Like Tree29Likes
Old 11-22-2014, 05:02 AM   #6196
Vinny Cancilla's Avatar
Originally Posted by billdogg View Post
I'm running Ty's Reed race setup right now, and it's good. A bit twitchy if anything. I'm running no front sway bar now. What is the effect if I add the front sway bar?
I would think the front swaybar would calm it down a little.
Serpent Srx8
Serpent America: Triton engines/ Nitro pro.Fuel/ Rc Addiction products : Vp pro Usa/Dialed-Rc
Barnstormers: Chester, NY, N.Y.. IRH Lindenhurst
Vinny Cancilla is offline   Reply With Quote
Old 11-22-2014, 05:51 AM   #6197
Trader Rating: 21 (100%+)
It will push like a dump truck.....red springs, 1.6 2 hole piston with 42.5 losi....start there...been running this on a medium bite clay track
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 11-22-2014, 06:59 AM   #6198
Firewood's Avatar
Trader Rating: 19 (100%+)
Ran my D413 (reedy setup) for the first time last night. What a blast. I only ran two heats, no practice at all, never even drove a 1/10 4wd buggy and let me say this thing is glued to the track. I'm not yet able to drive the car to it potential yet. Im so used to 17.5 sc and buggy. Running a 7.5t motor provide plenty of snap, car jump perfectly -
Can't wait to get back out there -
Ken Woychuk
TLR 22SCT & 22T - Hot Bodies D413
Mugen MBX6 E-Buggy & MBX6T Nitro
ISLAND RACEWAY & HOBBY LONG ISLAND NY
Firewood is offline   Reply With Quote
Old 11-22-2014, 09:06 AM   #6199
Trader Rating: 17 (100%+)
Does anyone know if the Avid floating servo mount works with the stock chassis?
AlderBoy is offline   Reply With Quote
Old 11-22-2014, 12:33 PM   #6200
Matt :-)'s Avatar
Originally Posted by bigemike View Post
serpent caps for their 1/10th scale buggies with standoff work, but it isn't a needed upgrade unless you plan on wrecking a ton. The stock setup is very decent and very usable until hotbodies comes up with something else.
I've had my D413 since July. Everything has been dead reliable so far. I just like aluminum shock caps.
Matt :-) is offline   Reply With Quote
Old 11-22-2014, 06:31 PM   #6201
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
So i have a couple hundred laps on my d413 with the Avis chassis and RC shox rack and 2 stage pistons. The Avid chassis definitely keeps the weight lower. A plus was also my temps dropped. After first I thought it was my imagination, but I could feel the heat in the chassis after it moved gown the motor mount to the chassis. I am running on high bite and it was fantastic. The RCShox pistons are so freaking plush to drive on. They beat those kit pistons hands down. I was running 37.5/30 oils with them. The steering rack has held up like a champ. Also, I still feel like the RCShox rack tighten up the car. We have retarded traction and I could feel it.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-22-2014, 06:59 PM   #6202
ironzgti35's Avatar
Trader Rating: 20 (100%+)
Ran my D413 for the first time today and it was a blast! Held up great and was quite impressed. Only issue was not enough lock tight on the hinge pin mounts into the diff case. During 2 qualifiers they loosened and the car still felt great.
HB Racing Proline Sweep Racing USA - PT RC Racing Oils
ironzgti35 is offline   Reply With Quote
Old 11-22-2014, 07:30 PM   #6203
tom2tone's Avatar
Trader Rating: 98 (100%+)
Is anyone running a tekin rs pro gen 1 in their buggy? I'm just curious if anyone has had good luck with them? I did a search and saw someone say that you needed two capacitors
Forgot to mention, I'll be running a tekin 6.5 gen 2
TEKNO EB48.3 / ET48
AE T5M & B6
Tekin / AKA / Hitec / SMC / Futaba
Trains and Lanes Racing http://tandlracing.com/
Dunn Raceway Park http://drprc.com
tom2tone is offline   Reply With Quote
Old 11-22-2014, 08:09 PM   #6204
kdeleon's Avatar
Not exactly the same, but I run the ESC and same motor in my 22-4. It was my back up gear. It has been running fine with one capacitor. Nothing really got any hotter. I just don't like the esc as much as the R10s that I run in my other cars. The throttle response just isn't as smooth.
kdeleon is offline   Reply With Quote
Old 11-22-2014, 08:57 PM   #6205
tom2tone's Avatar
Ok thanks, my set up is also kind of back up electronics. Just want to make sure Ill be able to race it.
TEKNO EB48.3 / ET48
AE T5M & B6
Old 11-23-2014, 03:13 PM   #6206
who makes or what are these xgear spring ty has on his setup sheet
billsharp34 is offline   Reply With Quote
Old 11-23-2014, 03:24 PM   #6207
Kyosho.
sime46 is offline   Reply With Quote
Old 11-23-2014, 03:35 PM   #6208
alexkenison's Avatar
hey guys i know a few of you have been wondering if anyone has set the car up as saddle pack config. well here it is. i have driven both cars back to back with a similar setup, and can say that the saddle pack setup is a little more stable than the shorty setup but however it is not as agile as you can imagine being a little heavier. i did have to grind the steering rack slightly to clear the sensor port on the motor but i dont think it will compromise the strength of the rack.
i apologize for the not getting a better shot of the rack. i will get one when i go to the track next.
Full Throttle Raceways - 510 Raceway
Kyosho RB6 - Hot Bodies D413
Sworkz S350 BE1 EVO
Airtroics - Tekin - Savox - Proline
alexkenison is offline   Reply With Quote
Old 11-23-2014, 03:41 PM   #6209
Trader Rating: 33 (100%+)
Kyosho but I wouldn't waste money on them. I run AE springs or HB stuff and very happy with either option and saved a lot of money.
GettinLapped is offline   Reply With Quote
Old 11-23-2014, 04:27 PM   #6210
Trader Rating: 130 (100%+)
I rum losing springs on mine
skyline1015 is offline   Reply With Quote
