Like Tree35Likes
Old 12-08-2014, 05:35 AM   #6436
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
One thing to note: Ty's uses Kyosho low friction X-rings in his shocks. If you plan on running his set ups make sure to switch seals or else the car will feel over dampened due to added friction from the stock O-rings. If you want to use stock O-ring dropping 5wt oil will net the same "feel" as low friction X-rings.
Over the weekend I tested AE vs LOSI diff oils of the same cst rating (7k and 3k). On the bench ("wheel twisting hand dyno") and on track losi oil feels about 2k heavier than AE. Since I own more AE diff oils, I've switch my diffs to AE 10k front/5k rear to match Ty's Losi 7k front/3k rear.
Hot Bodies D413 1/10 4WD Buggy-nick-12-6-2014.jpg
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 12-08-2014, 06:33 AM   #6437
ironzgti35's Avatar
Trader Rating: 20 (100%+)
I thought Vision Racing Products had 2x1.6 and 1.7 pistons available? I can't seem to find them. Those who are running the RCSHOX, did you have to adjust oil for the piston thickness as is mentioned on the site?
HB Racing Proline Sweep Racing USA - PT RC Racing Oils
ironzgti35 is offline   Reply With Quote
Old 12-08-2014, 06:34 AM   #6438
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I went down 5wt. but I am in AZ, where it is warmer. you will need to adjust for your track.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 12-08-2014, 07:07 AM   #6439
kdeleon's Avatar
Originally Posted by Anupam Das View Post
Next up im trying the RC Shocks dual stage pistons (1.6 in front 1.7 in rear) as well as xgear springs. I will keep you updated.
Heads up. RC Shocks only has one size for the dual stage pistons. The specific 1.6 and 1.7 sizes are "regular" pistons. If you want to pick the specific size and want valved pistons, then you need to buy VRP.
They are on the site, but they are valved pistons. http://visionracingproducts.com/Hot-Bodies-D413_c5.htm
kdeleon is offline   Reply With Quote
Old 12-08-2014, 08:52 AM   #6440
Trader Rating: 15 (100%+)
Use Ty's exact setup.
- X springs (worth it)
- xring orings (traxxas work)
- shock shaft lengths
- washers
- arm inserts
-oils
**If using AE caps adjust shock length accordingly 1-1.5mm longer.
**pay close attention to rubbing on caster block, touch it with a Dremmel.
uncle everett is offline   Reply With Quote
Old 12-08-2014, 11:58 AM   #6441
[QUOTE=Slotmachine;13705391]The front hinge pin holder on the back of the arm has a washer behind it, if you increase the thickness of the washer it adds forward arm sweep.
What's the thickness are you adding, how much
billsharp34 is offline   Reply With Quote
Old 12-08-2014, 12:04 PM   #6442
add 1mm for a total of 2mm.
slasn_48 is offline   Reply With Quote
Old 12-08-2014, 12:44 PM   #6443
MantisWorx's Avatar
Trader Rating: 28 (97%+)
On the dual stage we went with the same configuration as Ty's latest setup but with quicker rebound and a more progressive pack so you can run a lighter oil to get you through the rough stuff. The tuning window is really wide with them so there is really no need to change hole configurations. The Flat pistons are available in 3 sizes with all of them being thicker than kit pistons for those that want to just copy the team setups. Which is more popular by far! All in all with 4 choices we got it covered!
MantisWorx is offline   Reply With Quote
Old 12-08-2014, 12:58 PM   #6444
Marcus's 2 stage pistons have always made my 2wd and 4wd cars "stuck" to the track. I prefer them over the 1.6/1.7 combo Ty runs.
Old 12-08-2014, 03:15 PM   #6445
Slotmachine's Avatar
Send a message via MSN to Slotmachine
[QUOTE=billsharp34;13706363]
I run 2mm total, but some have gone up to 3mm. I don't think 3mm is necessary.
Paul
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 12-08-2014, 05:23 PM   #6446
nitro neil's Avatar
Trader Rating: 73 (100%+)
I built my car for saddle packs. Im trying to put in my motor and it doesn't fit. It hits the steering post. Ive tried a viper motor and a D3.5 and neither fit.will this car work in this configuration.
TLR, SPEKTRUM,HORIZON HOBBIES, JCONCEPTS, Tekin, MIP, ONeill Brothers Racing, Axis RC, Large Scale RC, Boom rc, Team Chase,
nitro neil is offline   Reply With Quote
Old 12-08-2014, 06:39 PM   #6447
Team Tekin
yzracer758's Avatar
Trader Rating: 18 (100%+)
there are only a few motors that will fit in saddle pack configuration, you will have to dremel the steering post down in order to get the motor to fit.
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics | Carolina Custom Anodizing
Jeremy Potter
Tekin C.S. Manager
yzracer758 is offline   Reply With Quote
Old 12-08-2014, 06:57 PM   #6448
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
then why advertise a saddle pack config if it can't fit motors? who actually wants to grind down a steering post?
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 12-08-2014, 07:46 PM   #6449
jhautz's Avatar
Trader Rating: 85 (100%+)
That has to be the most ridiculous thing I have ever heard.
jhautz is offline   Reply With Quote
Old 12-08-2014, 08:11 PM   #6450
Team Tekin
yzracer758's Avatar
Don't shoot the messenger!
Jeremy Potter
Tekin C.S. Manager
