC, Red RC, www.tytessmann.com
TYTESSMANN is offline   Reply With Quote
Old 12-31-2014, 08:36 AM   #6819
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Does that set up have the rear camber link in the front hole on the plate and the top inside hole on the rear hub? When I made that adjustment it made the car faster in the corners.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 12-31-2014, 08:40 AM   #6820
When you screw on the shock eyelet are you holding the shock shaft with side cutters on the threads? I have seen issues with other shafts breaking when being held like that.
Old 12-31-2014, 09:22 AM   #6821
RENOV8R's Avatar
Thanks for the advice, I'll start with the HB springs. As for the manual setup, I was basically only referring to spacers. But yeah, I do have 3 or 4 more up to date set up sheets that I'm going to try. Can't wait to get to the track, just waiting for the body to get back from painting and do a bunch of soldering this weekend.
BTW I've seen some posts saying this car is hard to work on. I changed the whole set up from saddle to shorty last night in roughly 1 hour. I find it fairly easy to work on. Hard is replacing tranny gears on a Baja 5SC
Old 12-31-2014, 09:43 AM   #6822
RENOV8R's Avatar
[QUOTE=Wildcat1971;13613120]they are the traxxas blue ones.
I use these. A few other members have also used them with out issues.
I hate buying a whole rebuild kit just for the o-rings, but the bonus is they come with a bunch of .5 mm spacers that you can use for tuning also. They just aren't the pretty orange ones
Old 12-31-2014, 10:10 AM   #6823
When I screw on eyelets I use a pair of needle nose that have a smooth area just behind the grooved section so I don't score the shaft. I'm guessing we just need to be screwing them on a little deeper.
Old 12-31-2014, 10:15 AM   #6824
billdogg's Avatar
Yes and yes. #2 on both locations.
Old 12-31-2014, 01:37 PM   #6825
anyone having much luck with the gunsmoke setup?
