Like Tree35Likes
Old 12-23-2014, 02:35 PM   #6691
So i ran mine a couple times and i was taking it easy for two reasons. one i did not use the proper connectors, i decided to use deans plugs and the body did not fit on because too much cable bunching up. other was i was using the losi 22r front 2wd tires. ive since ficed those issues but is it just mine or is this thing loud? mine is almost as loud as my Losi SCTE in regards to the diff. I am using a steel pinion gear, should i get an aluminum one to see if that makes it a little quieter?
Nisstyre is offline   Reply With Quote
Old 12-23-2014, 04:17 PM   #6692
JDJamminX1's Avatar
I would keep using the steel, the aluminum has been known to strip the spur gear. Its not the center gear making all noise, just the whole drive train resonates sound more then other cars. Its better noisy anyways, makes people scared of you...lol
LRP - MUGEN - AKA - OCRC - UPGRADE - SCHELLE - DE RACING
JDJamminX1 is offline   Reply With Quote
Old 12-23-2014, 05:15 PM   #6693
Just curious from those that have tried it. I see a lot of guys are running forward swept arms, would this be similar to running the +4 chassis without the forward swept arms? Just curious if these would have similar effects. Thanks!
AMorgan is offline   Reply With Quote
Old 12-23-2014, 07:28 PM   #6694
I don't remember reading anything about aluminum pinions stripping spur gears more than steel. Why would a 48P aluminum pinion be any different than a 48P steel when it comes to wearing or stripping spurs?
I thought the stripped spurs were mostly from improper mesh or the motor moving after mesh was set.
-Chris
iScream is offline   Reply With Quote
Old 12-23-2014, 07:33 PM   #6695
Trader Rating: 520 (100%+)
-Chris
I wouldn't say aluminum pinions strips the spur, but more it tends to wear both pinion and spur more quickly causing a shorter life span for both. At least that is what I have found in the past..
flame56mx is offline   Reply With Quote
Old 12-23-2014, 07:47 PM   #6696
kdeleon's Avatar
-Chris
I believe it was one of the early theories of why spurs were stripping before most now believe just to be a mesh or movement issue. I believe it happened to one person using an older pinion. So it was recommended to use steel as it lasts longer. But aluminum will work fine. I started with a new one and both pinion and spur still look new.
I believe Ty Tessman said he recommends steel. But he also said to use a new one with each new spur.
New seems to be key. If your pinion is worn, I bet steel or aluminum, there will be a problem.
kdeleon is offline   Reply With Quote
Old 12-23-2014, 08:20 PM   #6697
YoG
YoG's Avatar
You are correct.Hardend steel pinion should always be new when using a new spur gear.I remember TY stated that
XRAY XB2ce/AE T5M/AE SC5M/HB D413/TEKNO SCT410
http://www.corvictoria.com/
YoG is offline   Reply With Quote
Old 12-23-2014, 08:32 PM   #6698
Hmm, it seems odd to me that an aluminum pinion would wear a plastic spur more than steel. But, I guess I'm kinda talking theory here so I certainly won't argue with your actual experience.
I'm sure the quality/hardness of the materials as well as the precision of the machining plays a large part in it but I wouldn't know where to begin comparing one manufacturer to another when it comes to all that.
-Chris
Old 12-23-2014, 08:38 PM   #6699
That makes sense. In my opinion, for this specific kit, the best advice I've seen is watch for a high spot on the spur when you set your mesh. If you set your mesh at a random spot and don't check through a full rotation you can easily end up too tight or too loose overall, causing excessive wear.
-Chris
EDIT: A second part of that should be to always use thread lock on your motor mount screws when the mount is metal.
Old 12-23-2014, 08:59 PM   #6700
luist99's Avatar
Send a message via MSN to luist99
Mine was really loud until I found out that the shim inside the diff were in the wrong side causing a tight mesh. I also bought more to separated even more.
luist99 is offline   Reply With Quote
Old 12-23-2014, 09:27 PM   #6701
warpainter's Avatar
my car was really loud so i went re shimmed the diffs and put some mobil one red grease on them now the car is whisper quiet.
RC AMERICA, XRAY, WARPAINT, LEISURE HOURS HOBBIES, DLP PHOTOGRAPHY
warpainter is offline   Reply With Quote
Old 12-24-2014, 06:26 AM   #6702
Fastforward's Avatar
Can you provide more information on how to shim to reduce noise please?
Bob DeGood
AKA Big Bad Bob
AKA BBB
Fastforward is offline   Reply With Quote
Old 12-24-2014, 07:01 AM   #6703
luist99's Avatar
If you look at the instruction for the front and rear diff in the book shows to put the shim on the side of the screws. You just switch them to the other side on the bearing and if possible add more.
Old 12-24-2014, 07:36 AM   #6704
Thanks. Now I have a project for the Christmas break.
Bob DeGood
AKA Big Bad Bob
AKA BBB
Old 12-24-2014, 08:28 AM   #6705
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Are you shimming the gears closer or farther apart?
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
2004hdfxsti
