Like Tree35Likes
Old 12-05-2014, 12:30 PM   #6406
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by TheRcKid17 View Post
Prefer the ESC in the front or back? Shorty configuration
I run mine back
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 12-05-2014, 01:20 PM   #6407
Originally Posted by yzracer758 View Post
No right or wrong way on esc placement, Most run ESC up front, but lead HB engineer runs his out back.
to compensate for having my esc out back i run my battery full forward.
Torrance Deguzman
HPI/HB Mechanical Engineer
powered by LRP
T. Deguzman is offline   Reply With Quote
Old 12-05-2014, 01:33 PM   #6408
Trader Rating: 17 (100%+)
I do the same and had my battery all the way forward for quite awhile. The D413 has so much front grip it always felt like it was dragging the back around with it. So I just recently move the battery all the way back and really like how it balanced out the grip. Just something to try.
AlderBoy is offline   Reply With Quote
Old 12-05-2014, 06:38 PM   #6409
Finally got some track time with my new Schelle Racing +4mm chassis. So far I like it a lot. Since the extra length is in the front, it calms down the too-aggressive steering the car has normally. Car is now actually the same wheelbase as my 2w buggy. Less over-aggressive weight transfer to the front when coming hard into the turns, so the front doesn't grab suddenly and snap oversteer. Easier to drive harder, the suspension doesn't get all out of shape from getting on the gas hard, like it did on the stock chassis. And it doesn't add 100g to the weight of the car.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 12-05-2014, 06:47 PM   #6410
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I'm going to try some more kick up Saturday, I've been running 1&3 pin braces up front. Now Im at 1&2 it should give less turn in and more on power steering out of the corner
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 12-05-2014, 06:57 PM   #6411
pballer2777's Avatar
Trader Rating: 27 (100%+)
So I took the front arms off so I can try to find out why the arms are not free. The pin in the arm alone is free. Now when I put the pins thru the blocks and thtu the pins it tightens up. Even without the nut on the pin. I don't know what could be making it bind.
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 12-05-2014, 09:37 PM   #6412
check to make sure you have the orange 1mm spacers between the gearbox and the arm mounts. without them the arms will rub against the gearbox.
Torrance Deguzman
powered by LRP
Old 12-06-2014, 06:10 AM   #6413
Torrance....have you tried forward arm sweep on the car? I run it and like it a lot, it seems to make it more aggressive on turn in.
Old 12-06-2014, 06:36 AM   #6414
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Same here and it scaled better with the battery back all the way.
MantisWorx is offline   Reply With Quote
Old 12-06-2014, 06:56 AM   #6415
MantisWorx's Avatar
Originally Posted by RC*PHREAK View Post
pretty obvious at this point that you have some bone to pick with marcus. you put him on blast for helping customers with his products, but then you feel it's ok to slam him (after he's stayed out of this thread).
rcshox makes very good products that many racers are happy with and have had success with. yes, he makes aftermarket parts for rc's. yes, he expects to make money with his business. you don't like his products? don't use them. you say marcus "gouges" his customers, but a quick look shows that he charges $13 for a set of 4 pistons. the other company that was mentioned in this thread (visionracingproducts) charges $18. yet you call marcus out for "gouging"
Damned if i do damned if i dont.......
But thanks for the compliments i really appreciate it, some people just dont understand how the real world works. He is not the first nor will he be the last so it really does not bother me.
Old 12-06-2014, 07:01 AM   #6416
i do have washers there but maybe not enough. i have the .5mm. i will check later.
Old 12-06-2014, 08:44 AM   #6417
I currently have it on my car but I haven't been able to go to the track in months.
Torrance Deguzman
powered by LRP
Old 12-06-2014, 08:55 AM   #6418
I added 1mm to the front / rear arm mount to add some forward sweep to the front arms...and it definitely seems to have more off power turn in.
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 12-06-2014, 08:56 AM   #6419
Trader Rating: 132 (100%+)
Default Avid Chassis
you guys that are running the Avid chassis, have you noticed any differences with the handling on the buggy?
skyline1015 is offline   Reply With Quote
Old 12-06-2014, 11:36 AM   #6420
rangerjkb's Avatar
Trader Rating: 39 (100%+)
Send a message via MSN to rangerjkb
Just ordered the kit with a few option parts and truly appreciate current owners feedback and designer support throughout this thread. After only racing Onroad for the past 2 years, I'm looking forward to getting back to some Offorad racing. Considering all the great choices avaialable these days, the D413 looks to be the clear choice for getting the total package in a 10th scale 4WD Buggy.
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
