Like Tree31Likes
Old 11-14-2014, 06:36 AM   #6031
Trader Rating: 36 (100%+)
Send a message via AIM to robby26wi Send a message via Yahoo to robby26wi
looking for a good indoor med bite smooth track setup...any suggestions..
robby26wi is offline   Reply With Quote
Old 11-14-2014, 06:40 AM   #6032
Trader Rating: 17 (100%+)
Folks seem to have good luck with mine:
http://www.petitrc.com/setup/hotbodi...bbies20140608/
AlderBoy is offline   Reply With Quote
Old 11-14-2014, 06:42 AM   #6033
ok thanks...just starting build...lunsford tie rods and camber rods,b5 al caps and avid mounts...any other stuff needed before i build?
Old 11-14-2014, 06:45 AM   #6034
Vinny Cancilla's Avatar
How does your setup work on a medium/low bite track. What adjustments would you make if any.
Serpent Srx8
Serpent America: Triton engines/ Nitro pro.Fuel/ Rc Addiction products : Vp pro Usa/Dialed-Rc
Barnstormers: Chester, NY, N.Y.. IRH Lindenhurst
Vinny Cancilla is offline   Reply With Quote
Old 11-14-2014, 07:17 AM   #6035
I was told that the B5 alu caps doesn't work.
ColourGhost is offline   Reply With Quote
Old 11-14-2014, 07:19 AM   #6036
snwchris's Avatar
You need the B5 composite caps and standoffs, the ALs don't seem to work. The only Alum ones that seem to fit and work are the Serpent SRX ones, but you need their standoffs and few other items too to make them work.
TYs Reedy Setup was a great starting point for a lot of us at our med-high bite track.
snwchris is offline   Reply With Quote
Old 11-14-2014, 07:19 AM   #6037
Super Moderator
DRTMI's Avatar
Trader Rating: 27 (100%+)
Not the aluminum caps, the plastic ones.
A gun in the hand is better than a cop on the phone.
A 9mm might expand but a .45 will never shrink.
The gene pool needs a little chlorine.
DRTMI is offline   Reply With Quote
Old 11-14-2014, 07:20 AM   #6038
great...glad i ordered them lol..
Old 11-14-2014, 07:44 AM   #6039
snwchris's Avatar
The first page has the part numbers listed, which are composite.
Maybe you can sell the Al B5s to someone at your local track
Old 11-14-2014, 07:46 AM   #6040
I cancelled order hopefully...was on ebay...read the sticky now..Thanks much
Old 11-14-2014, 07:53 AM   #6041
tom2tone's Avatar
Trader Rating: 98 (100%+)
Originally Posted by kdeleon View Post
For those racing on carpet, did you see that Ty posted a new carpet setup:
http://www.tytessman.com/setups/pdf/...rpet-setup.pdf
I'm hoping to start the build today, can I build the kit with this set up with whats included? Or do I need to buy any specific parts? Extra shims?
I know sometimes it's best to build the kits stock and tune from there. But this could potentially save some headaches.
My track doesn't allow the pinpoints and I've got a 6.5 for a motor.
TEKNO EB48.3 / ET48
AE T5M / B6
Tekin / AKA / Hitec / SMC / Futaba
Trains and Lanes Racing http://tandlracing.com/
Dunn Raceway Park http://drprc.com
tom2tone is offline   Reply With Quote
Old 11-14-2014, 09:15 AM   #6042
kdeleon's Avatar
Not sure about this particular setup. But even for the other setups, you will need extra washers. You can kind of move things around from the standard build, but it takes planning. Easier to just buy the two different size washers that HPI has or some other brand if you don't like orange.
kdeleon is offline   Reply With Quote
Old 11-14-2014, 09:50 AM   #6043
rider313's Avatar
Trader Rating: 94 (100%+)
I hate the orange. I am about to strip it all on my next rebuild.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 11-14-2014, 09:52 AM   #6044
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
yeah, I am not a fan either, but the anno stripped alum looks like crap. no gloss to to it.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-14-2014, 10:15 AM   #6045
the incubus's Avatar
That is super easy to polish back up. Just a dremel, some regular car polish (polishing rouge would make it easier) and a screw with a large head to keep components like washers and nuts from flying on you and you can achieve this:
Those are bushings from my old TopKart racing chassis. There are many of them and they were an expense i knew I didn't have to incur on my wallet because they would be simple enough to polish back to new. My brother-in-law was like holy crap! LOL
The trick is to place your polishing bit at an angle that applies sideways resistance while forcing the part to rotate which results in time savings and a uniformly polished surface. To do screw heads you need to find a larger nut and drop them in and secure with an actual nut to keep it from flying out and use the same technique on the heads.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
