Like Tree31Likes
Old 11-23-2014, 05:02 PM   #6211
thanks
billsharp34 is offline   Reply With Quote
Old 11-23-2014, 05:43 PM   #6212
Trader Rating: 520 (100%+)
Originally Posted by skyline1015 View Post
I rum losing springs on mine
Looks to me like you should lay off the "rum"..j/k
flame56mx is offline   Reply With Quote
Old 11-23-2014, 05:47 PM   #6213
Trader Rating: 21 (100%+)
I prefer winning springs....��
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 11-23-2014, 06:18 PM   #6214
cokemaster's Avatar
Trader Rating: 18 (100%+)
Originally Posted by AlderBoy View Post
Does anyone know if the Avid floating servo mount works with the stock chassis?
The Avid servo mount uses 3 screws, so it will not fit if you are not willing to make some extra holes in your chassis.
Fleet:TLR 22 3.0, XB4 16, Mugen MBX7RE
ESC: Viper, Tekin, Airtronics/Sanwa
Motor: Novak, Tekin, Trinity, Scorpion
Radio: Airtronics M12
cokemaster is offline   Reply With Quote
Old 11-23-2014, 07:23 PM   #6215
jwood7's Avatar
Originally Posted by billdogg View Post
I'm running Ty's Reed race setup right now, and it's good. A bit twitchy if anything. I'm running no front sway bar now. What is the effect if I add the front sway bar?
I run on a tight indoor track med to low grip and found Ty's setup very twitchy to drive. Things that I did to calm it down. Orange front spring, take the shim off the Ackerman, copper sway bar on front, glue the front arm insert. U can also move the battery back.
This car is pretty sweet to drive. It can be driven hard and is still forgiving. Coming off a summer of driving 1/8 scale this car is a perfect fit.
AE has a 3/16 shim that works perfect on the Ackerman to take out the slop. And it's only $3
And after driving my car my buddy with a zx6 is pissed that he bought the wrong car
jwood7 is offline   Reply With Quote
Old 11-23-2014, 07:29 PM   #6216
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Here's a video of my win Saturday, Im running the black and green starting in first.
http://m.youtube.com/watch?v=UlX2uCXZiZw
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 11-23-2014, 08:15 PM   #6217
Trader Rating: 17 (100%+)
Cool, thanks!
AlderBoy is offline   Reply With Quote
Old 11-23-2014, 08:29 PM   #6218
trick25's Avatar
Trader Rating: 25 (100%+)
that was a good race. way to shake off some of the tangles and pipe bumps mid race.
4wd bug-D413, Blinky bug-XB2 17 CE 4wd SC-SCT410
trick25 is offline   Reply With Quote
Old 11-23-2014, 08:58 PM   #6219
Thanks......it was fun battling with Jose, he is one of the local Losi guys. I let him go a few times because I was confident in the way the car was handling. Slicks are working at our track now and if you get in the dust you just cant do anything about it.
Old 11-24-2014, 06:30 AM   #6220
billdogg's Avatar
Trader Rating: 15 (100%+)
Had my first real race yesterday. Car felt really good overall. In the A main though, my front shock cup became dislodged and fell off (really hurts performance obviously). Do you guys zip tie these to the bottom coil of the spring? These are the standard ones, not the mud guard type.
What is the advantage of running the wing mounts upside down?
What are you using to glue your arm inserts on?
billdogg is offline   Reply With Quote
Old 11-24-2014, 06:50 AM   #6221
Trader Rating: 131 (100%+)
Here you go. Check the 1st page of the thead.
Increasing Arms Stiffness
We know the D413 has "Signature HB Monocoque suspension arms for stiffness, strength and adjustability" but you can increase the stiffness without buying the carbon fiber plates.
Originally Posted by T. Deguzman View Post
just normal tire CA. gluing the covers gives it some extra stiffness. for example if you glue the plastic cover it'll be stiffer than an unglued screwed plastic cover but not quite as stiff as screwed carbon cover.
Wing Mounts
it's a built in feature - you can run the mounts in a high or low wing configuration. high wing is more stable on the ground. low wing is more stable in the air during high wind conditions. it was very windy at the worlds coupled with some big jumps.
and.... each wing mount is held by an upper screw and a lower screw. you can adjust the wing angle by adding shims to one of the screw locations. you probably can't see it in the pictures by Ty has a 0.5mm shim on the lower screw to give the wing a little more angle of attack.
skyline1015 is offline   Reply With Quote
Old 11-24-2014, 07:34 AM   #6222
Jcozz's Avatar
Trader Rating: 20 (95%+)
Got to the front diff and got everything together and stripped one of those tiny screws. Bummer for sure. Just built a Kyosho RT6 the last 2 days and didn't strip a single screw. Guess I'll whip out the Dremel.
Jared Cozzocrea
HobbyPro PRS1 / HobbyPro SB401 / Fusion Graphics / Mayor RC
Premier RC Raceway and Hobbies
Dave's RC Tracks
Jcozz is offline   Reply With Quote
Old 11-24-2014, 11:16 AM   #6223
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
IMO, some of the screws seem to be low grade. Those screws are long and have a small head. I would user a cap head screw to pre-thread then put the little guy in.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-24-2014, 11:44 AM   #6224
trick25's Avatar
and dont use a electric screwdriver.
Old 11-24-2014, 11:47 AM   #6225
JDJamminX1's Avatar
Also its a 1.3mm size hex driver, not a .050. That will strip a screw.
LRP - MUGEN - AKA - OCRC - UPGRADE - SCHELLE - DE RACING
JDJamminX1 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
