Like Tree28Likes
Old 11-30-2014, 10:05 PM   #6316
Nick_n's Avatar
PM sent Jay
Nick_n is offline   Reply With Quote
Old 12-01-2014, 12:38 AM   #6317
Hey I wanted to show a fellow racer the video of ty taking out cav and mayfield I cant find it anywhere? anyone got a link
Monkey#39 is offline   Reply With Quote
Old 12-01-2014, 12:43 AM   #6318
ProfessorX's Avatar
Trader Rating: 17 (100%+)
Any 2 x 1.6 shock Pistons out there the stock ones are too soft ????? Thanks for any info
ProfessorX is offline   Reply With Quote
Old 12-01-2014, 05:22 AM   #6319
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
RCShox makes some
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 12-01-2014, 06:15 AM   #6320
snwchris's Avatar
Originally Posted by Fastforward View Post
Slash shock caps are too small. Still searching.
The only option for Alum shock caps that work are the Serpent SRX caps and standoffs.
Originally Posted by lovell
I have serpent caps on my d413.
Here are the part numbers needed
500146-14.50
500137-4.69
500199-11.49
2-500176-23.99
500179-2.50
Also Post #5686 is picture proof of the Serpent Caps on and working
snwchris is offline   Reply With Quote
Old 12-01-2014, 06:32 AM   #6321
Check the first post on page one.
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 12-01-2014, 06:36 AM   #6322
ironzgti35's Avatar
Trader Rating: 20 (100%+)
Noticed some side to side play between the rear hub and the hex. Bearing are still good but was thinking about adding a shim or two behind each hex to tighten it up a little without binding.
HB Racing Proline Sweep Racing USA - PT RC Racing Oils
ironzgti35 is offline   Reply With Quote
Old 12-01-2014, 11:19 AM   #6323
Originally Posted by LightningStruck View Post
I'm running the Reedy setup, and need to get more rear bite. We have an off camber hair pin, and the car tends to get loose on the application of power, coming out of the hair pin. Current diff oils are 7/100/3, 37.5f/32.5r, 2x1.6f/2x1.7r. Running the copper front sway bar, black rear. I'm thinking of adding some anti-squat, going to the 1 dot C insert. Everywhere else on the track the car feels ok, maybe a touch too much steering since the car rotates so dang quick.
Any ideas what to try?
I had the same problem initially running the Reedy setup as well. I did two things that helped. I pulled the rear sway bar and kept the front to tame the front steering a wee bit. I went up in rear diff oils to 5K (7/100/5). These helped me plant the rear a bit more.
Vincent_Diesel is offline   Reply With Quote
Old 12-01-2014, 12:39 PM   #6324
Team Tekin
yzracer758's Avatar
http://www.visionracingproducts.com/...es-D413_c5.htm
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics | Carolina Custom Anodizing
Jeremy Potter
Tekin C.S. Manager
yzracer758 is offline   Reply With Quote
Old 12-01-2014, 02:34 PM   #6325
Tobiasmart's Avatar
Originally Posted by Wildcat1971 View Post
lol, I only order from sights in english
Try clicking on the English flag at the top then :-)
Tobiasmart is offline   Reply With Quote
Old 12-01-2014, 02:36 PM   #6326
Hoese37's Avatar
Originally Posted by pballer2777 View Post
what are the handling differences between the 2 battery configs?
Saddle pack I a bit heavier, and from what I hear from a local fast guy running that setup, its just more stable. The car isn't as aggressive.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 12-01-2014, 11:40 PM   #6327
just started my build missing parts in bag A..... LAME..missing the front shock collars nuts
Old 12-02-2014, 03:55 AM   #6328
vadersing's Avatar
has anyone tried running the D413 as a 2WD?
vadersing is offline   Reply With Quote
Old 12-02-2014, 06:48 AM   #6329
big greg's Avatar
Trader Rating: 119 (99%+)
this weekend at rc clubhouse with 276 entires, 5 heats of 4 wheel buggy, my car was fast enough to be top 5, just had mistakes in qualifying and the A main obviously, my fast lap wasn't far off the phenom, I know hot lap doesn't matter but still lol, got tangled up a bunch in the A, ill try to get my setup sheet posted
Hot bodies d812e tekin T8 1700 rx8 gen 2
Hotbodies d815 o.s. speed Tessman ed
Hb/hpi racing, vp pro usa, Lutz rc, valvenous paint, tekin racing, rc addiction products/nitro pro fuel
Rip bill bridges
big greg is offline   Reply With Quote
Old 12-02-2014, 06:54 AM   #6330
Team Tekin
yzracer758's Avatar
Contact HB/HPI Customer Service and they should be able to get you what you need.
Jeremy Potter
Tekin C.S. Manager
