Hot Bodies D413 1/10 4WD Buggy >
Like Tree66Likes
Old 12-15-2014, 09:38 PM
  #6556
nanoverse's Avatar
Originally Posted by Monkey#39
Finally got to run my this past weekend.. im running stock springs, stock oils and the thickest bars front and rear the front end is REALLY soft, turning on power im lifting the inside front tires.. Im thinkning on going up in oil .. Whats the heaviest spring for the car (doesnt matter brand )
Should mention indoor carpet track
Ronnefalk is running 1.6mm sways. Modded Kyoshos, haven't found part# yet to try.
nanoverse is offline
Old 12-15-2014, 10:13 PM
  #6557
sorry I was looking for shock springs.. but thanks for the sway bar info
Monkey#39 is offline
Old 12-15-2014, 11:22 PM
  #6558
MrLesac's Avatar
Trader Rating: 29 (100%+)
Got my car last week and was able to finish up painting the body today.
Having not even driven the car, im already impressed. fits together well, looks very strong, and the 4 piece body, although a pain to paint and trim, looks awesome!
here are a few pics, I just need a new servo horn and then it will be time to hit the track.
and one with my RB6, Im part of the rare "painted wing crew" lol
MrLesac is offline
Old 12-16-2014, 03:38 AM
  #6559
Xray (xb4) 3 dot - I use those both on front and rear (also running carpet medium grip)
ColourGhost is offline
Old 12-16-2014, 04:47 AM
  #6560
symmetricon's Avatar
Trader Rating: 27 (100%+)
Originally Posted by travymoto11
Nice.
symmetricon is offline
Old 12-16-2014, 04:48 AM
  #6561
Also nice, haha
Old 12-16-2014, 05:16 AM
  #6562
snwchris's Avatar
Originally Posted by DIRT DIGGER
anyone running that ready setup on there d413? if so what u thinking about it? stable easy to drive?
The Reedy Setup is a great starting point for the car and made it easy and fun to drive.
snwchris is offline
Old 12-16-2014, 07:20 AM
  #6563
Trader Rating: 15 (100%+)
+1
Moved my driving up an entire grade point.
uncle everett is offline
Old 12-16-2014, 07:35 AM
  #6564
luist99's Avatar
I removed my sway bars and buggy drove much easier. I haven't try just adding the rear. I was at one of my local tracks here In Wisconsin ( trackside). This past Sunday and Let's just say it was glued to the track. And I'm running beams and full slots for tires. Was no expecting it to work that good. Now I need it to work that good at my racing track
luist99 is offline
Old 12-16-2014, 10:52 AM
  #6565
trick25's Avatar
Trader Rating: 28 (100%+)
Had mine 3 months so far. First weekend i broke a hinge pin(etruggy landed on it). Sunday i had my second actual break durning a playday. I came back to pits and noticed i had a broken front tower mount(the plastic part).
I run on bigger 1/8 outdoor style tracks. I love the car and i got a couple spare tower mounts coming. Just sharing this so you guys may want to get spare mounts when they come back in stock. It is hard to know what spares to keep cause this car breaks so little(good problem to have)
trick25 is offline
Old 12-16-2014, 11:01 AM
  #6566
Jcozz's Avatar
Trader Rating: 20 (95%+)
Having the same problem at my local indoor carpet track.
Jcozz is offline
Old 12-16-2014, 11:39 AM
  #6567
Definitely need to go up in shock oil, I would think. In the 60-80wt range probably. As for springs, not sure. Look into the heaviest AE big bore buggy springs. Not sure if Durango big bore springs will fit or not, but if they do, look into the heavier white series springs. What springs are ppl using on other brands of 4wd buggies running at your track? See if those brands of springs will fit your shocks.
Stealth_RT is offline
Old 12-16-2014, 01:17 PM
  #6568
I have found Reedy/OCRC setups to work very well on our local clay with other buggies.
With this in mind. Should I build up my kit on the stock chassis or the avid chassis?
And if you recommend the Avid chassis, should I make any adjustments to Ty's Reedy Setup to account for the difference?
phillypete is offline
Old 12-16-2014, 02:42 PM
  #6569
pags30805's Avatar
Trader Rating: 24 (100%+)
kit came in today, which pistons is everyone running for the 2x1.6 and 2x1.7? is it the VRPs or stock blanks drilled out?
pags30805 is offline
Old 12-16-2014, 02:49 PM
  #6570
Team Tekin
yzracer758's Avatar
Trader Rating: 18 (100%+)
The VRP's have been working very well.
yzracer758 is offline
