Like Tree28Likes
Old 12-28-2014, 06:02 PM   #6766
Fastforward's Avatar
Originally Posted by nv529 View Post
Are you using a aluminum pinion? I'm running harden steel TLR pinions. My buggy is quiet.
Using Robinson steel pinions.
Bob DeGood
AKA Big Bad Bob
AKA BBB
Fastforward is offline   Reply With Quote
Old 12-28-2014, 06:38 PM   #6767
hi has anyone used the nationals setup yet on a med grip track? im running the reedy setup but thinking about changing to the nationals setup any suggestions if ur running the setup?
DIRT DIGGER is offline   Reply With Quote
Old 12-28-2014, 07:54 PM   #6768
ProfessorX's Avatar
Trader Rating: 17 (100%+)
Can I run AE x ring on the d413 the clear ones ????
ProfessorX is offline   Reply With Quote
Old 12-28-2014, 08:00 PM   #6769
kdeleon's Avatar
Yes, I ran them before. But others have reported that they leak. For me, they leaked on my first build. But after they swelled, they did not leak in subsequent builds. I have since changed to the Traxxas xrings. They are smooth and don't leak from the start. I would recommend those instead.
kdeleon is offline   Reply With Quote
Old 12-28-2014, 08:44 PM   #6770
ProfessorX's Avatar
Will the kyosho leak too ?
Old 12-28-2014, 08:46 PM   #6771
i run the kyosho and have no leaks with them.
Old 12-28-2014, 08:53 PM   #6772
ProfessorX's Avatar
Where can I find the kyosho x gear rings Amani don't have them
Old 12-28-2014, 09:02 PM   #6773
i got mine from ebay i just checked for you and there a bunch on there.
Old 12-28-2014, 09:35 PM   #6774
Suspended
YGPM
Mantis Toboggan is offline   Reply With Quote
Old 12-28-2014, 10:25 PM   #6775
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
for medium grip, try ty's setup from the gunsmoke classic.
RC*PHREAK is offline   Reply With Quote
Old 12-29-2014, 01:39 AM   #6776
nanoverse's Avatar
Haven't tried the X-rings yet but one more option are the Durango blue o-rings. Use them with the stock shim in the middle and they are smooth. Way better than the stock red ones in term of smoothness.
HB E817 | HB D815e | HB D413
Hitec Lynx 4s
nanoverse is offline   Reply With Quote
Old 12-29-2014, 02:18 AM   #6777
May be the tooth profile? I had some Robinson pinions that always sounded rough, changed to RW or Schumacher and much quieter. Might be worth a try?
TobyStephenson is offline   Reply With Quote
Old 12-29-2014, 08:53 AM   #6778
is there any difference between the front and rear sway bar sets? if so i wasnt sure which one is which or how to tell the difference?
Old 12-29-2014, 08:54 AM   #6779
Trader Rating: 129 (100%+)
front and rears are the same. each color represents how stiff they are. check out the link below
http://www.petitrc.com/setup/hotbodi...413_Charts.pdf
skyline1015 is offline   Reply With Quote
Old 12-29-2014, 08:56 AM   #6780
ok thanks just wanted to make sure fronts and rears were the same thanks
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
Buckland
