Like Tree28Likes
Old 12-20-2014, 08:04 AM   #6646
Trader Rating: 52 (100%+)
Doesn't ty use the hb one?
CarFanatic is offline   Reply With Quote
Old 12-20-2014, 10:03 AM   #6647
anyone using the reedy race setup excatly? im just wondering how its gona be just finished up this setup.
DIRT DIGGER is offline   Reply With Quote
Old 12-20-2014, 10:41 AM   #6648
Trader Rating: 15 (100%+)
uncle everett is offline   Reply With Quote
Old 12-20-2014, 01:32 PM   #6649
Originally Posted by uncle everett View Post
thank you sir. what type of track are u running on?
Old 12-20-2014, 03:27 PM   #6650
Leisure Hours. Medium to high bite clay. Full pin clay compound tires.
Old 12-20-2014, 04:06 PM   #6651
Trader Rating: 8 (90%+)
I just got the kit. Quick question,
I run at an indoor carpet track. I'm about to start the build but was wondering if I should start off with the kit setup or should I skip right to the tessman carpet setup?
I ordered everything to duplicate his setup exactly.
What would you do? Run it stock first of just go with the tessman right of the bat?
Boostgod is offline   Reply With Quote
Old 12-20-2014, 04:34 PM   #6652
Team Tekin
yzracer758's Avatar
Trader Rating: 17 (100%+)
Start with his carpet setup. The stock setup will be much to soft for carpet.
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics | Carolina Custom Anodizing
Jeremy Potter
Tekin C.S. Manager
yzracer758 is offline   Reply With Quote
Old 12-20-2014, 04:51 PM   #6653
Thanks. I'll be patient and wait for the oils and setup specific stuff to arrive.
Old 12-20-2014, 05:56 PM   #6654
When adjusting a gear diff how much of a difference in oil weight is necessary to feel a difference? 5K 10K 20? This will be our first go round with gear diffs. Thanks.
CaseyD is offline   Reply With Quote
Old 12-20-2014, 06:46 PM   #6655
kdeleon's Avatar
If you are anxious, I think the key piece will be the Avid aluminum chassis. Maybe diff oils too as both are harder to change. But shock oils and pistons you can go with something, even though might not be correct, simply because they are much easier to change. Like the pistons I feel are so easy to change here because they use a nut instead of an e clip. The chassis is just a major change later.
kdeleon is offline   Reply With Quote
Old 12-20-2014, 07:02 PM   #6656
luist99's Avatar
Send a message via MSN to luist99
So apparently my buggy was really lound, I found out that The spacer on diff's were in the opposite side causing the diff and pinion gear to be really close. I bought some more shims to really separated them. She'll be nice and quite
luist99 is offline   Reply With Quote
Old 12-20-2014, 07:12 PM   #6657
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I installed the avid chassis with the brass weight in the rear and the aluminum one up front and the car is faster on the same layout. I think I will try to add some more weight and see if it gets even better. I was only 1/10 of a second from fast lap........
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 12-20-2014, 08:41 PM   #6658
tom2tone's Avatar
Trader Rating: 98 (100%+)
So I snapped my stock akerman tonight racing.. Luckily another racer let me use his CF ackerman from his 44.3 and I retro fitted it. What replacement do you guys recommend? Anyone have experience with the Rc Shox ackerman?
Thanks in advance
TEKNO EB48.3 / ET48
AE T5M & B6
Tekin / AKA / Hitec / SMC / Futaba
Trains and Lanes Racing http://tandlracing.com/
Dunn Raceway Park http://drprc.com
tom2tone is offline   Reply With Quote
Old 12-20-2014, 09:07 PM   #6659
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I use the rcshox and it works great
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 12-20-2014, 09:15 PM   #6660
tom2tone's Avatar
Thanks! what material is the ackerman made of? Its hard to tell on the website.
TEKNO EB48.3 / ET48
AE T5M & B6
