Hot Bodies D413 1/10 4WD Buggy
#6676
#6677
I have had a lot of requests for a setup for slicks on Ozite, high grip. I don't know how high the grip on my carpet is compared to others around the world but this is the setup we have come up with. It's easy to drive and it's very stable.
http://www.tytessman.com/setups/pdf/...arpet-d413.pdf
Also the Gunsmoke setup is fixed on my site now, all the information is there.
#6679
Thanks Ty! Very close to the setup I run with slicks on carpet. The only thing missing in the setup is the rear lower shock mount position.
Do you always use the standard (B) rear shock tower?
#6680
#6681
Sorry about that, the rear lower shock mount position is the inner hole on the arm, whenever we raise the rear hub we use the "c" shock tower, if you don't the droop and the up travel aren't right. The "c" shock tower was made specifically for using the hub in the up position (lower hole). I will get the setup sheet updated with this info.
As far as the Avid chassis goes it keeps the chassis from rolling (keeps the chassis flatter), I know people have talked on here about the extra weight but we have tested by adding weight to the stock carbon chassis and it's definitely not the weight it is the stiffness. For me it makes the car more stable and generates less grip, I would use it on high grip tracks only.
I've never used the Schelle chassis.
#6683
I'm pretty sure the the alum caps are at HPI/Hot Bodies right now........As far as i know, Hobbico hasnt placed an order for these caps yet. The fact is we need to pressure Hobbico/Great Planes to order them.
HPI cant force the distributors to place orders......this situation is a real bummer and is one of the major downsides of having exclusive contract with a major distributor.
Basically, they have that part number in their system, but there is no expected arrival date. Once there is a date then we will see it entered into Tower's system.
Doesn't really clarify things. It seems like we are still stuck somewhere between HPI and Hobbico.
#6684
Reedy setup is $ with B tower (stock), can't wait to try it with the C tower.
#6685
It may take some time to get them in, but I appreciate the great customer service email from Tower Hobbies today and they now have the Hot Bodies D413 Aluminum Shock Caps listed for backorder: HB part #114112; Tower item #LXEYVD
#6686
uncle everett, I found TY's ROAR Nats setup at SpaceCoast to be even better than the Reedy. Made the car more agressive and had more steering. (good for tight tracks like the one I race at). The Reedy setup was easier to drive. When I was running the reedy setup, I was in the A. When I ran the nats setup, I started winning the A. Check out the differences in his setup between the two and you can see some of the changes like flattening out the kickup in the front, removing the bumpsteer shims, adding coppter swaybars in front...etc
http://www.petitrc.com/setup/hotbodi...coa2014081914/
#6687
has anyone tried running the carbon arm inserts (F/R) or R only or F only.?
How does this compare to the stock plastic inserts. What does it do to the car other than make it look extra dialed?
#6690
