Like Tree28Likes
Old 11-17-2014, 09:39 AM   #6076
Vinny Cancilla's Avatar
Originally Posted by cokemaster View Post
Not sure if everybody notice the comment on Ty's carpet setup. Look at the top, where he mention the Avid chassis.
http://www.petitrc.com/setup/hotbodi...Setup20141109/
Is the Avid chassis geared towards high bite tracks only.
Serpent Srx8
Serpent America: Triton engines/ Nitro pro.Fuel/ Rc Addiction products : Vp pro Usa/Dialed-Rc
Barnstormers: Chester, NY, N.Y.. IRH Lindenhurst
Vinny Cancilla is offline   Reply With Quote
Old 11-17-2014, 09:54 AM   #6077
jhautz's Avatar
Trader Rating: 85 (100%+)
Originally Posted by Wildcat1971 View Post
So, I moved my esc back behind the motor. I have been wanting to try that out for balance and because it makes the electronics install nice. Anyone else tried this on bumpy high bite?
I thought about it, but even with my esc installed on the front, the car is still weight biased towards the rear. I didn't want to move even more weight back there.
I am interested to hear your thought on how it affects the handling.
jhautz is offline   Reply With Quote
Old 11-17-2014, 10:10 AM   #6078
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
your side to side is 50/50? Did you use weight to get that? What electronics are you running. Haha, 1727 weight. I will be over 1800 once I get my chassis protector on, lol. My track is pretty high bite and I expect it to get rutted for "States" this weekend. I am hoping that extra weight and stiffness helps.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-17-2014, 10:16 AM   #6079
jhautz's Avatar
Actually it's not 50/50 right to left. It's heavier on the battery side. The combination numbers shown on that scale are front right/left rear and front left/right rear cross weight. If you look at the individual corner weights it is heavier on the battery side.
Old 11-17-2014, 10:28 AM   #6080
yeah, I saw that, about 19g grams. I was referring to the PCT in the middle. Man, I kinda want those scales, just because I am geeky like that
Old 11-17-2014, 10:41 AM   #6081
billdogg's Avatar
Trader Rating: 15 (100%+)
Originally Posted by billdogg View Post
First practice night with this buggy. I am using Ty's Reedy setup with the exception of kit springs, plastic arm inserts. Running on a medium bite hard packed dirt track with SS gold web front, and clay dirt web rear. Car felt really good, except for low speed 180' turns. I'm new to 4wd cars. With my 2wd cars, I could blip the brake and get the car to rotate. With this, it would just slow down, and could not get the car turned quickly. I added a gold front sway bar as per suggestion from another racer. Car felt a bit better in high speed corners, but the same on the low speed corners.
What should I try, sway bars, springs, diffs?
Like I said, I'm new to 4wd, so tuning with sway bars and diffs is new to me. Any help with those would be appreciated.
Talked to some locals about 4wd tires, and borrowed a set of HB fullslots for the front. This helped quite a bit. I am also going to try going 60K center diff instead of the 100K.
billdogg is offline   Reply With Quote
Old 11-17-2014, 11:30 AM   #6082
cokemaster's Avatar
Trader Rating: 18 (100%+)
I believe the chassis is stiffer, so yes it will help on high bite. For my part, i hope the lower cg will make the car easier to drive. Maybe Wildcat1971 can tell us how much stiffer the chassis feels?
Fleet:TLR 22 3.0, XB4 16, Mugen MBX7RE
ESC: Viper, Tekin, Airtronics/Sanwa
Motor: Novak, Tekin, Trinity, Scorpion
Radio: Airtronics M12
cokemaster is offline   Reply With Quote
Old 11-17-2014, 11:37 AM   #6083
I think going to 60k in the middle will only lock the rear in more.
Serpent Srx8
Old 11-17-2014, 11:43 AM   #6084
A lot, lol. I can twist the crap out of the cf chassis, the avid does not really twist at all. Front to back the CF didnt really flex at all with the chassis top plates, it is mostly side to side.
Old 11-17-2014, 11:44 AM   #6085
Trader Rating: 17 (100%+)
How does your setup compare with Ty's reedy setup, which is suppose to be easy to drive also.
Mine was easier to drive for me and others that tried both.
AlderBoy is offline   Reply With Quote
Old 11-17-2014, 12:03 PM   #6086
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
Myself, along with a few locals ran this set up over the weekend at our indoor series race. 6 D413's made the A-main.
Hot Bodies D413 1/10 4WD Buggy-nick-11-14-2014.jpg   Hot Bodies D413 1/10 4WD Buggy-collage_1.jpg
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 11-17-2014, 12:08 PM   #6087
Great, that's what I need, easier! Lol
Serpent Srx8
Old 11-17-2014, 12:16 PM   #6088
Did you find going to 60k in the middle gabe you more rear on power traction?
Serpent Srx8
Old 11-17-2014, 12:45 PM   #6089
kdeleon's Avatar
Has anyone tried the RCShox ackerman bar? I'm curious to get a report on it. Does it offer any driving improvement beyond the removal of slop?
kdeleon is offline   Reply With Quote
Old 11-17-2014, 12:48 PM   #6090
billdogg's Avatar
I could be wrong, but reading the Hudy 1/10 off road setup book, they say a thinner center diff will increase off power steering. It's worth a shot.
