Like Tree28Likes
Old 11-13-2014, 05:17 PM   #6016
Trader Rating: 21 (100%+)
Be sure to glue the inserts....otherwise you'll get to much arm flex, will feel inconsistent
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 11-13-2014, 05:32 PM   #6017
Vinny Cancilla's Avatar
Do you use the screws and glue together?
Serpent Srx8
Serpent America: Triton engines/ Nitro pro.Fuel/ Rc Addiction products : Vp pro Usa/Dialed-Rc
Barnstormers: Chester, NY, N.Y.. IRH Lindenhurst
Vinny Cancilla is offline   Reply With Quote
Old 11-13-2014, 05:37 PM   #6018
Trader Rating: 33 (100%+)
yes use both
GettinLapped is offline   Reply With Quote
Old 11-13-2014, 05:51 PM   #6019
Trader Rating: 120 (100%+)
Is anybody on here using the 2 stage 3 hole RCShox piston's and if so can you please give some feedback. Thanks.
22-4
MBX7R Eco, RC8B3E
MBX7R. RC8B3
JoeC is offline   Reply With Quote
Old 11-13-2014, 06:02 PM   #6020
Slotmachine's Avatar
Send a message via MSN to Slotmachine
try shoo-goo and screws.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 11-13-2014, 06:33 PM   #6021
bigemike's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to bigemike
shoe goo is alot more weight than ca
No sponsors. Love TLR, OS and Futaba though
bigemike is offline   Reply With Quote
Old 11-13-2014, 06:42 PM   #6022
Are most guys using the the stock plastic ones or the carbon. It seems like Ty uses the carbon on most of his setups.
Serpent Srx8
Old 11-13-2014, 07:09 PM   #6023
Got a little bored tonight while prepping a Proline Type-R body, wanted to see if I could make a really good condition Finnisher body fit that I had for my old D4 (actually a B44.2 body that fit the D4). It works ok, but might be tough to trim without another body to use as a guide, so I pressed the already cut out Proline body over the JC one lining up the front body mount hole and used that as a guide for the recesses of the shock tower mounts. Took a bit of trial and error, trimming slowly, but its definitely useable. Looks a bit less cab forward than normal, but not too bad. One issue I'm noticing is that the servo horn is hitting the side on full right steering, I think I can get it to work though. I'll should be giving it a track test tomorrow.
pullinteef is offline   Reply With Quote
Old 11-13-2014, 07:20 PM   #6024
MantisWorx's Avatar
Trader Rating: 28 (97%+)
That looks really good!
MantisWorx is offline   Reply With Quote
Old 11-13-2014, 08:34 PM   #6025
ironzgti35's Avatar
Trader Rating: 20 (100%+)
Are you guys shimming the rear hubs and arms? With the Ty reedy spacers on the rear arms there is still play, could use a .5 shim I think. Also the rear hubs slide a bit side to side as well.
HB Racing Proline Sweep Racing USA - PT RC Racing Oils
ironzgti35 is offline   Reply With Quote
Old 11-13-2014, 09:46 PM   #6026
kdeleon's Avatar
I added an additional .5 mm washer. And there is still a little play. If you look at Ty's other setups, he does put 2.5 mm of washers at times.
kdeleon is offline   Reply With Quote
Old 11-13-2014, 09:48 PM   #6027
kdeleon's Avatar
For those racing on carpet, did you see that Ty posted a new carpet setup:
http://www.tytessman.com/setups/pdf/...rpet-setup.pdf
Old 11-14-2014, 03:54 AM   #6028
Firewood's Avatar
Trader Rating: 19 (100%+)
I did. Shimmed the slop out of the back. The front was good on mine so I didn't need any additional shims there.
Ken Woychuk
TLR 22SCT & 22T - Hot Bodies D413
Mugen MBX6 E-Buggy & MBX6T Nitro
ISLAND RACEWAY & HOBBY LONG ISLAND NY
Firewood is offline   Reply With Quote
Old 11-14-2014, 04:08 AM   #6029
Well I run on a high bite clay indoor track and I use the plastic inserts and the car is a monster. I drove another D413 with carbon inserts and didn't notice much difference that would validate the cost. I glued my plastic inserts and seems good enough for me.
Old 11-14-2014, 04:40 AM   #6030
snwchris's Avatar
Hmmmm interesting cause I didn't glue my insert and car feels super great and each week I get consistently faster with it shaving more time off.
snwchris is offline   Reply With Quote
